RAM Module Key Fob
Intro: RAM Module Key Fob
In this instructable, I will show you how to, in less than twenty minutes, make a key fob out of an old RAM module. A key fob is one of those thingys that you get on a rental car saying the car model, make, name, plate number, etc.
This instructable is an entry for the pocket sized contest, so you know what to do if you like it(or even if you don't like it, you can proceed as if you had liked it).
This is also my very first instructable and would like some feedback on it. (Thanks)
DISCLAIMER:
Your safety is YOUR priority. use caution when handling sharp objects.
DISCLAIMER:
STEP 1: Your Supplies and Tools
Supplies & Tools:
Supplies:
An old piece of Random Access Memory
A keyring(preferably unused, but a used one is ok)
Tools:
Cutting Mat
Hobby Knife
Sandpaper 100 Grit*(a small patch is fine)(not shown in picture)
Drill wit a 1/8" bit(not always needed)
*Grit: the number of grains of sand in one square inch of paper(approx.). This means that the higher the number printed on the back of your piece of sandpaper, the finer the grains of sand will be.
Supplies:
Tools:
Cutting Mat
Hobby Knife
STEP 2: Preparation
In the following step I will show how to set up your workspace so as to be the most efficient possible.
To set up your workspace, you should consider the following:
How close do you want the sharp blade of the knife to our arm when not using it.
And how much elbow room you want to allot yourself.
Here is how I set my workspace up...
the knives on the side away from where my elbow will hit them and get cut(ouchyy!),
the ring that wont come in until later up and out of the way,
the sandpaper back and center so its easy to get at when I am ready to use it
STEP 3: Scoring and Preping the Module
The first step is to score the RAM module with the hobby knife so the cutting process is much easier.
Shown in the picture is the score line(which goes all the way around the module), and helps keep your cutting in line.
(you can see the score line in the side of the module in the light of the laser pointer...)
STEP 4: Cutting
Continue to cut the module until the module is half its original thickness.
Slide the Hobby Knife both ways(it goes faster by scraping and clearing the particles that you are removing).
STEP 5: Separation
Separate/break the intended section of the module off from the rest of the module.
You may now set the unwanted section aside for further uses...
Once the board, that the little black thingys are mounted on, is thin enough, it should snap easily in your fingers. The result of the snap is shown in the pictures below.
STEP 6: Sanding
Sand all the edges of the wanted piece of RAM module. Yes ALL of them(you don't want them making holes in your pocket now, do you?) until they are nicely rounded(not sharp).
Yes even those little notches in in the side that hold the module in to your computer...
STEP 7: Affixing the Key Ring
Now we get to affix the keyring to the ram module.
Inspect your piece of RAM for a small hole in a corner.
Put your keyring through the hole in the corner...
If you find none(which should be determinable very quickly(there are after all only four corners to check)) it is now time to go find the drill and 1/8" bit...{go hunting now if applicable}.
Otherwise proceed to step eight.
I went on to step eight because my module came with a hole pre-drilled into it.
STEP 8: You're Almost DONE
You're almost done now...
Attach the wanted set of keys to the ring...
YOU'RE DONE!!!!!
As this is an entry for the pocket contest, please rate... ;-)
YOU'RE DONE!!!!!
24 Comments
eggplanthunter 14 years ago
santy22 14 years ago
zack247 13 years ago
ndinitz 13 years ago
brunoip 14 years ago
ndinitz 14 years ago
dante900 14 years ago
p0g068 14 years ago
shadleyhax 14 years ago
jetsmiley123 14 years ago
ReCreate 14 years ago
SinAmos 14 years ago
Marble of Doom 14 years ago
Junk_Wizard 14 years ago
r21187 14 years ago
mbudde 14 years ago
mbudde 14 years ago
r21187 14 years ago
randofo 14 years ago
