Introduction: RFID CARD READER WITH ARDUINO,RFID-RC522 and LCD 16x2
Radio-frequency identification (RFID) uses electromagnetic fields to automatically identify and track tags attached to objects. The tags contain electronically stored information. Passive tags collect energy from a nearby RFID reader's interrogating radio waves. Active tags have a local power source such as a battery and may operate at hundreds of meters from the RFID reader. Unlike a barcode, the tag need not be within the line of sight of the reader, so it may be embedded in the tracked object. RFID is one method for Automatic Identification and Data Capture (AIDC).
RFID tags are used in many industries, for example, an RFID tag attached to an automobile during production can be used to track its progress through the assembly line; RFID-tagged pharmaceuticals can be tracked through warehouses; and implanting RFID microchips in livestock and pets allows positive identification of animals.
Since RFID tags can be attached to cash, clothing, and possessions, or implanted in animals and people, the possibility of reading personally-linked information without consent has raised serious privacy concerns. These concerns resulted in standard specifications development addressing privacy and security issues. ISO/IEC 18000 and ISO/IEC 29167 use on-chip cryptography methods for un-traceability, tag and reader authentication, and over-the-air privacy. ISO/IEC 20248 specifies a digital signature data structure for RFID and barcodes providing data, source and read method authenticity. This work is done within ISO/IEC JTC 1/SC 31 Automatic identification and data capture techniques.
ARDUINO UNO: The Uno is a microcontroller board based on the ATmega328P. It has 14 digital input/output pins (of which 6 can be used as PWM outputs), 6 analog inputs, a 16 MHz quartz crystal, a USB connection, a power jack, an ICSP header and a reset button. It contains everything needed to support the microcontroller; simply connect it to a computer with a USB cable or power it with a AC-to-DC adapter or battery to get started. You can tinker with your UNO without worrying too much about doing something wrong, worst case scenario you can replace the chip for a few dollars and start over again.
"Uno" means one in Italian and was chosen to mark the release of Arduino Software (IDE) 1.0. The Uno board and version 1.0 of Arduino Software (IDE) were the reference versions of Arduino, now evolved to newer releases. The Uno board is the first in a series of USB Arduino boards, and the reference model for the Arduino platform; for an extensive list of current, past or outdated boards see the Arduino index of boards.
LCD 16 x 2: LCD (Liquid Crystal Display) screen is an electronic display module and find a wide range of applications. A 16x2 LCD display is very basic module and is very commonly used in various devices and circuits. These modules are preferred over seven segments and other multi segment LEDs. The reasons being: LCDs are economical; easily programmable; have no limitation of displaying special & even custom characters (unlike in seven segments), animations and so on.
A 16x2 LCD means it can display 16 characters per line and there are 2 such lines. In this LCD each character is displayed in 5x7 pixel matrix. This LCD has two registers, namely, Command and Data.
The command register stores the command instructions given to the LCD. A command is an instruction given to LCD to do a predefined task like initializing it, clearing its screen, setting the cursor position, controlling display etc. The data register stores the data to be displayed on the LCD. The data is the ASCII value of the character to be displayed on the LCD. Click to learn more about internal structure of a LCD.
RFID- RC522: There are cheap RFID modules that can read and write Mifare's tags and being sold at several web stores, like eBay and included with many "starter kits" nowadays. Simply search RFID-RC522 (MF-RC522). The microcontroller and card reader uses SPI for communication (chip supports I2C and UART protocols but not implemented on library) (Maybe someone implements?). The card reader and the tags communicate using a 13.56MHz electromagnetic field. (ISO 14443A standard tags)
Step 1: COMPONENTS:
- RFID RC-522
- ARDUINO UNO
- LED
- BUZZER
- JUMPPER WIRES
- BATTERY (9V WITH CAP)
- PLUG (5 x 2.1)
- LCD (16 x 2)
- ADDITIONAL CONNECTION PINS
- RISISTANCE (220 ohm) (x 2)
- VARIABLE RESISTOR (10 K)
Step 2: CIRCUIT DIAGRAM:
Step 3: CODE:
RFID CARD READER By nonstopengineering Using Arduino,RFID-RC522 and LCD 16x2 ------------------------------------------*/
#include <eeprom.h> //Library To read and write PICC's UIDs from/to EEPROM #include <spi.h> //Library RC522 Module uses SPI protocol #include <mfrc522.h> //Library RC522 Module #include <liquidcrystal.h> //Library for LCD Display</liquidcrystal.h></mfrc522.h></spi.h></eeprom.h>
boolean match = false; // initialize card match to false
boolean programMode = false; // initialize programming mode to false
int successRead; // Variable integer to keep if we have Successful Read from Reader
byte storedCard[4]; // Stores an ID read from EEPROM
byte readCard[4]; // Stores scanned ID read from RFID Module
byte masterCard[4]; // Stores master card's ID read from EEPROM
#define SS_PIN 10
#define RST_PIN 9
MFRC522 mfrc522(SS_PIN, RST_PIN); // Create MFRC522 instance.
