Introduction: Python Tic Tac Toe Game
python tic tac toe game
this game is made in python that's a computer language
i have used a python editor called : pycharm you can also use normal python code editor also
Step 1: Import
from tkinter import *
Step 2: Root
root = Tk()
root.title(" 3T TIC TAC TOE") # Title
text = Entry(root, font=("ds-digital", 15)) text.pack(fill=X, padx=5, pady=5, ipadx=5, ipady=5) # Text
board = ["-", "-", "-"
, "-", "-", "-"] # Board
Step 3: Function After Putting Into the Editor It Show Warrnings Click the Warrnigs and Give Assambel All
# Functions
player = "X" button = [] stop_game = False stop_game_tie = False
def Turn(): # Printing Turn text.delete(0, END) text.insert(0, "{}'S TURN".format(player))
def Exit(): root.destroy() exit()
def Game_Over(): # Chech if game is over Check_Winner()
if stop_game == True: Hplayer() text.delete(0, END) text.insert(0, "'{}' WINNER".format(player))
else: Check_Tie()
if stop_game_tie == True: text.delete(0, END) text.insert(0, "TIE MATCH")
def Check_Winner(): # Check if there is a winner global stop_game
row_1 = board[0] == board[1] == board[2] != "-" row_2 = board[3] == board[4] == board[5] != "-" row_3 = board[6] == board[7] == board[8] != "-" if row_1 or row_2 or row_3: stop_game = True
column_1 = board[0] == board[3] == board[6] != "-" column_2 = board[1] == board[4] == board[7] != "-" column_3 = board[2] == board[5] == board[8] != "-" if column_1 or column_2 or column_3: stop_game = True
diagonal_1 = board[0] == board[4] == board[8] != "-" diagonal_2 = board[2] == board[4] == board[6] != "-" if diagonal_1 or diagonal_2: stop_game = True
def Check_Tie(): # Check if it is a tie match global stop_game_tie
if "-" not in board: stop_game_tie = True
def Hplayer(): # Managing Turn global player
if player == "X": player = "O"
else: player = "X"
def Add_Text(pos, play): # Add Text global button
if pos not in button and stop_game == False and stop_game_tie == False and pos != 9: Turn()
def_buttons[pos].configure(text=play) board[pos] = player
button.append(pos) Hplayer() Turn() Game_Over()
Step 4: Final Code It Will Give a Final Look👇
# GRID
def New_Match(): # New Match Button Function global board global player global button global stop_game global stop_game_tie
button_1.configure(text="") button_2.configure(text="") button_3.configure(text="") button_4.configure(text="") button_5.configure(text="") button_6.configure(text="") button_7.configure(text="") button_8.configure(text="") button_9.configure(text="") board = ["-", "-", "-", "-", "-", "-", "-", "-", "-"] player = "X" button = [] stop_game = False stop_game_tie = False Turn()
# Buttons
Turn()
frame = Frame(root) frame.pack(side=TOP, anchor=NW)
frame1 = Frame(frame) frame1.pack()
button_1 = Button(frame1, text="", width=8, height=3, command=lambda: Add_Text(0, player),bg = 'pink') button_1.pack(side=LEFT)
button_2 = Button(frame1, text="", width=8, height=3, command=lambda: Add_Text(1, player),bg = 'pink') button_2.pack(side=LEFT)
button_3 = Button(frame1, text="", width=8, height=3, command=lambda: Add_Text(2, player),bg = 'pink') button_3.pack(side=LEFT)
frame2 = Frame(frame) frame2.pack()
button_4 = Button(frame2, text="", width=8, height=3, command=lambda: Add_Text(3, player),bg = 'blue') button_4.pack(side=LEFT)
button_5 = Button(frame2, text="", width=8, height=3, command=lambda: Add_Text(4, player),bg = 'blue') button_5.pack(side=LEFT)
button_6 = Button(frame2, text="", width=8, height=3, command=lambda: Add_Text(5, player),bg = 'blue') button_6.pack(side=LEFT)
frame3 = Frame(frame) frame3.pack()
button_7 = Button(frame3, text="", width=8, height=3, command=lambda: Add_Text(6, player),bg = 'orange') button_7.pack(side=LEFT)
button_8 = Button(frame3, text="", width=8, height=3, command=lambda: Add_Text(7, player),bg = 'orange') button_8.pack(side=LEFT)
button_9 = Button(frame3, text="", width=8, height=3, command=lambda: Add_Text(8, player),bg = 'orange') button_9.pack(side=LEFT)
frame4 = Frame(frame) frame4.pack()
button_clear = Button(frame4, text="NEW MATCH", width=13, height=3, command=lambda: New_Match(),bg = 'violet',foreground = 'red') button_clear.pack(side=LEFT)
exit_button = Button(frame4, text="EXIT", width=12, height=3, command=lambda: Exit(),bg = 'green',foreground = 'orange') exit_button.pack(side=LEFT)
def_buttons = [button_1, button_2, button_3, button_4, button_5, button_6, button_7, button_8, button_9]
root.mainloop()
