RGB LED Game Shield for Arduino
Intro: RGB LED Game Shield for Arduino
To play this game, you have to match the random color displayed by one of the rgb leds by using 3 sliding potentiometers. Then, you press a button and you are told whether you were right or not. There are 2 levels, easy and hard, and a reset button so you can go to a new color after you win.
That's the main basis of my project, and I hope you enjoy seeing how I made it.
STEP 1: Materials
Materials:
Arduino
2 rgb leds
3 red leds*
3 green leds*
2 pusbutton switches
1 sliding switch (I used a right-angle DPDT)
3 10k Slidding Potentiometers
1 piece of pc board*
4 10-pin male headers
1 10k resistor
8 150 ohm resistors*
6 100 ohm resistors*
wire
Tools:
Solder
Soldering iron
Basic electronic tools(pliers, wire cutters, wire strippers)
*The stars will be explained on the next page
STEP 2: The Parts
The red and green leds
For this you can either use 3 green leds and 3 red leds which are used to display if you won the game or lost it, but you can also do what I did and use 3 red/green leds.
The pc board
Make sure the pc board is large enough to cover the entire arduino, as some pieces are too small and will not fit all the parts or pins on the arduino.
Resistors
I used 100 ohms on the blue and green of the rgb leds and 150 ohm on the red but that can change depending on your leds. I used 150 ohm on my red/green leds but thaat can change for yours too. The reset button has one 100 ohm resistor and the "checking button" has a 10k and a 100 ohm resistor.
STEP 3: Bend the Headers
the make the headers work for this shield, use pliers and push the smaller part down so the longer part gets longer. Now cut two of the headers into blocks of 6 and the other 2 headers into blocks of 8.
The arduino does not have all .1" spacing, so we have to accomodate for that. Take one of the 8-blocks and bend all the pinsto one way about 30 degrees. Now,grab the pins a little higher with the pliers and bend them back to normal. This should offset them just enough to fit the arduino.
STEP 4: Soldering
If you have trouble reading it, I will do a write-up of the circuit too.
STEP 5: The Code
The code for this project is pretty simple. The first part is for defing everything, the second for creating a random color, and the third for using the potentiometers and giving the pushbutton and leds commands.
Here it is:
/*Code for rgb led game shield. By Ikestarm17. Special thanks to Ladyada for
all the great products, mbeckler for his informational site, marklar, grumpy_mike,
and AWOL on the Arduino forums.*/
int greenled1 = 13;
int greenled2 = 8;
int greenled3 = 4;
int redled1 = 19;
int redled2 = 7;
int redled3 = 12; // leds that show if you were right or not
int buttonstate;
int val;
int val2;
int val3;
int switchpin = 2;
int switchpin2 = 0; // variables for the button stuff
int redactual;
int greenactual;
int blueactual; // variables for storing the colors you need to match
int redPin = 3;
int bluePin = 5;
int greenPin = 6; // pins for the rgb led you control
int redIn = 2;
int greenIn = 3;
int blueIn = 4; // pins for the potentiometers for the rgb led
int redguess;
int greenguess;
int blueguess; // variables to store the values of your led to compare to the random ones
/* This following part before "void setup()"
*is all about making the rgb led
*a "good" random color, not just a whited out one.
