Introduction: ROS Melodic on Raspberry Pi 4[Debian Buster] + RPLIDAR A1M8
This article will cover the process of installing ROS Melodic Morenia on Raspberry Pi 4 running the latest Debian Buster and how to use RPLIDAR A1M8 with our installation.
Since Debian Buster was officially released just a few weeks ago(as of moment of writing this article), there are no pre-built ROS packages to install with apt-get, which is a preferred method of installation. Hence we will need to build it from source. Trust me, it's not that scary as it sounds. The process is described in this official tutorial, but to build ROS Melodic on Raspberry Pi we will need to make a few modifications.
In case you are still scared, here is a funny picture that *might* help you relax. Please do provide feedback if the level of relaxation provided was sufficient. If not, it will be replaced with picture of a funny cat.
January 2020 EDIT: Since it has been half a year since I posted this article there might have been some changes to ROS or Buster. I have made an image for Raspberry Pi 4 a while ago, after writing this tutorial. A contributor has uploaded it to Google Drive
https://drive.google.com/file/d/1lcPBYgdFG7EuaIV23...
April 2020 EDIT: I have found time recently to redo ROS Melodic installation on the newest Raspbian image from official Raspberry Pi site.I have edited this instructable accordingly. I also created and shared clean, compressed images:
Raspbian Buster Lite 2020-02-13 Release with ROS Melodic Bare-bones Need 8 GB SD card
Raspbian Buster with desktop 2020-02-13 Release with ROS Melodic Desktop Need 16 GB SD card
It might be the fastest way to get your system up and running. If you wish to compile ROS yourself, keep reading the article.
Step 1: Installing Bootstrap Dependencies and Download the Packages
Let's start by setting up the repositories and installing the necessary dependencies
sudo sh -c 'echo "deb http://packages.ros.org/ros/ubuntu $(lsb_release -sc) main" > /etc/apt/sources.list.d/ros-latest.list'
sudo apt-key adv --keyserver 'hkp://keyserver.ubuntu.com:80' --recv-key C1CF6E31E6BADE8868B172B4F42ED6FBAB17C654
sudo apt-get update
sudo apt-get install -y python-rosdep python-rosinstall-generator python-wstool python-rosinstall build-essential cmake
Then initialize rosdep and update it
sudo rosdep init
rosdep update
When that's done let's create a dedicated catkin workspace for building ROS and move to that directory.
mkdir ~/ros_catkin_ws
cd ~/ros_catkin_ws
Now you have two choices:
ROS-Comm: (Bare Bones) installation - install this one if you are familiar with ROS and know what you are doing and what packages you will need. If you need packages not included in ROS-Comm, you will need to compile from source as well.
Desktop Install: includes GUI tools, such as rqt, rviz, and robot-generic libraries. Might be better choice for beginners to ROS.
I'll go with installing Desktop Install here.
rosinstall_generator desktop --rosdistro melodic --deps --wet-only --tar > melodic-desktop-wet.rosinstall wstool init -j8 src melodic-desktop-wet.rosinstall
The command will take a few minutes to download all of the core ROS packages into the src folder.
If wstool init fails or is interrupted, you can resume the download by running:
wstool update -j4 -t src
Step 2: Fix the Issues
April 2020 EDIT: Skip this step, it seems all the issues have been fixed now.
Let's install the compatible version of Assimp (Open Asset Import Library) to fix collada_urdf dependency problem.
mkdir -p ~/ros_catkin_ws/external_src cd ~/ros_catkin_ws/external_src
wget <a href="http://sourceforge.net/projects/assimp/files/assimp-3.1/assimp-3.1.1_no_test_models.zip/download" rel="nofollow"> http://sourceforge.net/projects/assimp/files/assi...</a> -O assimp-3.1.1_no_test_models.zip
unzip assimp-3.1.1_no_test_models.zip
cd assimp-3.1.1
cmake .
