Introduction: REV Robotics Duel Motor Transmission Tank (Fenduke MK.1)
This is the first robotics project myself and my friend Liam. We tasked ourselves with creating a tracked tank to enter this competition to fund our school robotics team, the Springbank Robotics Team at SCHS. Our vision for this project was to create a bot that both functions well and drives at a moderate speed. We have named our Tank The Fenduke Mk.1
REV Robotics
15mm Metal Motion Brackets - 1x Pieces
15mm Extrusion - 420mm - 90° Ends - 2x Pieces
15mm Extrusion - 150mm - 45° Ends - 4x Pieces
15mm Metal Brackets - 4x Pieces
15mm Plastic Brackets - 4x Pieces
15mm Plastic Inside Corner Bracket - 4x Pieces
REV Robotics Control Hub - 1x Pieces
5mm Hex Shafts (400mm) - 3x Pieces
Locking Motion Hub - 2x Pieces
GoBilda
5203 Series Yellow Jacket Planetary Gear Motor - 2x Pieces
2920 Series Steel Set-Screw Collar (6mm Bore) - 18x Pieces
Studica
Motor Mount Clamp Kit - 2x Pieces
Pitsco & Tetrix
MAX Tank Tread Chain Links - 208x Pieces
MAX 11 mm Bronze Bushing - 12x Pieces
MAX Tank Tread Sprocket - 2x Pieces
MAX Tank Tread Idler Wheel - 6x Pieces
Amazon
Battery adapter for Makita (Custom Power Connector) 18v Battery - 1x Pieces
Makita 18v Battery - 1x Pieces
Logitech F310 Wired gamepad - 1x Pieces
Custom Parts
15mm Extrusion (Custom) - 203.5mm - 90° Ends - 2x Pieces
15mm Extrusion (Custom) - 135mm - 90° Ends - 3x Pieces
Wood Platform 230mm x 165mm - 1x Pieces
Step 1: Assemble the Frame
Step 2: Assemble and Add the Bottom Idler Wheels
Step 3: Assemble the Top Idler Wheel
Step 4: Attach the Battery Station
Step 5: Attach the Control Hub
Step 6: Attach the Motors
Step 7: Fit and Attach the Tracks
Step 8: Build Code and Transfer OpMode
The .blk file is downloadable via this Google drive
