Introduction: RBG Alpha Sniper Repeater
This is the same model type from the Alpha repeater but it is stronger, more accurate, and better scoped also it fires so fast you cant see the rubber band until it touches the ground it is a semi automatic assault sniper (Works best with BLUE rubber bands.)
Step 1: Beginning the Process
To start building this model go to https://www.instructables.com/id/EAN8MTM5A2EV2Z8SGD/
Step 2: Getting the Difference
To make the butt,Grenade,handle,bipod,and scope go to https://www.instructables.com/id/E62O5RMF54HJ7EO/
Step 3: Rebuilding the New and Improved Scope
Replace the 3-inch rods on the scope with 5-inch rods
Step 4: Extending the Barrel
first remove the center part of the barrel then replace it with two 3-inch rod barrel parts (look at the green rods and try to copy it) that is how specific i can get then take 3 1 1/2 inch rods and stick one through the hole in each part of the barrel then put semi circle pieces and attach them to the rods on both sides then combine the semicircles with 3-inch rods on both sides
Step 5: Rebuilding the Amazing Handle
First remove the old handle then attach 2 semicircles on one side of the barrel make sure their at least 3 inches away, do the same thing with the other side then attach a 1-inch rod to each semicircle facing inward of the barrel then attach a circular piece to the 1 inch rods to combine the rods then take 5 5-inch rods and attach them in the bottom part of the circular pieces which should put the two circular pieces together
Step 6: FINISHED!!!!!!!!!!!!!!!!!!!!!!!!!!!
You finaly finished the sniper congrads to see more creations by me visit my webpage of ERIKTHEGREEN!
