Introduction: RGB REMOTE (pinguino+web+linksys)
It may be a way to harmonize a room, change the color of a swimming pool or just fooling around
Step 1: RGB REMOTE Webserver and Serial Connection
As to the little memory space of this team, to host my website, I have included a change and I have installed a 1GB SD card as hard drive so you can play and install things without fear to occupy the 5Mb which has by default. I've also created two output interfaces for internal serial ports by default has LINKSYS and that, in principle are control consoles, modifying a bit its used to connect any computer with RS232 communication.
Step 2: RGB REMOTE Pinguino
link original http://www.hackinglab.org/pinguino/index_pinguino.html
link Madrid http://pinguino.walii.es
The program basically tells the microcontroller that the serial port and listen when you get status R eg send a pulse to continuous 5volts particular output for the red LEDs. And finally sent to the serial port the color name that is kindled.
The code is as follows. USE PINGUINO GUI to programate it.
// Prueba de Puerto serie comandando RGB
// walii.es 2010
//aquí agregamos las posibles variables.
int i; //para nuestro contador de puertos
int key; //para la tecla que escucha por el Puerto serie.
void setup()
//Aquí configuramos los puertos de salida para que inicien
//en estado de SALIDA y APAGADOs.
for (i=1;i<4;i++){
pinMode(i,OUTPUT);
digitalWrite(i,LOW);
//Aquí configuramos el Puerto serie, para que escuche peticiones a 9600bps,
//suficiente para este proyecto.
Serial.begin(9600);
//Y por acá podemos ver la configuración de comandos a escuchar en el Puerto
//serie y hacer lo necesario para iniciar los leds que correspondan a la acción
void loop()
if Serial.available()
key=Serial.read(); //escucha el Puerto serie…
if (key=='r') digitalWrite(1,1),digitalWrite(2,0),digitalWrite(3,0),Serial.print("rojo");
if (key=='v') digitalWrite(1,0),digitalWrite(2,1),digitalWrite(3,0),Serial.print("verde");
if (key=='a') digitalWrite(1,0),digitalWrite(2,0),digitalWrite(3,1),Serial.print("azul");
if (key=='m') digitalWrite(1,1),digitalWrite(2,1),digitalWrite(3,0),Serial.print("marron");
if (key=='b') digitalWrite(1,1),digitalWrite(2,0),digitalWrite(3,1),Serial.print("morado");
if (key=='n') digitalWrite(1,0),digitalWrite(2,1),digitalWrite(3,1),Serial.print("celeste");
if (key=='w') digitalWrite(1,1),digitalWrite(2,1),digitalWrite(3,1),Serial.print("blanco");
if (key=='c') digitalWrite(1,0),digitalWrite(2,0),digitalWrite(3,0),Serial.print("apagado");
Serial.print("\n\r"); //por ultimo imprimimos el nombre del color seleccionado.
//vuelve a comenzar el loop
Step 3: RGB REMOTE Web Programming
The web part is easy, are in lua script that generates a message to the serial port ECHO.
For example:
Create files for each color.
Rojo.lua, verde.lua, azul.lua, morado.lua, etc.
We put them in the run directory CGI-BIN on our server. And we give it execute permission. With the command chmod + x *. lua
The files inside are the following. For the record rojo.lua, for our case is the serial port (/ dev/tts/1)
---# //para rojo envía por puerto serie el carácter "r"
---#! /usr/bin/lua
caracter="echo r > /dev/tts/1";
os.execute(caracter);
EASY NO ????????
Now in any button you want to do, we can put as ( href="/cgi-bin/rojo.lua" ) and run the script every time you press.
For example, this code is copied to a file.html on our web server.
