Introduction: Radio Controlled Helicopter Testing Stand
Hi everybody and welcome to my Instructable... If you like it please vote...Thanks...
I found this old ceiling fan on the side of the road.
I took it apart and opened the motor. I removed the stator so the rotor would spin more freely...
Step 1:
I then cut a hole in a piece of plywood so the bottom of the motor would fit in. I then made up the sides so as this would form a base,...
Step 2:
I then made up a sort of clamp where the pole used to fit. I was going to use the original pole but was made of plastic and may not have been strong enough. I had some old tent poles which fitted the hanging bracket but even with the bracket tightened right up the pole still wobbled, so I needed to strenthen it...
I had to find a way to make sure the pole was vertical before drilling the holes for extra bolts. My router table and a spirit level did the job..
Step 3:
I used the piece ply I cut out earlier (to fit motor in) over the top of the poles to hold everything up. I used epoxy to hold it there.
I them made the top platform and fitted a block of ply to it with a hole for the small pole to fit in.
I put a small cup hook in to attach the platform to...
Step 4:
I fitted a short piece of chain to the small pole. I hooked this onto the cup hook in the top platform. This gave me a flexable joint so if the helicopter got airborne It could react to the controls without getting away....
Step 5:
I fitted a clamping device to hold the helicopter down.