make
sudo make install
Let's also install OGRE for rviz
sudo apt-get install libogre-1.9-dev
January 2020 UPDATE: The issues with libbost already has been fixed by ROS developers, you can skip this part
/// skip /// Finally we'll need to fix the issues with libboost. I'm using the solution from this post on stackoverflow:
"The errors during compilation are caused by the 'boost::posix_time::milliseconds' function which
in newer boost versions accepts only an integer argument, but the actionlib package in ROS, gives it a float on several places. You can list all files using that function (!in ros_catkin_ws folder!):
find -type f -print0 | xargs -0 grep 'boost::posix_time::milliseconds' | cut -d: -f1 | sort -u
Open them in your text editor and search for the
'boost::posix_time::milliseconds' function call.
and replace calls like this:
boost::posix_time::milliseconds(loop_duration.toSec() * 1000.0f));
with:
boost::posix_time::milliseconds(int(loop_duration.toSec() * 1000.0f)));
and these:
boost::posix_time::milliseconds(1000.0f)
with:
boost::posix_time::milliseconds(1000)
I recommend you use nano text editor, which is simpler than VIM ;) Ctrl+O is saving, Ctrl+X is exiting and Ctrl+W is searching.
///continue_from_here///
Step 3: Build and Source the Installation
Next we use the rosdep tool for installing all the rest of the dependencies:
rosdep install --from-paths src --ignore-src --rosdistro melodic -y
Once it has completed downloading the packages and resolving the dependencies you are ready to build the catkin packages. (Run this command from ros_catkin_ws folder)
sudo ./src/catkin/bin/catkin_make_isolated --install -DCMAKE_BUILD_TYPE=Release --install-space /opt/ros/melodic -j2
If the compilation process freezes(very likely, if you install the desktop version), you need to increase swap space available. By default it's 100 MB, try increasing it to 2048 MB.
Good luck! The whole compilation process takes about 1 hour(less for Bare-bones version), so go make some tea.
Now ROS Melodic should be installed on your Raspberry Pi 4. We'll source the new installation with following command:
echo "source /opt/ros/melodic/setup.bash" >> ~/.bashrc
Open a new shell for changes to take effect. Try launching roscore to check if everything was successful.
Step 4: Install RPLIDAR ROS Package
Let's create a separate workspace for other packages, that are not part of core ROS.
From you home folder do:
mkdir -p ~/catkin_ws/src
cd ~/catkin_ws/
catkin_make
and source it to bashrc:
echo "source $HOME/catkin_ws/devel/setup.bash" >> ~/.bashrc
Okay, we're ready to start installing RPLIDAR ROS package.
cd src
sudo git clone https://github.com/Slamtec/rplidar_ros.git cd ..
catkin_make
Wait for the package compilation to finish. Try launching the package to see if the compilation was successful:
roslaunch rplidar_ros rplidar.launch
If it doesn't output any errors, do a quick celebration dance(*optional).
Now only the last piece is missing - since you are probably running Raspberry Pi 4 in headless mode, we can't visualize lidar messages. For that we'll need to set-up ROS to run on multiple machines.
Step 5: Set Up ROS to Run on Multiple Machines
For this part you will need a Ubuntu 18.04 computer with ROS Melodic installed. Since it's Ubuntu ROS can be simply installed using apt-get as described in this tutorial.
After you have working ROS installation both on Raspberry Pi and your desktop machine, check the IP addresses of both machines. They need to be on the same network!
Run roscore on your desktop computer and export ROS_MASTER_URI
roscore
export ROS_MASTER_URI=http://[your-desktop-machine-ip]:11311
Next on Raspberry PI execute
export ROS_IP=[your-raspberry-pi-ip]
and launch RPILIDAR launch file
If it launches successfully, check the topics present on your desktop machine with rostopic list
If you can see / scan mesages, everything works as it supposed to work. Then launch RVIZ on your desktop machine, add Laser Scan messages and choose /scan topic. You will also need to change fixed frame to /laser.
Voila!
Step 6: Done!
This guide can be a first step towards building your ROS robot on top of new Raspberry Pi 4. We have installed ROS Melodic and prepared the installation for running headless and connecting to our desktop machine over wireless network for remote control.
Next steps are dependent on what type of robot you want to build. You can add motors and encoders for odometry, stereo camera for Visual SLAM and all sorts of other exciting and useful things.
The hardware for this article was kindly provided by Seeed studio. Check out Raspberry Pi 4, RPLIDAR A1M8 and other hardware for makers at Seeed studio store!