*I don't know much about this part,
*because I only changed one little part,
*Marklar from the arduino forums created it */
#ifndef RGBCommonLED_H
#define RGBCommonLED_H
#include "WProgram.h"
class RGBCommonLED {
public:
RGBCommonLED(int rpin, int gpin, int bpin);
~RGBCommonLED();
void setRGB(byte r, byte g, byte b);
void setHSV(byte h, byte s, byte v);
void setColor(unsigned long v);
void setHue(byte level);
void setSat(byte level);
void setVal(byte level);
void adjHue(int level);
void adjSat(int level);
void adjVal(int level);
void setRandomColor();
void setRandomHue();
void setRandomSat();
void setRandomVal();
void setHSVLevel(int section, byte level);
void adjHSVLevel(int section, int level);
void setRandomHSVLevel(int section);
void updateLED();
void HSVToRGB( unsigned int inHue, unsigned int inSaturation, unsigned int inValue,
unsigned int *oR, unsigned int *oG, unsigned int *oB );
void RGBToHSV( unsigned int inRed, unsigned int inGreen, unsigned int inBlue,
unsigned int *oH, unsigned int *oS, unsigned int *oV );
void updateHSVFromRGB();
int pins[3];
int rgb[3];
int hsv[3];
private:
boolean hsvSet;
void setRGBFromHSV();
void setHSVFromRGB();
#endif
RGBCommonLED::RGBCommonLED(int rpin, int gpin, int bpin){
pins[0] = rpin;
pins[1] = gpin;
pins[2] = bpin;
hsvSet = false;
RGBCommonLED::~RGBCommonLED(){
void RGBCommonLED::setColor(unsigned long v)
this->setRGB((v & 255),((v >> 8) & 255),(v >> 16) & 255);
void RGBCommonLED::setRGB(byte r, byte g, byte b){
rgb[0] = r;
rgb[1] = g;
rgb[2] = b;
hsvSet = false;
void RGBCommonLED::setHSV(byte h, byte s, byte v){
hsv[0] = h;
hsv[1] = s;
hsv[2] = v;
this->setRGBFromHSV();
hsvSet = true;
void RGBCommonLED::setHSVLevel(int section, byte level){
updateHSVFromRGB();
hsv[section] = level;
void RGBCommonLED::setHue(byte level){
this->setHSVLevel(0,level);
void RGBCommonLED::setSat(byte level){
this->setHSVLevel(1,level);
void RGBCommonLED::setVal(byte level){
this->setHSVLevel(2,level);
void RGBCommonLED::adjHSVLevel(int section, int level){
updateHSVFromRGB();
int th = hsv[section] + level;
if( th < 0 ){
th = 255 + th;
else if( th > 255 ) {
th = 255 - th;
th = constrain(th,0,255);
hsv[section] = th;
void RGBCommonLED::adjHue(int level){
this->adjHSVLevel(0,level);
void RGBCommonLED::adjSat(int level){
this->adjHSVLevel(1,level);
void RGBCommonLED::adjVal(int level){
this->adjHSVLevel(2,level);
void RGBCommonLED::RGBToHSV( unsigned int inRed, unsigned int inGreen, unsigned int inBlue,
double vals[3];
unsigned char maxc=0, minc=0;
double hue, sat, val;
vals[0]=inRed;
vals[1]=inGreen;
vals[2]=inBlue;
//red is set as maximum and minimum
if(vals[1]>vals[maxc]) maxc=1;
if(vals[2]>vals[maxc]) maxc=2;
if(vals[1]<vals[minc]) minc=1;
if(vals[2]<vals[minc]) minc=2;
val = vals[maxc];
if(vals[maxc]==0)
sat = hue = 0;
else
sat=255*(1-(vals[minc]/vals[maxc]));
hue = 60 * ((maxc*2) + (vals[(maxc+1)%3] - vals[(maxc+2)%3])/(vals[maxc] - vals[minc]));
if(hue < 0) hue += 360; //corrector for hues in -60 to 0 range
*oH = hue; //map(hue,0,360,0,255);
*oS = sat;
*oV = val;
void RGBCommonLED::HSVToRGB( unsigned int inHue, unsigned int inSaturation, unsigned int inValue,
if( inSaturation == 0 )
// achromatic (grey)
*oR = *oG = *oB = inValue;
else
