RF Transmitter and Receiver
Intro: RF Transmitter and Receiver
In this project, I will use RF modules with Pic 16f628a. It will be a short tutorial about rf. After you learn ho rf modules communicate with each other you can use these modules with pic microcontroller, ardunio or any microcontroller. I controlled RGB LEDs but If you can control many thing motors or relays.
STEP 1: Short RF Lesson
What is RF?
In short term, radio frequency (RF) refers to the rate of oscillation of electromagnetic radio waves in the range of 3 kHz to 300 GHz, as well as the alternating currents carrying the radio signals.
How does it work?
We need two modules which are transmitter and receiver. Our control our data 1 and 0(we use the microcontroller in this project) and transmitter send these data in Seri way in radio waves. After ıt started broadcasting, receiver collect these radio waves and it gives as 1 and 0 again.
Why do we use it?
If we want to communicate some devices without any wire we RF modules is one of the ways.
STEP 2: Circuit Schemas
In the first circuit is the transmitter second is receiver.I controlled 3 RGB led by this modules.
STEP 3: Component List
Transmitter Part:
- pic16f628a
- 18pin dip socket
- 1n4001 diode
- lm7805
- 220 uf 16v electrolytic cap
- 1 uf cap
- 330ohm ^1
- 4.7k ohm ^1
Rf transmitter (433 MHZ)
- 10k ohm ^4
- 4 push button
- 5mm led
- male header
Receiver Part:
First eight is the same
9.RF receiver (433 MHZ)
10. 5mm RGB led ^3
11.led
12male header
Note:RF modules must be same frequency.
Rf modules link of rf modules
STEP 4: Printed Circuit Board
I love using PCB instead of prototype PCB(including many holes), In my opinion, this way is more healthy for circuits. After designing the circuits I printed on the boards but there are some tiny nets so I needed to fix some nets. After fixing operations they go to in acid. Then they are ready for next step.
STEP 5: Solder Mask !
Its optional part.
Solder mark has some difficulties but otherwise, it has some benefits.Your PCB can be healthy very long time and short circuit risks become increases.You can find many resources about how can you make solder mask at home.After the solder mask operations, PCB's go drilling operations.
STEP 6: Soldering
At last, we soldering the components on PCB. My advice you should solder dip socket first but attach the pics and rf modules after soldering. You should be very careful about short circuits. Besides, rf modules can be effected static electric very easily.
STEP 7: Codding
I used PIC CCS for programming. If you have any question about anything just ask it, please.
First, we choose the baudrate you should look that for rf modules datasheet then we define transmitter an receiver pins. Parity is about our data is odd or even but we don't use it in this project, at last, we choose 1 our stop bit.
Preamble Function:
If we try to use the same many RF modules in the same area it will be some provision. We prevent this problem with preamble function. We define an identification for our modules and sent it receiver module.
We can see this function on the oscilloscope.First two pic belong transmitter and second modules belong receiver circuit
STEP 8: RUN!
In this project main idea was RF communication thus I did not use qualification pic or oscillator. If you want to obtain better communication you should use high-frequency crystal oscillator and high-frequency RF modules. You should use an antenna.
56 Comments
cesarviloria2022 2 years ago
Prominent 2 years ago
Pls am planning a project whereby I want to make a wireless system that will transmit when a water detector detects water. I was thinking of using the knowledge of this transmitter and receiver with a water detector chip. Pls can I get help from you?
AlC70 5 years ago
Be aware that 433 MHz is within the LICENSED UHF amateur radio bands. I license is required to use these frequencies (420 - 450 MHz) at any power level. One of the national hobby shops was recently fined several million dollars for marketing drones that use these frequencies and don't warn consumers about the "non type accepted" products. There are exceptions, just be sure to check with your local authorities before transmitting on these frequencies.
eburman 5 years ago
Seriously? Get of your high horse! These units put out a minuscule signal. It's not enough to even make it outside the walls of my house. What value is there in your comment? You say "check with your local authorities." Which authorities? Are you able to provide so much as one legitimate example of someone who has been prosecuted by the FCC for using one of these units? Citations please.
steve.6250.00 2 years ago
JCFLindsay 5 years ago
I want to play with ham/SW radio reception. Can you recommend a place for beginners to learn, and how to purchase equipment?
JimG50 5 years ago
For info and books about Amateur Radio (Ham Radio) see ARRL.ORG. For equipment google ICOM, Yaesu, Kenwood or go on Ebay searching for amateur equipment. Or build your own. 73. JIm
DavidH1070 5 years ago
do you have a reference for these rules that a layman could reference?
e5frog 5 years ago
433MHz is a license free band in the EU for low effect (LPD433). In Sweden (possibly wider area, don't know) the allowed band is 433.050 - 434.790MHz and you often find them in cordless headphones, remote light/power switches etc
sanketmore164 4 years ago
IM TRYING TO MAKE THIS PROJECT,
BUT IT NOT WORKING
IM USING BOTH TRANSMITER AND RECEIVER CIRCUIT IN SAME BREADBOARD,AND SAME POWER SUPPLY,PLZ HELP ME WITH THIS,,,WHAT CAN I DO,
OEsirik 4 years ago
sml.bustos 4 years ago
But... There is not decode section of preamble in the "rf receiver.c"
NavodJ 5 years ago
mina_adel_85 5 years ago
OEsirik 5 years ago
MeanFacedP 5 years ago
OEsirik 5 years ago
