Introduction: Rainbow Loom Ladder Bracelet
Step 1: What You Need
You will need:
• a loom
• rubber bands
• a hook
• an S or C clip
• a loom
• rubber bands
• a hook
• an S or C clip
Step 2: Placing Bands
Take your first band and place it going to the left. Then take your second band and place it to the right. MAKE SURE YOU ARROW IS FACING AWAY FROM YOU!! Then continue putting bands on both left and right pegs tithe second to last peg. When on the second to last peg, place the bands inwards so it is on the middle peg.
Step 3: Next
Place the same colored band across the second left peg to the second right peg. Skip the first two left and right peg. Continue to place them across till you reach third to last peg on both left and right sides. Skip the last on before reaching where it goes towards the center.
Step 4: Then
Next place your middle colored band all forward the center pegs. Stop where it turned to the middle
Step 5: Loooping
Place a cat band on the end of the center pegs. Then turn the loom around so the arrow is pointing towards you. Then start looping to the end
Step 6: More Placing
Place rubber bands across on top of the other cross bands.
Step 7: More Looping
Start from the cat band and loop the bottom bands to the corresponding side. Then loop the bottom bands from the left and right pegs forward to the end then loop them to the center.
Step 8: Taking It Off
Put the hook through all the bands on the last canter peg. With a rubber band at the end. Pull that band through and place it on your hook. Then take the bracelet off.
Step 9: Extension
Place four bands going forward on any side peg not center. Make sure the arrow is facing AWAY from you. Then place on of the ends from your bracelet on the end of the four bands. Turn the loom around and loop the band. Then place an S or C clip on one end and secure them together.
Step 10: END
Hope you enjoyed and made a bracelet! Please leave a comment, like, and follow. Thanks for just viewing!
- rainbowloomer
- rainbowloomer
