Introduction: REMINDER BOXY
THIS ISN"T A NORMAL BOX.
Step 1: Introduction:
This is not a normal box. REMINDER BOXY is a box that can remind you when your things is too many, it’s time for cleaning. There are 2 different sound and distance: The first sound shows up when things are 10cm long to the top, with a beep for every 1 second. The second sound shows up when things are 5cm long to the top, with two different sound for every 0.5 second.
Step 2: LIST OF THE MATERIAL:
STEP 2.1 Arduino:
- Arduino board (suggest: Arduino Leonardo, but Arduino UNO is fine)
- Breadboard
- Speaker
- Ultrasonic sensor (suggest: HC-SR04)
- LCD board (12C)
- Power bank and USB
- Jumper wires (12 are enough)
STEP 2.2 Box:
- Empty box
- Painting tools (decorate the box)
- Paper board (to make a cover for arduino)
- Box cutter
Step 3: HOW TO MAKE IT/ Arduino:
Step 4: HOW TO MAKE IT/ Box:
1. Find a empty box, decorate it if you want.
2. Use box cutter to cut the hole for ultrasonic sensor on the top of the box (* make sure the position is accurate)
3: Cut a whole for ultrasonic sensor’s jumper wire on the side of the box (* a small whole is okay)
Step 5: Box COVER:
4. Put the arduino board inside the box
5. Use paper board to make a small cover for the arduino board
6. Cut a whole on the side of the paper board (* make sure jumper wires can go through it)
7. Combine the cover and arduino board (* make sure you cover arduino)
Step 6: FINAL STEP of the Box:
8. Use power bank and USB to connect arduino
9. Finish! Now you can put things! (* the cover can also put things on it)
Step 7: CODE:
<p>#include <Wire.h><br>#include <LiquidCrystal_I2C.h> #define trigPin 10 #define echoPin 12 LiquidCrystal_I2C lcd_I2C_27(0x27,16,2); void setup() { pinMode(trigPin, OUTPUT); pinMode(echoPin, INPUT); } void loop() { float duration, distance; digitalWrite(trigPin, LOW); delayMicroseconds(2); digitalWrite(trigPin, HIGH); delayMicroseconds(10); digitalWrite(trigPin, LOW); duration = pulseIn(echoPin, HIGH); distance = (duration / 2) * 0.0344; if (distance >= 400 || distance <= 2){ lcd_I2C_27.print("Out of range"); delay(250); } if (distance <= 5){ //5cm distance, will shows up 2 different sound for every 0.5 sec tone(13, 800.0, 100.0); delay (50); tone(13, 650.0, 100.0); delay (50); tone(13, 500.0, 100.0); delay (50); }else if(distance <= 10){ //10cm distance, will shows up a beep for every 1 sec
tone(13, 330.0, 100.0); delay (1000); } else { lcd_I2C_27.print(distance); lcd_I2C_27.print(" cm"); delay(250); } delay(250); lcd_I2C_27.clear(); }</p>
Step 8: TEST IT!
![IoT Challenge](https://content.instructables.com/FAT/WM2Z/JVAT0WI7/FATWM2ZJVAT0WI7.jpg?auto=webp&frame=1&width=320)
IoT Challenge
