Introduction: RGB LED Lamp
This is a special lamp that helps you sleep well. I use the RGB LED to make this lamp, it's elegant if you add a cover.
1x Arduino Leonardo
5x Wires
4x Clip wires
1x RGB LED
1x Paper
1x 100ohm resistor
Step 1: Code
The link for full codes: Arduino CC
//RGB LED lamp
//The color of LED changes in the order of red, orange, yellow, green, blue, dark blue, and then purple.
//The RGB LED is controlled by the color of red, green, and blue
//Pin 7 controls the brightness of the red
//Pin 6 controls the brightness of the green
//Pin 5 controls the brightness of the blue
void setup(){ // put your setup code here, to run once:
void loop(){ // Main code
analogWrite(7 , 255); //改
analogWrite(6 , 0); //改
analogWrite(5 , 0); //改
delay( 1000 ); // waits a few milliseconds
//Red
analogWrite(6 , 120); //改
//Orange
analogWrite(7 , 255);//改
analogWrite(6 , 255); //改
//Yellow
analogWrite(7 , 0); //改
//Green
analogWrite(5 , 255); //改
//Blue
//Dark Blue
analogWrite(7 , 130); //改
//Purple
Step 2: Explain
RGB LED is controlled by a negative polarity and three kinds of light: Red, Green, and Blue. These three colors are the primary colors of light. Different brightness for each color combined can make almost all kinds of color. I choose the colors of the rainbow: red, orange, yellow, green, blue, dark blue, and violet to be the colors of my lamp.
Step 3: Building Up Arduino
Build up the circuit like the image above.
- Three wires connect from D5, D6, and D7 to the RGB LED.
- A wire connects from GND to LED's negative polarity
- 4 clip wires connect to the RGB LED
- Upload the codes from Arduino app
- Make a paper shade cover on it
Here is a link for how to use a paper to make lamp cover:
https://www.youtube.com/watch?v=DCelEdIow2c
After all of that, you are finish!
Congrats!
Source: LED blinking