LiquidCrystal lcd(7, 6, 5, 4, 3, 2); //Initializing LCD PINS as (RS,EN,D4,D5,D6,D7)
void setup() {
// put your setup code here, to run once:
Serial.begin(9600); // Initialize serial communications with PC
lcd.begin(16, 2); //Initializing LCD 16x2
pinMode(8, OUTPUT); //LED and Buzzer PIN OUT
SPI.begin(); // MFRC522 Hardware uses SPI protocol
mfrc522.PCD_Init(); // Initialize MFRC522 Hardware
mfrc522.PCD_SetAntennaGain(mfrc522.RxGain_max);
if (EEPROM.read(1) != 1) { // Look EEPROM if Master Card defined, EEPROM address 1 holds if defined
Serial.println("No Master Card Defined"); //When no Master Card in Your EEROM (Serial Display)
Serial.println("Scan A PICC to Define as Master Card");
lcd.clear();
lcd.setCursor(0, 0);
lcd.println("SET MASTERCARD "); //When no Master Card in Your EEROM (LCD Display)
lcd.setCursor(0, 1);
lcd.println("SCAN A PICC....."); //Scan any RFID CARD to set Your Master Card in Your EEROM (LCD Display)
delay(1500);
do {
successRead = getID(); // sets successRead to 1 when we get read from reader otherwise 0
while (!successRead); //the program will not go further while you not get a successful read
for ( int j = 0; j < 4; j++ ) { // Loop 4 times
EEPROM.write( 2 + j, readCard[j] ); // Write scanned PICC's UID to EEPROM, start from address 3
EEPROM.write(1, 1); //Write to EEPROM we defined Master Card.
Serial.println("Master Card Defined");
Serial.println("Master Card's UID");
for ( int i = 0; i < 4; i++ ) { // Read Master Card's UID from EEPROM
masterCard[i] = EEPROM.read(2 + i); // Write it to masterCard
Serial.print(masterCard[i], HEX); //Master Card only view in serial
Serial.println("Waiting PICCs to bo scanned :)");
//WAITING TO SCAN THE RFID CARDS:
Serial.println("");
lcd.clear();
lcd.println("WAITING ");
lcd.println("FOR PICC.... ");
delay(1500);
void loop() {
lcd.clear();
lcd.print(" SWIPE");
lcd.print(" YOUR CARD"); /*
if (digitalRead(BUTTON) == HIGH); //To Delete the EEROM USE the below command just run it
// for (int i = 0 ; i < EEPROM.length() ; i++) {
// EEPROM.write(i, 0);
do {
if (programMode) {
// Program Mode cycles through RGB waiting to read a new card
else {
if (programMode) {
if ( isMaster(readCard) ) { //If master card scanned again exit program mode
Serial.println("This is Master Card");
Serial.println("Exiting Program Mode");
lcd.clear();
lcd.print("EXITING FROM");
lcd.print("MASTERCARD MODE");
delay(2000);
return;
else {
if ( findID(readCard) ) { //If scanned card is known delete it
Serial.println("I know this PICC, so removing");
lcd.clear();
lcd.print("AVAILABLE!");
lcd.print("SO DELETING.....");
delay(5000);
deleteID(readCard);
Serial.println("-----------------------------");
else { // If scanned card is not known add it
Serial.println("I do not know this PICC, adding...");
lcd.clear();
lcd.print("Card no:");
lcd.print(readCard[0], HEX);
lcd.print(readCard[1], HEX);
lcd.print(readCard[2], HEX);
lcd.print(readCard[3], HEX);
lcd.print(readCard[4], HEX);
delay(4000);
lcd.clear();
lcd.print("NOT AVAILABLE");
lcd.print("SO ADDING.......");
delay(5000);
writeID(readCard);
else {
if ( isMaster(readCard) ) { // If scanned card's ID matches Master Card's ID enter program mode
programMode = true;
Serial.println("Welcome to Mastercard Mode");
lcd.clear();
lcd.print("WELCOME TO");
delay(3000);
int count = EEPROM.read(0); // Read the first Byte of EEPROM that
Serial.print("I have "); // stores the number of ID's in EEPROM
Serial.print(count);
Serial.print(" record(s) on EEPROM");
Serial.println("");
Serial.println("Scan a PICC to ADD or REMOVE");
lcd.clear();
lcd.print("SCAN PICC TO");
lcd.print("ADD OR REMOVE...");
delay(2500);
else {
if ( findID(readCard) ) { // If not, see if the card is in the EEPROM
Serial.println("Acces Granted");
lcd.clear();
lcd.print(" CONGRATULATION");
lcd.print(" ACCESS GRANTED");
digitalWrite(8, HIGH);
delay(1500);
digitalWrite(8, LOW);
lcd.clear();
else { // If not, show that the ID was not valid
Serial.println("Access Denied");
for (int abcd = 0; abcd < 6; abcd++)
lcd.clear();
