Introduction: Rainbow Loom Ring- EASY
Easy Breezy Rainbow loom ring using different colors!
Step 1: Placing the Bands
Place the bands from left to center, always start to the left.
Step 2: Putting Capping Bands
twist the band 2x , and dont forget to put another capping band in the left peg.
Step 3: Hooking Process
Pull the capping bands using ur hook slowly towards you. Hook the bands like doing single bracelet.
Your loom should look like the 3rd photo.
Step 4: Adding Rubber Band
Use your hook to do this process.
Step 5: Removing It From Your Loom
Gently remove your bands from the loom to avoid it snapping.
Step 6: Twisting Process
After removing, remove the purple band on the hook, and insert the band on the peg, then twist it like i did on the 2nd photo.
Step 7: Securing Process
Use c- clip or s-clip, attach it to the purple bands, as seen on the 1st and 2nd photo
Step 8: Tadaaa!
Now this is the product.
