Introduction: RC Compartment
For this project you will need
1 small Philips screw driver
1 rc car controller
1 cutting tool preferably pliers
super glue
1 rc car controller
super glue
Step 1: Disassemble All Parts
Remove all of the screws and open up the case remove screws from circuit board and cut wires from battery, also take out battery.
Step 2: Rebuild
Take the cover that was on the back for the battery cover and click it back into place, then put the screw in on the inside of controller so where the screw head was initially is now just threads, next screw the circuit board back on to the support pegs and then cut out the top left corner so that you can access the bat-box screw easily.
Step 3: Finial Step
Now simply replace the lid to the container and put 2 screws into the back, the rest is optional, you can replace the remaining two screws and the antenna but that will make it harder to open so i just put a dab of super glue on them and the antenna and slid it into place that way you will only need to unscrew 3 screws total, this should enable you to store small memory cards money and anything else that is small. Hope you like the project and vote for me!