lcd.print(" SORRY");
lcd.print(" ACCESS DENIED");
delay(700);
lcd.clear();
lcd.print(" YOU'RE NOT ");
lcd.print(" AUTHORIZED ");
delay(700);
lcd.clear();
int getID() {
// Getting ready for Reading PICCs
if ( ! mfrc522.PICC_IsNewCardPresent()) { //If a new PICC placed to RFID reader continue
return 0;
if ( ! mfrc522.PICC_ReadCardSerial()) { //Since a PICC placed get Serial and continue
return 0;
// There are Mifare PICCs which have 4 byte or 7 byte UID care if you use 7 byte PICC
// I think we should assume every PICC as they have 4 byte UID
// Until we support 7 byte PICCs Serial.println("Scanning PICC's UID.........");
lcd.clear();
lcd.print("SCANNING");
lcd.print("PICC's UID.....");
delay(2000);
for (int i = 0; i < 4; i++) { //
readCard[i] = mfrc522.uid.uidByte[i];
Serial.print(readCard[i], HEX);
Serial.println("");
mfrc522.PICC_HaltA(); // Stop reading
return 1;
boolean isMaster( byte test[] ) {
if ( checkTwo( test, masterCard ) )
return true;
else
return false;
}boolean checkTwo ( byte a[], byte b[] ) {
if ( a[0] != NULL ) // Make sure there is something in the array first
match = true; // Assume they match at first
for ( int k = 0; k < 4; k++ ) { // Loop 4 times
if ( a[k] != b[k] ) // IF a != b then set match = false, one fails, all fail
match = false;
if ( match ) { // Check to see if if match is still true
return true; // Return true
else {
return false; // Return false
boolean findID( byte find[] ) {
for ( int i = 1; i <= count; i++ ) { // Loop once for each EEPROM entry
readID(i); // Read an ID from EEPROM, it is stored in storedCard[4]
if ( checkTwo( find, storedCard ) ) { // Check to see if the storedCard read from EEPROM
return true;
break; // Stop looking we found it
else { // If not, return false
return false;
void readID( int number ) {
int start = (number * 4 ) + 2; // Figure out starting position
for ( int i = 0; i < 4; i++ ) { // Loop 4 times to get the 4 Bytes
storedCard[i] = EEPROM.read(start + i); // Assign values read from EEPROM to array
void deleteID( byte a[] ) {
if ( !findID( a ) ) { // Before we delete from the EEPROM, check to see if we have this card!
failedWrite(); // If not
else {
int num = EEPROM.read(0); // Get the numer of used spaces, position 0 stores the number of ID cards
int slot; // Figure out the slot number of the card
int start;// = ( num * 4 ) + 6; // Figure out where the next slot starts
int looping; // The number of times the loop repeats
int j;
int count = EEPROM.read(0); // Read the first Byte of EEPROM that stores number of cards
slot = findIDSLOT( a ); //Figure out the slot number of the card to delete
start = (slot * 4) + 2;
looping = ((num - slot) * 4);
num--; // Decrement the counter by one
EEPROM.write( 0, num ); // Write the new count to the counter
for ( j = 0; j < looping; j++ ) { // Loop the card shift times
EEPROM.write( start + j, EEPROM.read(start + 4 + j)); // Shift the array values to 4 places earlier in the EEPROM
for ( int k = 0; k < 4; k++ ) { //Shifting loop
EEPROM.write( start + j + k, 0);
successDelete();
//For Failed to add the card:
void failedWrite() { Serial.println("something wrong with Card");
lcd.clear();
lcd.print("SOMETHING WRONG");
lcd.print("WITH CARD");
delay(2000);
//For Sucessfully Deleted:
void successDelete() {
Serial.println("Succesfully removed");
lcd.clear();
lcd.print("SUCCESFULLY");
lcd.print("REMOVED");
delay(2000);
int findIDSLOT( byte find[] ) {
// is the same as the find[] ID card passed
return i; // The slot number of the card
//For Sucessfully Added:
void successWrite() { Serial.println("Succesfully added");
lcd.clear();
lcd.print("ADDED");
delay(2000);
//For Adding card to EEROM:
void writeID( byte a[] ) {
if ( !findID( a ) ) { // Before we write to the EEPROM, check to see if we have seen this card before!
int start = ( num * 4 ) + 6; // Figure out where the next slot starts
num++; // Increment the counter by one
EEPROM.write( start + j, a[j] ); // Write the array values to EEPROM in the right position
successWrite();
else {
failedWrite();
