Introduction: Quick, Easy, and Delicious Pasta
If you need a quick and easy way to make pasta you've come to the right recipe. This takes about 20 minutes and is tasty for people of all ages. I'm going to show you how to make and enjoy the most delicious pasta out there!
All you need is pasta, water, a medium sized pot, a spoon, salt, olive oil, butter, and parmesan.
Step 1: Gather Your Supplies
Gather the supplies listed above and get ready to cook!
Step 2: Fill Your Pot
Take your pot and fill it up with about 5-6 cups of water.
Step 3: Put Your Pasta on the Stove
Put your pot on the stove, and turn your stove on high. Wait for your water to boil (This could take up to fifteen minutes depending on your stove). Make sure your water doesn't overflow.
Step 4: Water Boils
When your water starts to bubble, turn your stove down to medium (if your stove had numbers it should be about 5-7).
Step 5: Olive Oil and Salt
Directly after step three, add a splash of olive oil and a sprinkle of salt to your pot. Mix around your water with a spoon/spoonula.
Step 6: Pour in Pasta
Pour in the amount of pasta you want to make. Set your timer to 8 minutes.
Step 7: Stir
Stir your pasta for about 15 seconds every two minutes.
Step 8: Drain
When the timer goes off turn off the stove. Drain the water out of your pasta over the sink and put your noodles in a separate bowl.
Step 9: Add Your Butter
Once your pasta is completely drained, put your pasta in a separate bowl. Add the amount of butter you want to add. (I normally add about one tbsp, but you can add however much you want). Mix around your butter with your pasta until it is completely melted.
Step 10: Add Your Cheese
Add your cheese to your pasta. Personally, I am a big fan of cheese and add a lot of parmesan cheese. You can add any type and amount of cheese you prefer.
Step 11: Enjoy!
Congrats! You've successfully made amazing pasta. Hope you enjoy!
