Introduction: Quick and Easy Crochet Crinkle Hat
Textured Crochet Patterns are great for adding a rich look to any crochet project. Among all the Crochet Projects and Patterns, Crochet Hats and Beanies are the most easy and fun to make. Crocheted hats are the most versatile projects to make. You can work with a combination of the Basic Crochet stitches and you can end up with a lovely textured look.
Today am sharing the pattern for Quick and Easy Crochet Crinkle Hat. I made this as a Part Of The 2025 Scarf & Hat of the Month CAL along with Rhondda from Oombawka Design Crochet and Amy from The Stitchin’ Mommy.
The Crinkle Hat Pattern is made with the basic crochet stitches. This is a quick working pattern. The pattern is made by crocheting a rectangle and the sides and the top are sewed up to make a easy hat.
Visit https://rajiscrafthobby.blogspot.com/2025/07/quick-and-easy-crochet-crinkle-hat-part.html
8 Ply Cotton Yarn - 1 Skein
5mm Crochet hook
Step 1:
Here is the Video Tutorial:-
You can follow along with this tutorial video. Please be sure to subscribe too!
Step 2:
Round 1:-
Start with a Slip Knot.
Chain 40.
This measures around 38 inches.
You can adjust the size altering these stitches according to your requirement.
Start with any Multiple of 2.
Step 3:
Round 2:-
1 Double Crochet in the 2nd Chain from the hook.
1 Double Crochet each in the remaining stitches.
Once you reach end, Chain 1 and turn your work.
Step 4:
Round 3:-
1 Single Crochet in the 1st stitch.
1 Slip Stitch in the next St.
1 Half Double Crochet.
Repeat(1SL,1HDC)
1 Single Crochet in the last stitch.
Once you reach end, Chain 2 and use the Straight Edge Turning Chain method to make the turning chain.
Straight Edge Turning Chain:-
Usually you would Chain 2, turn and start working the next round. Here is a quick tip to have a nice straight edge .
- Insert the hook into the 1st chain from the bottom.
- Yarn over and pull up a loop. You should have 2 loops on the hook.
- Turn your project and insert the hook into the first stitch.
- Yarn over and pull up a loop. You will have 3 loops on the hook.
- Again, yarn over and pull through 2 loops. You will have 2 loops on the hook.
- Lastly, yarn over and pull through 2 loops.
- This will make one Double Crochet.
Step 5:
Round 4:-
1 Back Loop Double Crochet in each of the stitches.
Step 6:
Round 5 Onwards:-
Keep Repeating Round 3 and Round 4 untill its around 17 to 18 inches in size or untill the the size needed .
Step 7:
Joining:-
Lay the Hat so that the textured side is facing up and the Plain side is on the Back.
Fold your work in half so that the plain side in now facing up and the textured side is inside.
Join both the ends with 1 Slip Stitch in each of the stitches Be sure to align the stitches in line with each other .
Leave a long tail and weave off.
Step 8:
Top of the Hat:-
Using a yarn needle, make running stitches on top of the hat.
Pull the yarn end to close the opening.
If required, make few more stitches on the top to make it secure.
Turn the Hat inside out and weave off the extra yarn ends.
