Introduction: Quick Clamp for Track Saw
My track saw has screw clamps which firmly hold the track in place. However the screw clamps take a bit of time to tighten. If you need to move the track often, you would like a quicker way of clamping the track.
Step 1: Sourcing the Parts
You need a quick clamp and a bit of metal that fits your saw track. I used a broken quick clamp. I tried to glue it, but it wasn't strong enough anymore. So that is a perfect donor.
For the metal I found a corner bracket that was exactly the width of the slot in my saw track, so I cut two strips of that.
Step 2: Welding It Up
Place the clamp on the metal strip and weld it. I used TIG welding with a little bit of filler material.
I then welded another metal strip on top to prevent the strip from bending when tightening