unsigned int scaledHue = (inHue * 6);
unsigned int sector = scaledHue >> 8; // sector 0 to 5 around the color wheel
unsigned int offsetInSector = scaledHue - (sector << 8); // position within the sector
unsigned int p = (inValue * ( 255 - inSaturation )) >> 8;
unsigned int q = (inValue * ( 255 - ((inSaturation * offsetInSector) >> 8) )) >> 8;
unsigned int t = (inValue * ( 255 - ((inSaturation * ( 255 - offsetInSector )) >> 8) )) >> 8;
switch( sector ) {
case 0:
*oR = inValue;
*oG = t;
*oB = p;
break;
case 1:
*oR = q;
*oG = inValue;
*oB = p;
break;
case 2:
*oR = p;
*oG = inValue;
*oB = t;
break;
case 3:
*oR = p;
*oG = q;
*oB = inValue;
break;
case 4:
*oR = t;
*oG = p;
*oB = inValue;
break;
default: // case 5:
*oR = inValue;
*oG = p;
*oB = q;
break;
void RGBCommonLED::setRandomColor(){
this->setColor((unsigned long)random(0x01000000));
void RGBCommonLED::setRandomHue(){
this->setRandomHSVLevel(0);
void RGBCommonLED::setRandomSat(){
this->setRandomHSVLevel(1);
void RGBCommonLED::setRandomVal(){
this->setRandomHSVLevel(2);
void RGBCommonLED::setRandomHSVLevel(int section){
this->setHSVLevel(section, (unsigned int)random(0x0100));
void RGBCommonLED::updateHSVFromRGB(){
this->setHSVFromRGB();
hsvSet = true;
void RGBCommonLED::updateLED(){
analogWrite(this->pins[0], rgb[0]);
analogWrite(this->pins[1], rgb[1]);
analogWrite(this->pins[2], rgb[2]);
redactual = rgb[0];
greenactual = rgb[1];
blueactual = rgb[2];
void RGBCommonLED::setRGBFromHSV(){
unsigned int h = hsv[0];
unsigned int s = hsv[1];
unsigned int v = hsv[2];
unsigned int r = 0;
unsigned int g = 0;
unsigned int b = 0;
HSVToRGB(h,s,v,&r,&g,&b);
this->setRGB(r,g,b);
void RGBCommonLED::setHSVFromRGB(){
unsigned int r = rgb[0];
unsigned int g = rgb[1];
unsigned int b = rgb[2];
unsigned int h;
unsigned int s;
unsigned int v;
this->RGBToHSV(r,g,b,&h,&s,&v);
hsv[0] = map(h,0,360,0,255);
hsv[1] = s;
hsv[2] = v;
hsvSet = true;
RGBCommonLED led1(10,11,9);
void setup()
pinMode(redled1, OUTPUT);
pinMode(redled2, OUTPUT);
pinMode(redled3, OUTPUT);
pinMode(greenled1, OUTPUT);
pinMode(greenled2, OUTPUT);
pinMode(greenled3, OUTPUT);
pinMode(switchpin, INPUT);
pinMode(switchpin2, INPUT);// setting the leds as output and the switch as input
Serial.begin(9600); // start serial
randomSeed(analogRead(0)); // read analog pin 0 to get random value
led1.setRandomHue();
led1.setSat(255);
led1.setVal(255);
led1.setRandomColor();
led1.updateLED(); // set a random color on the first rgb led
buttonstate = digitalRead(switchpin); // read the switch as off
void loop(){
redguess = analogRead(redIn);
greenguess = analogRead(greenIn);
blueguess = analogRead(blueIn); // read the potentiometers
redguess = map(redguess, 0, 1023, 0, 255);
greenguess = map(greenguess, 0, 1023, 0, 255);
blueguess = map(blueguess, 0, 1023, 0, 255); // scale down the values
analogWrite(redPin, redguess);
analogWrite(greenPin, greenguess);
analogWrite(bluePin, blueguess); // set the color values
redguess = 255 - redguess;
blueguess = 255 - blueguess;
greenguess = 255 - greenguess; // fix the value's numbers so 0 is 255 and 255 is 0
val = digitalRead(switchpin);
delay(10);
val2 = digitalRead(switchpin);
val3 = digitalRead(switchpin2); // read switches and fix the bouncing
