Introduction: R2-D2 Astromech From Cardboard
I wanted to build R2-D2 for my son's birthday party but didn't want to spend two years and $10,000 so I went with a non-moving (for now) cardboard version. The whole project took about a month ( just a few hours a night as I have a full time job) and probably cost about $50 since I had most of the materials.
Step 1: Research and Planning
The first thing I did was research. I found a list of R2-D2's measurements online. Throughout this project I referred to my interactive Artoo , taking measurements and scaling them to full size. All I needed was the dome size ( approximately 18") and everything else was scaled around that.
Step 2: The Dome
This was the hardest part. I cut several 18" circles from corrugated cardboard and cut them in half. I used them as formers for the dome glueing them to another 18" circle with hot glue. My glues of choice for all projects are hot glue and The Ultimate white glue. Next I cut tapered strips and glued IMG_6912.JPGthem along the edges to make a semi globe. I then apply a layer of spackle to the entire dome. I allowed it to dry and sanded it and repeated this process until I had a smooth dome.
Step 3: The Structure
I made the legs from wooden 2x4s so they would be strong enough to hold the body and give it some weight. The body was two cardboard circles glued together with a series of 1" thick foam core strips.
Step 4: The Legs
The legs were made with foam core and mat board over the wooden leg base.
Step 5: The Skin
I Wrapped a sheet of mat board around the cylinder. I then drew the compartments on another sheet of mat board and cut them out (saving the cut-outs and shaving off thin strips). Next I glued the cut-out layer to the cylinder and then glued all the compartment cut-outs. The round detail in the bottom center was made with a plastic solo cup and some mat board pieces.
Step 6: The Dome Details
I drew the dome details with a pencil and then traced them with a nail to etch the details into the dome.
Step 7: The Details
I cut the vents out of mat board. I made the leg details from gift wrap tubes. Additional leg details include some paint lids and a highlighter marker split down the middle with a hacksaw. The sensor eye was made from a plastic convex mirror I found in the automotive dept at Walmart. I colored it with a black Sharpie marker which worked very well. I painted some airline tubing gold and attached it to a painted marker cap and glued it to each foot.
Step 8: The Holoprojector
I made these with plastic containers found in a vending machine and mat board. For the one on the front of the dome I inserted a small flashlight I bought at the dollar store.
Step 9: Painting
I sprayed the dome silver and brush painted the dome compartments. I sprayed the body white and then did a wash with dirty black paint water so he didn't look so brand new.
Step 10: Finishing Touches
Finally I punched a circle from a piece of red reflective tape and stuck it on the dome. I also put a yellow on on the back side of the dome. I cut a hole in the dome and inserted the flashlight and Holoprojector . I put a rod in the center of the dome so it can be manually rotated. At some point I hope to mechanize the dome and build the third leg so he is truly finished but he looks pretty good for now. Just have to make sure the Jawas keep their hands off of him.
1 Person Made This Project!
- frehleycooper made it!
98 Comments
5 months ago
I love this. I love making things from cardboard so I might use this in the droid I'm making right now!
1 year ago
please describe what board is you used how thick is it
2 years ago
I found this R2 D2 instructable months ago and it inspired me to go ahead and make my own Droid. I recently shot to make my own R2D2 but as soon as I started the project, I came to the conclusion that it's best that I just make a Star Wars theme Droid as a practice run. And see how that turns out. If it turned out well then I shoot for an R2 D2 Droid. So I'm leaving this comment and giving credit to this post that inspired me to create my own Droid. Thank you.
2 years ago
I'm interested in trying this one out, but as a storage cabinet for my Digital Education classroom, which means modifying the visual appearance a bit, due to wanting to have a large front door on the body, but I think that with all the existing detail most people probably won't notice the changes. For the dome I have a BBC Micro:Bit kit that includes an electric motor, should be quite easy to use it following any of a number of projects already online to animate the dome. One thing this project is missing, which is really cheap yet would make a massive difference, is the use of Christmas tree LEDs to animate the light panels in the dome. I'll keep you posted if I go ahead with this.
2 years ago
I am about to attempt this build using your posts as guides! Thanks for this, you are a genius! I'll come back and post my progress!
4 years ago
I began the droid, using foam core board for the body. however, it is a bit flimsy.
4 years ago
For those who want to know how tall the body is;
The body is 18" in diameter, and thankfully I did the math (I have the scale Sphero R2-D2). I figured out the body across is 2.5" in diameter, so I divided 18/2.5 and got 7.2, so the little under 3" high sphero R2-D2 multiplied by 7.2 is... (drumroll please) 21.6" tall. so what I would do (what I AM doing) is just doing 21.5" rather than doing the hard work... thank me later
Reply 4 years ago
(a thank now would also work)
Reply 4 years ago
(please?)
5 years ago
How tall is the body? And how have you done its lower part?
Reply 4 years ago
4 years ago
i´m not such a big star wars fan but wow this is really amazing!
all the detalis and the painting, great job!
i would like to make a trashcan that looks like this for my sister ^^
Reply 4 years ago
A trashcan?
Actually yeah, use a big trash can. you really should. It's a common, yet great idea
5 years ago
Fantastic - I love it!
5 years ago
You should sell thses...I would buy one...
Reply 5 years ago
I would sell one for the right price. The problem is that shipping would probably be very expensive. Not to mention this took about a month of my spare time to build.
5 years ago
I would love to buy one, i will pay for shipping and material. No paint needed. Although i would pay extra for a paint job
Reply 5 years ago
6 years ago
I suggest you look up how to use an Ardunio. It should be able to do your dome spin, roll R2D2 with a remote, and make all the sounds. With a little work, this could make an awesome photo booth!
Reply 6 years ago
I've been hearing that name a lot lately. I will check that out. Electronics are not one of my strengths but I do want to learn. Thanks.
