Introduction: RMConstruction's Shadow Sniper Rifle
This is my Shadow Sniper-Rifle. I was improving my previous sniper, and i kinda hated the back, so i only kept the barell. I added various other parts including a great ratchet system and foregeip. Gradually, i improved it more and more, and i ended up with this great gun. I call it the "Shadow" sniper rifle because it is still quite accurate in the dark.
PROS
Removable stock
Removable scope
Powerful
Fairly accurate
CONS
If you use the wrong size band, the barell can rip in half
AMMO
Red connector + blue rod
Random connectors, not white. They jam the ratchet!
PLEASE DON'T FORGET TO COMMENT AND RATE!
PROS
Removable stock
Removable scope
Powerful
Fairly accurate
CONS
AMMO
Step 1: Handle
Pretty easy to build, follow the notes for details.
Step 2: Trigger System & Ratchet
The trigger and ratchet system. Follow the notes for details.
Step 3: Foregrip
The foregrip for the barell. Very easy.
Step 4: Barell & Supports
The easy Barell and supports.
Step 5: Scope Attatchment
The scope. Very easy.
Step 6: Stock Attatchment
The stock. Pretty easy, notes to help.
Step 7: Assembly
Pretty easy assembly. Notes to help.
Step 8: Rubber Bands
Adding the bands. Again simple.
Step 9: Loading and Firing
Easy. Pull back your band, connect to the ratchet and fire!!!
Your done!
Enjoy, and please don't forget to rate and comment!!
Thanks!
Your done!
Thanks!
