Quickie: Wobbly Fan Repair
Intro: Quickie: Wobbly Fan Repair
Honestly, this is a five minute job.
I spent the weekend watching a fan that looked almost ready to fall from the ceiling. Rather than calling an electrician, I asked around at work, and got some quick tips for fixing it myself.
It took about five minutes to find the root cause of the problem, and sort it out. Thanks to the great guys at Electrician To The Rescue for the tips.
All you need is a screwdriver, some pliers, and a step ladder.
STEP 1: Check the Drop Rod
This is the main step in the repair. The rest is turning screws.
Most ceiling fans hang from a drop rod. The ball joint should be properly engaged to your support bracket. This is held in place with a cotter pin that runs through the rod and into the mount. If the pin is damaged, or bent, you're going to get a wobble.
With pliers and a new pin, you can fix this one pretty easily - all mechanics, no electrical work involved.
STEP 2: Repair Uneven Blades
If your fan has had an impact, pretty much ever - whether it's with a hand raised a bit too far, a stray tennis ball, or a startled (and probably somewhat confused) small mammal - you're going to see some damage.
This was, it turns out, the problem with my own fan. I have a vague memory of hitting my head with the blades, and it seemed my skull did a bit of damage to the equilibrium.
The blades should hang equidistant from the ceiling. If they're not, if they're warped or bent, you need to replace them. These can be bought online for a pretty good price. Hey, if you're lucky, the manufacturer might even replace them for free! If you're me, you end up paying ~$50-$100 AUD.
It's pretty easy. Turn off the power to the fan, unscrew each blade in turn. Replace with the new blades. The thin end goes in the bracket; and then, screw in place (or, bolt, depending on the mount).
Turn the power back on once you're satisfied everything's secure, and test.
I had no more wobble after this - but I did have to tighten the screws a second time. Mostly because I'm paranoid.
If you're struggling with this, it's not worth messing around - call an electrician.
STEP 3: Tighten Everything
If there's a screw, nut, or bolt, make sure it's tight.
The support bracket should be secured to the fitting very tightly. If it's not, you're in for a wobbly time.
6 Comments
MartyK1 7 years ago
Good points. As a former electrician, 3 things I always check when installing or repairing fans:
1. Blade distance from ceiling.
2. Angle of blades, relative to ceiling.
3. Radial symmetry. This one seems to cause the most wobble. The blades all need to be the same distance apart.
I usually cut a piece of cardboard to use as a gauge for the angle and distance from ceiling, and another piece to use to check the angles between blades for radial symmetry.
jackal1455 7 years ago
Fans will also wobble if the blades have been pushed to different heights. They should be at the same height. Don't clean fans with a broom.
Kids: get your parents to try this. Don't do it yourself.
Turn the fan off before checking the blade heights or trying to bend the blade supports. Push a ruler, a book or a drink bottle against the ceiling and rotate the fan by hand to check the height of each blade.
Check heights of all blades before turning the fan on.
nehmo 7 years ago
There's nothing about balancing imbalanced blades.
Mary EP 7 years ago
After checking tightness and it still wobbles, try taping a penny or two at different places to see what works,
Suraj Bhawal 7 years ago
DIY Hacks and How Tos 7 years ago
Nice tip. I will try this with my fan.
