Introduction: Rainbow Loom Hexagon Line
This bracelet is pretty easy, I tried to add instructions in words but most of it is in pictures. I think I made this one up, if you have seen any other bracelets like this, just to let you know I did not use any sort of video or instructions to make this bracelet. If someone's made the exact same one I did not copy I made this one up.
Step 1: Things You Will Need
You will need your loom a hook the elastic bands and a c clip. (Or S clip)
Step 2: Laying Down Your First Bands
Start by placing one band from the middle then up and repeat. Make sure to have your arrow facing away from you.
Step 3: The Hexagon
Put your first band from the middle to the left then your second band from the middle to the right. Then take another band and place it on the left side (where the one on the left just ended ^) then up, then from the one you just put on to the middle and up. Do the same thing on the right side.
Step 4: A Capping Band
Take one band twist it like a figure 8 then put both loop onto the very last one
Step 5: The Hooking
Now here is the tricky part, look at the picture for each step.
