Quick Firestarter
Intro: Quick Firestarter
This is a very simple firestarter made out of old candles, some dixie cups, and toilet paper rolls.
STEP 1: Melting the Wax
This should be self explanatory. you melt the wax and fill up the little paper cup. leave about 1cm of space between top and wax.
STEP 2: Filling the Roll
Take a spoon or a tool similar to this and dig some wax out of the cup. Fold the end of the roll down and plop a spoonful of hardened wax into the roll.
STEP 3: Making the Fire
After you have folded both of the ends down so you cant see the wax, go get some wood. A good variaty of small and big chuncks are best.
STEP 4: FIRE
Lay a piece of bark down on your grate and build a little log cabin over it. light both ends of the roll and carefully put it into the little house. and enjoy your fire!
Tips. if you put the smaller ones on the fire will start faster (duh)
make a little roof over the starter so the wood will catch. it wouldnt do anything if the flame just shot out the top. be sure to leave a "chimney" so that the smoke can escape.
scale of 1-10 10 being best, how helpful was this?
21 Comments
sparkster1 14 years ago
MattandJora 13 years ago
trike road poet 14 years ago
To use, open the box pull the two 'wicks' up and light. The improvised 'candle' lights and the large flame is easy to start the fire with. I use a heavy stick or log fragment on each side of the box and pile the kindling over the candle. As the flame ignite the small stuff, add the heavier stuff in a log cabin structure over the burning kindling. One very important point, use a small narrow stick to keep air passages open as the fire starts to keep the flames fed with air as the wood pieces come to ignition temps.
Phil B 15 years ago
MattandJora 15 years ago
mojobo1 14 years ago
This is more portable, but I like newspaper. (Wood stove is my only heat source.. Start a fire in it every morning)
Also, I think letting the wax drip onto the wood helps. Think of a candle.. The wick is IN the wax so it burns a lot longer. If the cardboard burns up and theres still wax, there will just be a big puddle of melted wax.
Wax doesnt burn easy by itself (has to be really hot), but if its on something else like wood/wick/string/etc, it burns better.
sharlston 15 years ago
cx420ns 15 years ago
mynameisjonas 15 years ago
tech-king 15 years ago
Phil B 15 years ago
knexsuperbuilderfreak 15 years ago
imshanedulong 15 years ago
tyty100 14 years ago
EmmettO 15 years ago
bylerfamily 15 years ago
For this one the fire can get started in about 15 minutes depending on how you set your logs up. If you have two biggish logs on either side of the bark horizontally then some smaller ones vertical on top of it, it goes faster.
maruawe 15 years ago
