Introduction: Rainbow Loom Poodle
PLEASE follow and like!!! HONEST FEEDBACK PLEASE! This is the rainbow loom Poodle! Remember to check for updates! Make sure your loom looks just like the pictures! NOT ALL PICS ARE MINE!!!! I'm still kinda new to the instructables app
Step 1: Materials
You will need:
A loom
A hook
Rainbow bands
A clip
A loom
A hook
Rainbow bands
A clip
Step 2: Colors
You could use ANY colors you want but I'm going to use(just replace the colors listed below with your colors):
Purple: fluffy hair/fur
Black: eyes and nose
White: shaved part of fur/hair
Step 3: The Poodle's Legs and Arms
Take a rubber band( I'm using white) and twist it into a figure 8. Then put the two holes of the figure 8 together to form a cap band and place it on two pegs horizontally. The legs and arms are made the same way and all of the rubber bands used for the arms and legs should be going horizontally.Continue placing the rubber bands about 3 more times and add a cap band that is looped on the last peg 3 or 4 times and loop them like the extensions of a rubber band bracelet. Then take it off the loom and place it on a tooth pick. Repeat the steps until you have 2 arms and 2 legs that look the same
Step 4: Beginning
Make sure the arrow(if your using a rainbow loom) of your loom is pointing TOWARDS you.(pointing at you) and place 2 rubber bands(the color of your poodle's fur) on the top and bottom pegs that surround your loom's arrow
Step 5:
Now place 2 more on EACH side(make sure it matches the picture!)
Step 6:
Now (use the color of the poodle's SHAVED fur) place two rubber bands going horizontal in the middle row of pegs( from this point on, you have to double all or your rubber bands) and 1 rubber band on each side
Step 7:
Now place 1 rubber band from the sides to the middle(remember to double the rubber bands!) diagonally
Step 8: The Poodle's Neck
Now place 3 rubber bands(instead of doubled it is tripled) in the middle row of pegs
Step 9: We're Doubling the Bands Again!
Remember to double the bands again! Place (the color of poodle fur that is NOT shaved) a rubber band from the neck to the right going diagonally then do the same from the neck to the left
Step 10:
Now place one rubber band from the neck horizontally in the middle row of pegs(doubled and the same color of poodle fur that isn't shaved).
Step 11:
Now place 2 doubled bands to all of the rows.( color of an unshaved poodle fur)
Step 12:
Now place 2 doubled bands( color of shaved poodle) in the middle row. Then add 3 doubled bands to the left and right rows
Step 13:
Now place ( the color of shaved poodle fur) a doubled rubber band diagonally from left to the middle. Then do the same from the right to the middle
Step 14:
Then put the legs on the last left and right rubber bands
Step 15:
Then place the arms on the last UNshaved poodle fur colored rubber bands on the left and right rows
Step 16:
Double bands!Just look at the pictures it explains it all!
Step 17:
Single band! Look at the picture!
Step 18: Muzzle
Now take your hook and wrap a black rubber band around it 4 times. Then take an unshaved poodle colored rubber band and put it on the curved part if the hook. Then slide the black rubber band onto the other rubber band and place the other rubber band fully onto the hook. Then place the muzzle onto the rubber band above the neck that is triangle shaped
Step 19: Looping!
On the left row, reach in the hole and push it back. Then grab the top two on the peg and pull it out. Then loop it to the middle peg. Do the same to the other side
Step 20:
Then loop the right and left rows horizontally until you've reached the diagonal rubber bands
Step 21:
Now loop the diagonal rubber bands! After that, loop the middle row until you've reached the neck!
Step 22:
Now loop the neck! Then loop the top two rubber bands. Repeat that 2 more times. Then loop the sides and middle. DONT loop the top middle though!
Step 23:
Now place two poodle hair colored cap bands on the second row in the middle. Then loop the last middle rubber band.
Step 24:
Now move the top left and top right rubber bands to the middle
Step 25:
Now place and pull a rubber band from the hole in the top middle row. Make sure to knot it!
Step 26: Not Done Yet!
Now pull the poodle off the loom! Now you could stretch it and rearrange it to make it look better! And tug gently on the muzzle!
Step 27:
Wrap your rubber band 4 or 3 times!Look at the picture!
Step 28:
Do that 2 more times. You will end up having 3. Look at the pictures! Repeat it with the other side
Step 29:
Step 30: Eyes!(optional)
Step 31: Done!
Now your done! If you want to do this again without taking the time to read this, here's a picture guide!;)
