Introduction: Rainbow Illuminated Ruby Cake
Hii Guys,
Jelly cakes are a popular dessert among children. They come in many different flavors and designs, but it is safe to say that they are enjoyed by many people of all ages. Jelly cake is a dessert that is made up of jelly and cake. It can be made in many different ways and with many different flavors. It has many health benefits if the jelly cake made out of Gelatin means by using Agar Agar Powder or by using China Grass.
Agar agar powder is a vegetarian substitute for gelatin that is used as a gelling agent to thicken sweet and savory dishes. It is made from a type of seaweed called red algae, which is rich in calcium and also contains chlorophyll, red and blue phycoerythrin's. Agar Agar powder has several advantages over gelatin. Firstly, it is vegan-friendly and can be used as a substitute for gelatin in any recipe. Secondly, it sets at room temperature and effectively keeps its shape in warmer weather.
Agar agar powder also has several health benefits. It is low in calories but high in fiber, manganese, magnesium, folate and iron. It may also help improve digestive health, aid in weight loss and keep your blood sugar stable.
After seeing all these benefits I want to make cake a Ruby cube cake because most people and children love this game. So I thought it will be the right choice and Im very happy to share this instructable with you.
- Jelly Art Cake Tools
- Agar Agar Powder or China Grass
- Food Colors (Red, yellow, Green, Orange, Blue)
- Essence (6 Flavors)
- Sugar (150 gm)
- Injection with Needle
- Knife
- Moulds
- Some Patience
Step 1: Cake Design Expectations
- Follow the above images makes you easy.
Step 2: Jelly Preparation & Color Mixing Process
Important Note:
- Follow the video give you more info and clarity
- use 150gm of sugar for 1000ml of water
- You can try with you favorite colours and essence.
Procedure:
- Add 1000ml of water in bowl.
- Add 10mg Agar Agar Powder in those water and stir well.
- Leave it until 15min aside.
- Now Provide heat to the bowl on a medium flame.
- After the bowl reached 80degC add 150gm sugar and stir until dissolved.
- When the bubble starts, off the stove and remove the foam on the water.
- Now add colors and essence to water i.e whatever you want to mix is on you.
- Don't store the cake for more than 30 hours, the cake going to shrinks and compress itself
Step 3: & Moulding & Shaping Process
- Follow the video and take your own time to accomplish.
- Fill the Agar Agar Solution in molds.
- Dry it for 2 hours and Place in Fridge for 1hour.
- After drying flip the mold and take outside the cake using metal strips.
- Cut the Cylinder cake into Cube as 7.5cm x 7.5cm
- Cut the Colour Block into 18.75 x 18.75 each as 16 blocks for each side.
- Cut safely and exactly and take your own time while cutting.
- Make you own trace paper which makes your move easy and precise.
Step 4: Cube Design Process
- Follow the video, so you can easy make yourself.
- 16 Blocks are pasted at each face.
- So total 78 blocks were pasted.
- Use Syringe with needle to paste the blocks.
- Don't make think shake, the needle not able to pass the Liquid.
- Don't apply too much force on syringe, the needle will shoot outside.
- Apply the liquid before becomes solid.
Step 5: Illuminated Stand Making Process
- Following above video is the easiest way to make yourself.
- The strength of cake depends upon amount of agar agar powder used.
- Dont store the cake stand more than 30 hours, it loses its shape.
- Place a white below the stand from the centre.
- The light should easily pass on the cake while Cube cake is placed on it.
Step 6: Showcase
- The cake is illuminates due to its nature of transparency.
- ENJOY THE YUMM YUMMY CAKE
