Nerf Sniper Rifle(Tri-Strike)
Intro: Nerf Sniper Rifle(Tri-Strike)
So in this project, I will show you how to convert a Nerf tri strike into a sniper rifle.
STEP 1: Tri Pod
So for this step, you will need one approximately 1 foot long piece of pvc pipe and a Y connector.
First cut the pipe into two 10 cm pieces and one 7 cm piece.
Then fit the three pieces into the connector. Before using pvc cement always dry fit the parts to see if they fit. The tripod should look like this:
(This step is optional) Now, to create a more professional look, you can spray paint the tripod black or camo like I did.
STEP 2: Blaster
This is the easiest step. All you have to do is fit the barrel into the barrel attachment point, and put the stock in the back attachment point. If you want, you can even add a scope to the tactical rail up top. (As a bonus, you might want to upgrade the spring to a 5 or a 7kg spring for better power.)
STEP 3: Scope(If You Don't Have One)
If you don't have a sniper rifle scope, then you can make one out of a toilet paper roll and a couple of lenses.
First, cut the toilet paper roll to the desired length.
Then cut two slots on the roll, and insert your lenses.
Cover up the two slots with tape
Paint(optional, but it looks cool)
Hot glue a tactical rail attachment
Slap it onto your sniper rifle!
STEP 4: All Done!
Your sniper rifle is all done! use glue-tac or double sided tape to attach your tripod to the base of your rifle and snipe your next target from behind concealment!
