Introduction: RFID Bicycle Lock Prototype
Welcome to my RFID Bicycle Lock Concept tutorial,
I just got my RFID Chip from www.dangerousthings.com implanted in my arm and I thought about things to do with it.
The first thing I thought about was writing my will and organ donar data to the chip, so if I´m in a bicycle accident, the people could identify me. But this idea is kind of easy.
The other idea is some lock that could replace the big, bulky locks I carry around while cycling.
This concept is only the beginning of the development.
Step 1: Tools and Materials
Materials:
- 1" by 2" pinewood
- A scrap sheet of MDF, 3mm width
Tools:
- Bank drill
- Band saw
- Band sander
- Dremel motosaw
Electronics:
- RFID Reader RC522
- Arduino UNO
- 5 jumpers
- Buzzer
- Servo motor
Step 2: Cutting Out Rear Wheel Blocker
The idea of the rear wheel blocker is the same used in some old bicycles, like the one in the first picture.
I´m using wood as a prototype material, but in the future I´m planning to use aluminum.
- We take the scrap MDF sheet and draw a freehand "moon" shape that is 8-9 cm in diameter.
- Then we cut the sheet with the Dremel motosaw
Step 3: Attaching the Blocker to the Servo
The servo comes with a white plastic part with holes on it and 2 screws.
- We take the bank drill and drill to holes on the blocker.
- Then we take the 2 screws to adjust the blocker to the plastic part of the serve.
- With the blocker and the plastic part joined together, we can adjust it to the servomotor.
For further prototypes, we should think about how to fix the blocker to the servo permanently.
Step 4: Building the Servo Mount
The servo mount help us to fix the servo to the rear fork tube of the bike.
- We take the 1"x2" pine wood piece
- We draw a rectangle of 1.5 cm x 3cm on the front.
- On the side of the pinewood we draw a rectangle of 5cmx 3.5 cm.
The we cut with the band saw the rectangles and then we use the dremel so sand it down.
At the end we drill a 1 cm diameter hole in the side of the mount.
Step 5: Attach the Servo to the Servo Mount
- We take a small screw to fix the servo to the front of the pinewood.
Step 6: Fix the Mount in the Rear Fork Tube
Then we take the screw and the nut and adjust the servo motor mout to one of the tubes of the rear fork.
Step 7: Arduino Circuit
For the electronic part, I used the tutorial by Enrico S. (https://plus.google.com/+EnricoS/about) posted in german on this url: http://fluuux.de/2015/08/eine-tuer-mit-rfid-chip-o...
The steps for this part are:
- Connection of the rc522 RFID reader to the Arduino UNO
Arduino UNO | RFID-RC522
Pin 10-----------SDA
Pin 13 ----------- SCK
Pin 11-------------MOSI
Pin 12-------------MISO
- IRQ
GND---------------GND
Pin9-----------------RST
3.3V-----------------3.3V
- Connection of the servo and the buzzer
Arduino / Buzzer
Pin7 + (red)
GND - (Black)
Arduino / Servo
Pin8; Yellow Cable of the servo
3.3V + (red)
GND - (black)
- Upload the Arduino Sketch "RFID_Karte.ino" (see attachment above)
- Add "authorized" RFID Card Numbers to the system
This is pretty easy, you just upload the sketch and scan the card you want to register. In the terminal of the Arduino, you will read "[NICHT BERECHTIGT]", german for "not authorized", followed by the card number.
Copy that number and put it here:
// Hier die UUID fuer erlaubte Karten eingeben und in "erlaubteKartenCount"
// Anzahl der Eintraege angeben long erlaubteKarten[] = { 1011520, 2492530, "PUT THE NUMBER OF YOUR CARD HERE"}; byte erlaubteKartenCount = 3;
Step 8: Try It Out
Now take the RFID you registered changing the code and pass it through the reader, as you see on the video, the motor should open if the card is authorized.
For future prototypes:
- Comment in english the code from Enrico with some changes and adaptions
- Use an alternative reader: The RC522 reader hasn´t power enough to read our 125khx Dangerous Things Chip, so we need other chip.
- Totaly different materials for the lock: Of course MDF and wood it´s not optimal, I´m thinking about aluminum and other metals for the lock.
- Comment below what we should think about in later projects ;)
Bicycle Contest 2016
6 Comments
6 years ago
this is brilliant! The big problem is that the whole package is very big. if you could make everything smaller it would be amazing. I can help design the metal parts which come attached to the frame, make everything smaller and lightweight.
Reply 1 year ago
just use Arduino nano instead of uno
5 years ago
This works well but how did you make it close when you scanned a second time?
6 years ago
I think you have a great concept here. Personally i would use a 2 solenoid setup. one to move a pin in and out to lock the tire and another one to lock the pin into place. Easy place to source cheap strong solenoids is the junkyard. Get power locks off of cars. the rear hatch unlocking solenoid for large trucks/SUV's are strong and easy to remove.
6 years ago
Great idea! Not sure about the embedded RFID lol, but I love this! How about for strength purposes just using a solenoid of some sort?
https://encrypted-tbn0.gstatic.com/images?q=tbn:ANd9GcTeQ7a16k-D8Ur2a6KS6KASIb5xJqoFKUp8nyXFsioDtPR-Z1y4
6 years ago
