Introduction: Radar Gun With Gyroscope.
This is a speed measuring device that can calculate speed using both a linear measurement and a angular measurement.
The material you will need include:
- 1 Arduino Nano
- 1 Ultrasonic Sensor
- 1 Small breadboard
- 1 Serial LCD (Or any display of your choice you will just have to make a slight modification to the code)
- 1 Gyroscope (I used a )
- 3D printer with filament to make the casing (optional)
Code and the .stl for the case: https://github.com/John-Alimoglu/SpeedCameraCode
Step 1:
Attach your Arduino Nano to the front of the small breadboard. Then glue the breadboard down so the USB port is accessible through the hole.
Step 2:
If required solder the pins onto your gryoscope. Make sure you use the straight pins not the 90 degree bent ones.
Step 3:
Install your Gyroscope next to your Arduino
Step 4:
Wire up the power pins on the gyroscope. Then wire SCL to A5 and SDA to A4. This allows us to receive info from the gyro.
Step 5:
Solder 4 wires on to your ultrasonic sensor then wire the ground one to ground, vcc to 5v, trig to pin 2 and echo to pin 3.
Step 6:
Push the ultrasonic sensor into its slot.
Step 7:
Wires the displays power pins then wire the RX pin to the Arduino Nanos TX pin
Step 8:
Use some wire, string or whatever you like to attach the screen to the box.
Step 9:
Add your switch into the slot in the lid and wire it to pin 4 and 5v.
Step 10:
Simply add the lid and run the code.
