Introduction: Rainbow Loom Goldfish Charm
PLEASE like and follow!!! You will need 39 rubber bands + a rubber band for the eyes + an extra rubber band to hold it all together
Step 1: Materials!!!! :D
YOU WILL NEED:
A LOOM
A HOOK
RAINBOWBANDS
A LOOM
A HOOK
RAINBOWBANDS
Step 2: Colors!
You could use any colors you want! <3
Step 3: Placing the Bands
Make sure the arrow on your loom is pointing AWAY from you!!!
Step 4:
Place 2 rubber bands from the bottom middle peg to the right diagonally! Do the same to the left side! Then place 2 rubber bands from the bottom middle peg forward.
Step 5:
Then place 2 rubber bands from the middle forward. Do the same to the left and right. Repeat that ONCE! Now place 2 rubber bands from the left forward. Do the same to the right!
Step 6:
Now place a SINGLE rubber band from the middle forward! Then place a SINGLE rubber band from the right to the middle diagonally! Do the same to the left side!
Step 7:
Now place 2 rubber bands from the middle to the right diagonally! Do the same to the left side!
Step 8:
Then place a SINGLE rubber band from the middle forward!
Step 9:
Now place 2 rubber bands from the left forward! Do the same to the right side!
Step 10: The Eyes!
This is optional! Grab a SINGLE rubber band and place it on the second bottom peg on the left to the right. Then drag the middle of the eyes to the third peg in the middle row.
Step 11:
Now take 2 rubber bands and place them from the middle of the eyes to form a triangle(look at the pictures!) then take a single and and form a figure 8 by twisting it. Then place the 2 holes of the 8 together to form a doubled O! Then place it below the triangle you placed earlier. Make sure it is also a triangle!
Step 12:
Now take 2 rubber bands and place it from the left to right ABOVE the triangle you just placed! Look at the pics!
Step 13:
Now take a SINGLE rubber band and twist it 2 times to have a tripled O! Place it on the top left rubber band. Do the same to the right side!
Step 14: Looping the Rubber Bands! :D
Now flip the loom so that the arrow is now pointing at you.
Step 15:
Place your hook in the left cap band and grab the two rubber bands and loop it forward! Then loop the 2 rubber bands that are in/under the bands you just looped to the middle diagonally! Do the same to the right side!
Step 16:
Now loop the middle single band forward!
Step 17:
Reach under/in all of the looped bands and loop the top single band to the right diagonally! Now reach back in and pull another single band and loop it to the left diagonally! Loop the last single band forward!
Step 18:
Now loop the right rubber bands forward until you reach the top of the right row! Then loop the last rubber band to the middle diagonally! Do the same to the left side!
Step 19: Almost Done!!! ;)
Now loop the rest of the middle row until you reach the top! Then take a single rubber band and knot the top( if you don't know how, comment or look at my other instructables!) Then CAREFULLY take the charm off the loom! Now you're done!!! PLEASE FOLLOW AND LIKE!!!! Enjoy your charm! You might want to stretch and/or adjust your charm! <3
