Introduction: Rainbow Loom:Triple Single
So this is my favorite design and I want you all to learn it too. You have seen the single design but now you have to make its triple!
DUE TO LIMITED BANDS I WILL NOT FILL THE WHOLE LOOM WHICH MAKES A RING!
Latest Tutorial: https://www.instructables.com/id/Rainbow-Loom-Railr... (Railroad Bracelet)
Like my Facebook page: https://www.facebook.com/rainbow.looms.by.sara
Step 1: Gather Your Things
You'll need
- Rainbow Loom
- Hook
- S clip OR C clip
Step 2: Placing the Bands
Place the loom in a fact that the arrows are facing away from you
Add two bands diagonally at the end as shown
Then add straight bands as shown till the end of the loom
DUE TO LIMITED BANDS I WOULD END AFTER 6 TO 7 COLUMNS
Afterwards, place the background band in a manner that their arrow is facing towards the end of the loom
Step 3: Add the Cap Band
Make a shape of an eight and transfer both ends on one finger. Stretch it and place it on last middle peg.
Step 4: Match the Look
Your loom should look like as shown.
Step 5: Looping the Bands
Push your hook through the cap band and the two bands bottom to it and pick the last band. Loop it to the next,
Do the same for the sides
Do the same for straight lines in all three rows
It should look like as shown
Step 6: Remove Your Band
Push your hook through the bands
Add another band on the end if the hook
Both ends of the band should be on the hook.
Hold every band on the peg and remove them. (all three rows)
KINDLY DONT REMOVE FROM THE HOOK
Step 7: Extension
Add a band from top to bottom and do the same with 5 or 6 more bands (maximum) on the same row.
Use the band on the hook as the cap band
Loop the bands as you did before. Push your hook through the last one and remove
TA-DA!