Add me on LinkedIn if you have any question and subscribe to my YouTube channel to get notified about more interesting projects involving machine learning and robotics.
67 Discussions
Question 3 months ago
Hello , I got the LaserScan map on rviz using /scan topic. But I have problems in running HectorSLAM or SLAM algorithms in rpi. So is there a contact information ( Email, telegram , or WhatsApp) in order to discuss with u urgent things . Aim Waiting ur reply urgently
4 months ago
I was struggling couple of days to install ROS on Pi4 , Just I picked up image mentioned in tutorial.Thanks a ton for preparing this as well as updating .Providing image file is great help
6 months ago
I found this error when I installed this - sudo ./src/catkin/bin/catkin_make_isolated --install -DCMAKE_BUILD_TYPE=Release --install-space /opt/ros/melodic -j2. How can I solve and finish this installation sir? Thanks in advance and looking forward to ur solution for my issues very soon.
Here is my error---
CMake Error at CMakeLists.txt:19 (find_package):
By not providing "Findconsole_bridge.cmake" in CMAKE_MODULE_PATH this
project has asked CMake to find a package configuration file provided by
"console_bridge", but CMake did not find one.
Could not find a package configuration file provided by "console_bridge"
with any of the following names:
console_bridgeConfig.cmake
console_bridge-config.cmake
Add the installation prefix of "console_bridge" to CMAKE_PREFIX_PATH or set
"console_bridge_DIR" to a directory containing one of the above files. If
"console_bridge" provides a separate development package or SDK, be sure it
has been installed.
-- Configuring incomplete, errors occurred!
See also "/home/pi/ros_catkin_ws/build_isolated/class_loader/CMakeFiles/CMakeOutput.log".
See also "/home/pi/ros_catkin_ws/build_isolated/class_loader/CMakeFiles/CMakeError.log".
<== Failed to process package 'class_loader':
Command '['/opt/ros/melodic/env.sh', 'cmake', '/home/pi/ros_catkin_ws/src/class_loader', '-DCATKIN_DEVEL_PREFIX=/home/pi/ros_catkin_ws/devel_isolated/class_loader', '-DCMAKE_INSTALL_PREFIX=/opt/ros/melodic', '-DCMAKE_BUILD_TYPE=Release', '-G', 'Unix Makefiles']' returned non-zero exit status 1
Reproduce this error by running:
==> cd /home/pi/ros_catkin_ws/build_isolated/class_loader && /opt/ros/melodic/env.sh cmake /home/pi/ros_catkin_ws/src/class_loader -DCATKIN_DEVEL_PREFIX=/home/pi/ros_catkin_ws/devel_isolated/class_loader -DCMAKE_INSTALL_PREFIX=/opt/ros/melodic -DCMAKE_BUILD_TYPE=Release -G 'Unix Makefiles'
Command failed, exiting.
Reply 6 months ago
6 months ago
Thanks a lot for the post. And for the Raspberry Pi image!! It helps a lot!
Reply 6 months ago
Glad that it was helpful!
Question 11 months ago
I've meet with an error when build the catkin packages.
After this line of code
This error appeared,
/usr/bin/ld: cannot find -lcatkin::class_loader::wrapped-linker-option0
/usr/bin/ld: cannot find -lcatkin::rosconsole::wrapped-linker-option0
/usr/bin/ld: cannot find -lcatkin::rostime::wrapped-linker-option0
/usr/bin/ld: cannot find -lcatkin::cpp_common::wrapped-linker-option0
collect2: error: ld returned 1 exit status
make[3]: *** [Makefile:38: "/home/pi/ros_catkin_ws/devel_isolated/qt_gui_cpp/lib/python2.7/dist-packages/qt_gui_cpp/libqt_gui_cpp_sip".so] Error 1
make[2]: *** [src/qt_gui_cpp_sip/CMakeFiles/libqt_gui_cpp_sip.dir/build.make:61: /home/pi/ros_catkin_ws/devel_isolated/qt_gui_cpp/lib/python2.7/dist-packages/qt_gui_cpp/libqt_gui_cpp_sip.so] Error 2
make[1]: *** [CMakeFiles/Makefile2:566: src/qt_gui_cpp_sip/CMakeFiles/libqt_gui_cpp_sip.dir/all] Error 2
make: *** [Makefile:141: all] Error 2
<== Failed to process package 'qt_gui_cpp':
Command '['/opt/ros/melodic/env.sh', 'make', '-j2']' returned non-zero exit status 2
==> cd /home/pi/ros_catkin_ws/build_isolated/qt_gui_cpp && /opt/ros/melodic/env.sh make -j2
I'm currently using raspbian buster on a pi4 4gb
i tried to install ros kinetic before but i have meet this error as well when building the same package.
