Introduction: RGB Conductive Mosaic
For my Computational Craft midterm, I wanted to take a swatch that I made earlier in the semester and expand upon it. I am a musician (trumpet player/composer) and I have always been fascinated by/passionate about making mosaics.
The materiality of the CDs is important to me because I feel like they are just a business card for musicians now. Most people buy music on iTunes or listen to it on Spotify or Pandora making the landscape for a performing artist's revenue and distribution radically different than it was even 10 years ago.
Step 1: Materials
2 Neopixel RGB LEDs (or other addressable LEDs
Lilytiny with USB port
Black (or any other color), non-conductive fabric
Copper
Conductive thread
Clear nail polish
CDs (or other non-conductive material to make your mosaic out of)
Hot glue gun (and hot glue refills)
Libraries:
adafruit neopixel library
Digispark Library (https://digistump.com/wiki/digispark)
Step 2: Build Your Simple Circuit (make Sure to Test With Alligator Clips Before You Sew!)
LilyTiny Vin-LED power
Ground-LED Ground
LilyTiny Pin 3- LED Data In
I highly recommend reading through the Adafruit Sewable Neopixels guide before you attempt to sew your circuit.
Add the Copper switch to act as a soft-button on the power line
Step 3: Time to Make Your Mosaic!!!
Use materials that you think are beautiful to construct your mosaic!
I used CDs because I think that they are very beautiful when they are cut and reflect the light in a very interesting way.
Make sure not to disrupt your circuit or place conductive material near your circuit.
Step 4: Code Time
Upload this code onto your Lilypad Tiny and watch it light up!
#include
#define PIN 3 #define gnd 0
// Parameter 1 = number of pixels in strip // Parameter 2 = Arduino pin number (most are valid) // Parameter 3 = pixel type flags, add together as needed: // NEO_KHZ800 800 KHz bitstream (most NeoPixel products w/WS2812 LEDs) // NEO_KHZ400 400 KHz (classic 'v1' (not v2) FLORA pixels, WS2811 drivers) // NEO_GRB Pixels are wired for GRB bitstream (most NeoPixel products) // NEO_RGB Pixels are wired for RGB bitstream (v1 FLORA pixels, not v2) Adafruit_NeoPixel strip = Adafruit_NeoPixel(2, PIN, NEO_GRB + NEO_KHZ800);
// IMPORTANT: To reduce NeoPixel burnout risk, add 1000 uF capacitor across // pixel power leads, add 300 - 500 Ohm resistor on first pixel's data input // and minimize distance between Arduino and first pixel. Avoid connecting // on a live circuit...if you must, connect GND first.
void setup() {
pinMode(gnd, OUTPUT); digitalWrite (gnd, LOW); // use this pin as a ground strip.begin(); strip.show(); // Initialize all pixels to 'off' }
void loop() {
colorWipe(strip.Color(255, 255, 255), 20); // Red colorWipe(strip.Color(255, 0, 0), 20); // Green colorWipe(strip.Color(0, 0, 255), 1); // Blue // Send a theater pixel chase in...
// Fill the dots one after the other with a colorå void colorWipe(uint32_t c, uint8_t wait) { for(uint16_t i=0; i
