Introduction: Quote Slides - PowerPoint Designs and Skills
Don't waste your time making boring presentations😫! If you are quoting someone, quote it professionally. Follow these steps to make your quote slides unique and professional with your PowerPoint skills😍.
- Microsoft PowerPoint
- A persistent and determined personality
Step 1: Rectangle
Insert a rectangle from the Shapes icon.
Step 2: Triangle
1) Insert a Triangle from the Shapes icon
Step 3: Triangle Rotate
1) Rotate the triangle 90 degrees counterclockwise.
2) Change the color, by right clicking the shape and selecting the Fill icon (Shape Fill).
Step 4: Merge Shapes
1) Select both shapes ***Select it entirely (from corner to edge). You can see whether it has been selected when it has white circles on the border of the shape***
2) Search merge shapes in the search bar above.
3) Select Combine.
Step 5: Shape Format
1) Go to the Shape Format menu
2) Select No Outline
3) Select a desired color (optional).
Step 6: Image
1) Paste an image onto the slide
2) Increase the size of the image
Step 7: Send to Back
1) Right click
2) Select Send to Back
Step 8: Quote
1) Type the quote in a text box
Step 9: Effects
1) Go to the Animation menu
2) Select Grow/Shrink after scrolling down
3) Select With Previous from the Start drop down menu
Step 10: Animation
1) Select Animation Pane
2) Select Effect options after clicking the picture number in the Animation Pane
Step 11: Effect Settings
1) Customize the size to 120%
2) Make the both the smooth start and smooth end 1 sec.
Step 12: DONE!!!
Look at your beautiful PowerPoint design and animation!!!
Download my example to see how it should turn out.