if(val3 == LOW && val == val2 && val != buttonstate && val == LOW && redactual + 55 < redguess ||
val3 == LOW && val == val2 && val != buttonstate && val == LOW && redactual - 55> redguess ||
val3 == LOW && val == val2 && val != buttonstate && val == LOW && blueactual + 55 < blueguess ||
val3 == LOW && val == val2 && val != buttonstate && val == LOW && blueactual - 55 > blueguess ||
val3 == LOW && val == val2 && val != buttonstate && val == LOW && greenactual + 55 < greenguess ||
val3 == LOW && val == val2 && val != buttonstate && val == LOW && greenactual - 55 > greenguess ||
val3 == HIGH && val == val2 && val != buttonstate && val == LOW && redactual + 85 < redguess ||
val3 == HIGH && val == val2 && val != buttonstate && val == LOW && redactual - 85 > redguess ||
val3 == HIGH && val == val2 && val != buttonstate && val == LOW && blueactual + 85 < blueguess ||
val3 == HIGH && val == val2 && val != buttonstate && val == LOW && blueactual - 85 > blueguess ||
val3 == HIGH && val == val2 && val != buttonstate && val == LOW && greenactual + 85 < greenguess ||
val3 == HIGH && val == val2 && val != buttonstate && val == LOW && greenactual - 85 > greenguess){ // make sure your led's colors do not match the other one's for the easier level
digitalWrite(greenled1, LOW), // turn on red leds
digitalWrite(redled1, HIGH),
delay(500),
digitalWrite(redled1, LOW),
digitalWrite(redled2, HIGH),
delay(500),
digitalWrite(redled2, LOW),
digitalWrite(redled3, HIGH),
delay(500),
digitalWrite(redled3,LOW);
delay(500),
delay(500),
delay(500),
digitalWrite(redled3,LOW),
delay(250),
digitalWrite(redled3, LOW),
delay(250),
delay(250),
delay(250),
delay(250),
delay(250),
delay(250),
delay(250);
while(val3 == LOW && val == val2 && val != buttonstate && val == LOW && // make sure button is pressed
redactual + 55 >= redguess && redactual - 55 <= redguess &&
blueactual + 55 >= blueguess && blueactual - 55 <= blueguess &&
greenactual + 55 >= greenguess && greenactual - 55 <= greenguess ||
redactual + 85 >= redguess && redactual - 85 <= redguess &&
blueactual + 85 >= blueguess && blueactual - 85 <= blueguess &&
greenactual + 85 >= greenguess && greenactual - 85 <= greenguess){ // make sure your led's colors are close enough to the other one's for the easy level
digitalWrite(redled1,LOW), // turn on green leds
digitalWrite(greenled1, HIGH),
delay(500),
digitalWrite(greenled2, HIGH),
delay(500),
digitalWrite(greenled2, LOW),
digitalWrite(greenled3, HIGH),
delay(500),
digitalWrite(greenled3, LOW),
delay(500),
delay(500),
delay(500),
delay(250),
delay(250),
delay(250),
delay(250),
delay(250),
delay(250),
delay(250),
delay(250);
11 Comments
ktrantham 9 years ago
I noticed a problem with the sketch!! If its not already fixed in your sketch/code, The #include WProgram.h is now Arduino.h in the newer versions of Arduino IDE. Thanks for the share, this is great, gonna give it a go!
Makersauce 13 years ago
aaronXtreme 10 years ago
hey u can start anytime. try renting books frm the library on arduino and programming. its a great hobby
ikestarm17 13 years ago
could you use 10k pots ins tread of the sliders?
this is great!
nrodríguez9 12 years ago
cricketm24 12 years ago
the seaker 13 years ago
whiskey_14 14 years ago
ikestarm17 14 years ago
