Introduction: Quadratic Formula Program for TI-83, 84 Calculators
What you will Need:
- A TI-83 or 84 calculator (silver edition, plus, it all works)
and
- A little patience
First let's go over some basics
Your TI - 83 - 84 uses a programming language called TI-BASIC and as the name says, it's a basic, simple programming language that is easy to write for short programs, and requires creativity to create complex programs. You can write programs on your calculator and run them directly.
To Program a calculator there is a button called: PRGM i will point it out in a picture, basicly after you have opened the Program maker and editor, you will push this button to access a list of commands that your calculator understands and we can put them together to make programs.
Step 1: Open the Gates to Programming!
The pictures are marked so that you can follow along on your calculator
This part is about Creating a New Program
Step 2: Time to Program!
Here is the code to plug into the calculator it will go: CODE and then i will tell u where to find that command it will be divided between code and where it is
Here's the Code that goes into the Calculator:
:ClrHome
:Input A
:Input B
:Input C
:(B^2-4AC)->X
:If X
Disp "No Real Answer"
:(-B+√(x))/(2A)->Y
:(-B-√(x))/(2A)->X
: Leave blank and press enter for next line
:Disp Y,X
Step 3: Try It!
Enjoy and i will write some games, other math equation programs and so on!
Thank you!
-Maker9000
P.S the ? you get when you open the program is normal, it's asking for the variable A, then B and finally C
