RGB LED STRIP COLOR ORGAN (WITHOUT MICROCONTROLLER)
Intro: RGB LED STRIP COLOR ORGAN (WITHOUT MICROCONTROLLER)
its a RGB LED STRIP ORGAN and don't used any microcontroller. its based N-channel mosfet.
STEP 1: Parts
Hi,
Its a RGB LED STRIP COLOR ORGAN WITHOUT MICROCONTROLLER
and here is the part list .
1) 3.5mm audio socket- 1ps
2) 12V, 2AMP power adaptor- 1ps
3) 5m of RGB LED Strip.- 1ps
4) Prototyping board- 1ps
5) N-channel mosfet (11N65C3) - 3Ps
6) Diode - 1N4148 -1ps
7) 50K ohm Potentiometer- 1ps
8) Transistors
I) 2N3904 - 1ps
II) 2N3906 - 3ps
9) LED
I) Red Led- 1ps
II) Green Led- 1ps
III) Blue Led- 1ps
10) Capacitors
I) 10uF electrolytic-1ps
II) 0.047uF ceramic- 1ps
III) 0.47uF electrolytic- 1ps
IV) 0.01uF ceramic- 1ps
V) 1uF electrolytic- 1ps
11) Resistors
I) 100 ohm - 2ps
II) 10K ohm- 2ps
III) 1k ohm- 1ps
IV) 2.2K ohm -3ps
V) 4.7K ohm- 2ps
VI) 150 ohm -1ps
VII) 270 ohm- 2ps
STEP 2: Circuit Diagram
its a very simple circuit, I found a circuit for total 6 LEDs on the internet. I took is and modified it to drive full 5 meters RGB LED STRIP by using the N channel mosfet, here is the Circuit diagram take a look
STEP 3: Video
Hear it is in the working I have a you tube channel by the name of ELECTRONIC JUGAAD plz check it out.
and if u have any question plz comment below I will answer them as soon as possible.
21 Comments
tomatoskins 9 years ago
This looks so cool! I'd love to see this turned into a EL wire suit for raves! That would be awesome!
lsanjaysha 9 years ago
yes that will be awesome I will try for it soon!
monkeyracing 9 years ago
thanks for writing, plz share this. and share your build with me
sparks_vfr 3 years ago
https://makezine.com/projects/easy-led-color-organ/
PapakC 8 years ago
didnt had mosfet so i use tip31c and reverse it after rgb led (didnt notice before that rgb led has 1 common + and 3 - for each color
https://www.youtube.com/watch?v=rwskswdi4tA
doblandopapeles 8 years ago
any clue?
could you explain how to use a tip31 in this circuit in more detail?
thanks
Asesh Basu 8 years ago
Wow!! This looks awesome!
I totally want to make it. I have one small question though, what do i do to connect leds (say 5 leds for the 3 frequencies) instead of the led strip?
WOW!! Looks so awesome!
Nice work, dada.
I have one question though. What if I want to use led's (say 5 leds for each color), how should I progress??
Sn34kyP373 8 years ago
I believe you introduced an error in your diagram. You have an additional join where the 10uF, 10K Ohm, 1N4148, and 2N3904 components are. The original drawing over at http://makezine.com/projects/easy-led-color-organ/ doesn't have this join.
vladereign.hyuuga 8 years ago
hi I am trying to replicate your project i have some questions, 1 is the 10K at the base of 2n3904 looks shorted 2, what is the use of the mosfet?
here's mine
https://www.youtube.com/watch?v=xnMQG-hF-ho
<iframe width="560" height="315" src="https://www.youtube.com/embed/xnMQG-hF-ho?rel=0" frameborder="0" allowfullscreen></iframe>
I built mine, just a little adjustment on the circuit above.
JP04294 8 years ago
Hello, I was wondering if you could tell me how to hook this up to an alternate power source, such as the fuse box/car battery of an automobile?
lsanjaysha 8 years ago
its simple if u have 12V battery in your car then hook car battery ground to circuit ground and connect positive to circuit's positive and put an on/off switch between it.
JustineR1 8 years ago
i am confuse what is male header sv1 on the top for?
thats for RGB strip output.
Mad scientist - ieks 9 years ago
hi,
im working on the same thing only i want that i can still use al the colors of my rgb led strip. So i can ir remote the color and it will jump with it on the music. Until know not mutch succes. Im just useing transistor's, driver and adapter, and a +12V 3A remote then (adapter the same specs) the strip is 4m long, and 4 wire's (afcorse) and if i possibly can then i want to have a switch between so i can turn it off - flashing on sound - normal on
I hope to hear from you!
