Introduction: Rainbow Loom Triple Single Tutorial
Hello :D
This is my second tutorial on Rainbow Loom :D
please enjoy and please fell free to comment below :D
<3 Dinocorn27 (Bianca)
Step 1: Materials
What you will need:
1 Loom Board
1 Loom Hook or Crochet Hook
Loom Bands
1 S or C Clip
Step 2: Base
Make sure our board is thee right way first. The arrows should be pointing upwards.
Start creating the base by placing your bands to the pin in front of them. (The pictures make more sense)
Continue until you have reached the top of your loom.
Step 3: Triangles
Turn your loom bard around so the arrows are pointing towards you.
Start creating you triangles using 1 colour. I chose white.
Do not add a last triangle.
You should finish on the second last of each loom rod.
Step 4: Looming
Start to on the bands to the pins in front of them.
Continue this until you have reached the end.
Step 5: Pulling It Off
Before you pull it off, move the bands on the last left pin to the central pin. Do this for the right side as well.
Take a single band (the colour that you used for triangles.
Stick your hook through the bands on central pin and hook the band through,
Don't entirely pull the band through, pull it just enough where you can grab the other side if thee elastic in the bottom and hook it onto the hook as well.
Gently pull it off.
Step 6: Extension
Firstly, replace the hook with two fingers and add a c or s clip to secure one end of the band..
for the extension you will only need 1 rod.
Make sure the rod is the right way up.
Start to make an extension. I only used 4 because i have a small/medium wrist.
Turn the loom around.
Put that on the closest band towards you.
Start looming it to the band towards you. make sure for the first one, you do not gt the bracelet, instead you get the band below it.
Gently pull it off and secure with s or c clip.
Step 7: Finished
Enjoy your new Triple Single Rainbow Loom Bracelet.
Please comment down below feedback and any requests :D
Thanks
<3 Dinocorn27
Bianca