Answer 11 months ago
Hello! I'm not familiar with this particular issue. There might have
been some changes to ROS Melodic or Buster since I wrote this article.
If you don't need the latest version of Buster you can try using RPI 4
image I made
https://drive.google.com/file/d/1lcPBYgdFG7EuaIV23B2-7tL10EMizMD9/view?usp=sharing
Question 1 year ago
after writing the above command , the compilation get struck with error :
Failed to process package 'bondpy':
Command '['/opt/ros/melodic/env.sh', 'make', 'cmake_check_build_system']' returned non-zero exit status 2
==> cd /home/pi/ros_catkin_ws/build_isolated/bondpy && /opt/ros/melodic/env.sh make cmake_check_build_system
i am new to this so please help me ..
Answer 1 year ago
Hello! I'm not familiar with this particular issue. There might have been some changes to ROS Melodic or Buster since I wrote this article. If you don't need the latest version of Buster you can try using RPI 4 image I made
Reply 1 year ago
Thank you for your reply !!!!
so the image includes ROS Melodic + Buster?
and can I apply it on Rpi 4b?
Reply 1 year ago
Yes, correct!
Tip 1 year ago on Step 2
Thanks for this great summaryof the requierd fixes.
Following
all the commands in Step 2 it seems that the manually fix of the errors
by (cast floats to int) are not necessary anymore. The downloaded source
files (today 5 Jan.) already included the necessary casts from float to
int.
Reply 1 year ago
Thanks! Updated the article just now
1 year ago
Running
"find -type f -print0 | xargs -0 grep 'boost::posix_time::milliseconds' | cut -d: -f1 | sort -u"
from ~/ros_catkin_ws returns:
./src/ros_comm/roscpp/include/ros/timer_manager.h
./src/ros/roslib/test/utest.cpp
for me. Haven't gotten any further. I'm also running the bare bones installation instead of the desktop one, so perhaps that makes a difference.
(You might want to add the relevant commands for bare bones installations to that part of the process? Although they're not that hard to find. Also, presumably I won't need Ogre, since there's no rviz.)
Will comment again to update when and if I make it through tomorrow. (Fingers crossed)
Reply 1 year ago
It is a great guide DmitryM8, but I could differently use the
commands for the bare bone installation like SkyeP2 says. The reason is I am
totally new to ROS and can only figure out that I need to exclude desktop and RVIZ
stuff, but what else, if anything?
So if anyone can tell me what I need and don’t need
for installing the bare bone only, that would be much appreciated?
Reply 1 year ago
Well, that took longer than expected, but I got it to work. Bare bones installation lacks the sensor_msgs package, so I had to install that. I also had issues getting the connectivity to work correctly, for a number of reasons. Virtual box needed to be in Bridged Networking mode, had some DNS issues with one network and IP issues with another. roswtf came in handy there. And then finally I had issues getting rviz to pick up the data properly which were solved by reinstalling rplidar on the master (laptop). Well, it's all worth it. Thank you for the tutorial!
Reply 1 year ago
Perfect! So, you got it to work in VirtualBox?
Reply 1 year ago
Hey, sorry, I was out OOO for a few weeks.
Yes! I got it to work, but I've forgotten everything over the last month so I'll have to get it up and running again. After that I need odometry and object detection (front-mounted sonar sensor on a servo) and I should be able to get some accurate SLAM/autonomous navigation.
1 year ago
Hello.
I followed every single step until build the installation, and in this point I got the following error:
Executing the command that it says to me appears the following info:
How can I solve it and finish the installation?
Thanks in advane.
Best regards.
Alesandro
