Introduction: RECONDITION CONTROL CNC ACRAMATIC 2100
About: DESING AND MANUFACTURING SOFTWARE AUTOCAD,MASTERCAM,INVENTOR PROFESIONAL,RHINOCEROS, FUSION 360, REVIT, CNC, MAQUINAS HERRAMIENTAS, REPAIR CNC CINCINNATI Y FAGOR :p
MAS INFO
CADCAMCNC.WEEBLY.COM :p
Step 1: DISMANTLING THE UNIT
TO START THE RE-CONDITIONING OF THE DISARMAMENT CONTROL UNIT EVERYTHING AND MAY PERFORM AN EXTERNAL INSPECTION OF EACH OF THE UNITS AND PLATES
PARA COMENZAR EL REACONDICIONAMIENTO DE LA UNIDAD DE CONTROL DE DESARMARA TODO Y SE POCEDERA A REALIZAR UNA INSPECCION EXTERNA DE CADA UNA DE LAS UNIDADES Y PLACAS
Step 2: CHECKING AND INSPECTING CARDS
THE STARJETAS THAT DO NOT WORK WILL BE VERIFIED TO REPLACE IT OR ONLY THE CMOS WILL BE UPDATED SO THAT IT MAY BE REUSE
SE VERIFICARAN LA STARJETAS QUE NO FUNCIONEN PARA PODER REMPLAZARLA O SOLO SE ACTUALIZARA EL CMOS PARA QUE SE PUEDAN REUTILIZAR
Step 3: CARD RECONFIGURATION
THE CARDS WILL BE REPAIRED AND THE BIOS WILL BE CHARGED TO BE USED NOT TO BUY A NEW
SE REPARARAN LAS TARJETAS Y SE CARGARA EL BIOS PARA PODER UTILIZARLA NO COMPRAR UNA NUEVA
Step 4: CARD IS DAMAGED BY a NEW CARD TO RUN THE CONTROL
SE SUSTITUYE LA TARJETA DAÑADA POR UNA NUEVA PARA PONER A FUNCIONAR EL CONTROL
CARD IS DAMAGED BY A NEW CARD TO RUN THE CONTROL
Step 5: REPAIR AND REPLACEMENT OF ACRAMATIC 2100 CONTROL
REPARACION Y REACONDICIONAMIENTO DE CONTROL ACRAMATIC 2100
EN EL VIDEO SE MIRA TODO EL PROCESO :p
