Introduction: Rainbow Loom Fishtail
Step 1: What You Need
For this design, you will need a...
a hook
a loom
rubber bands
'C' clips
a hook
a loom
rubber bands
'C' clips
Step 2: Placing the Rubber Bands
For this design you can also use the mini loom but I find it easier to use the Rainbow Loom.
All you need is any two arrows on the loom.
Take ONE rubber band, twist it so it's like an 8 and put it onto any two arrows on the loom.
Put TWO rubber bands on the same arrows as the one you put the 8 on.
Step 3: Starting
Take the hook and grab the twisted rubber band on the bottom and drag it onto the top.
Step 4: Hooking the Rubber Bands
Next, add another rubber band, any colour, onto the top of the other rubber band.
Step 5: Hooking the Rubber Bands
Repeat step 3. Take the bottom rubber band and drag it to the top.
Step 6: Hooking the Rubber Bands
Repeat step 4. Place another rubber band.
Step 7: Hooking the Rubber Bands
Repeat step 3. Drag the rubber band from the bottom to the top.
Step 8: Hooking the Rubber Bands
Continue doing this until you think it's long enough.
Step 9: Finishing
Now, there should only be TWO rubber bands on the arrows. Take the bottom one, for me it's white, and pull it to the top WITHOUT adding any other rubber bands.
Step 10: Finishing
Take the last rubber band, for me it's black, and put it onto your hook.
Step 11: Add Clips
Add the 'C' clip and your done! :)
Sry this is small. Just add more rubber bands and it'll be longer. ;D
