Introduction: Quick Way to Make a Rose Brooch From Fabric Scraps
Never discard fabric scraps, even if they are very small and produce fraying when cut. You can use them to make a great rose brooch.
For this project I used scraps of a double-sided jacquard fabric that were left over from my project Reversible Japanese Knot Bag https://www.instructables.com/Reversible-Japanese-.... Jacquard fabric is a type of cloth featuring an intricate pattern woven into the warp. Almost all woven fabrics will produce fraying when cut. To solve this problem, I decided to use instant glue. When this glue dries, it hardens the fabric, which not only stops the fraying, but also fixes the bend imparted to the fabric. This property is perfect not only for fixing the threads very quickly at the edges, but also for shaping the curved rose petals.
double-sided fabric scraps
cardboard
scissors
a plastic file
instant glue
a toothpick
hot glue stick and hot glue gun
pen/felt-tip
pen brooch pin/safety pin
Step 1: Templates
Make cardboard petal templates. The digits (4, 5, 6, and 6) on each template indicates how many fabric petals you need to make using the template.
Step 2: Cutting Our Fabric Petals
Place the template on the fabric as tightly as possible (no allowances) and trace the outline.
Cut out the required number of petals from the fabric scraps.
Step 3: Shaping the Petals Using Instant Glue
Place one of the small petals on a plastic file and dab the fabric with instant glue. Wait a few seconds. When the fabric starts to harden, bend the fabric petal around the toothpick, giving the petal a shape. The glue will no longer stick to your fingers. Do not miss this moment, otherwise, when the fabric is completely hardened, it will be very difficult to shape the petals.
Bend all the other petals in the same way as in the previous step. For large petals, bend the edges at the top as well.
Step 4: Forming the Rose
Now you will glue the petals together using hot glue. Glue the smallest petals together first. Then glue the larger petals, spreading them evenly around the sides. Glue the largest petals at the very end. To make the rose bloom while gluing the petals, hold them for a couple of minutes at an angle.
Step 5: Adding the Pin
Cut a small circle out of the fabric. Glue the pin on the back of the fabric rose, pressing a circle of fabric on the outside. Wait a little for the hot glue to harden well.
Step 6: Enjoy the Work Done
If necessary, trim the edges of the petals. Your fabric rose brooch is ready.
