Introduction: Rainbow Mimikyu! Free Crochet Pattern
A pastime of mine is developing patterns for different crochet Pokémon. My latest pattern was Mimikyu, and I decided to use one of my multi-colored O'Go skeins to create a unique stuffed animal. This pattern is a 3.5/5 in terms of difficulty, as some of the techniques used for the more intercut features utilize techniques that may be difficult for beginners. I hope you find this pattern as fun as I found!
- 4.5 mm crochet hook
- Rainbow O'Go red heart super saver yarn
- Big Twist value yarn in color burgundy
- Darning needle
- Regular needle
- Red/Black thread
- Stuffing
Abbreviations you'll need to know
sc - single crochet
inc - increase
dec - decrease
mg circle - magic circle
ch - chain
Step 1: Mimikyu Body
- Mg circle 6 (6)
- inc x 6 (12)
- (sc, inc) x 6 (18)
- (2sc, inc) x 6 (24)
- (3sc, inc) x 6 (30)
- (4sc, inc) x 6 (36)
- (5sc, inc) x 6 (42)
- (6sc, inc) x 6 (48)
- 48sc (48)
- 48sc (48)
- 48sc (48)
- 48sc (48)
- (7sc, inc) x 6 (54)
- 54 sc (54)
- (7sc, dec) x 6 (48)
- (6sc, dec) x 6 (42)
- (sc, dec) x 12 (30)
- (sc, dec) x 10 (20)
- 20sc (20)
- 20sc (20)
- 20sc (20)
- 20sc (20)
- (4sc, inc) x 4 (24)
- 24sc (24)
- (5sc, inc) x 4 (28)
- 28sc (28)
- (6sc, inc) x4 (32)
- 32sc (32)
- (7sc, inc) x 4 (36)
- 36sc (36)
- (8sc, inc) x 4 (40)
- 40sc (40)
- (9sc, inc) x 4 (44)
- 44sc (44)
- (10sc, inc) x 4 (48)
Keep yarn attached, do not cut yet
Step 2: Mimikyu Flaps
- Crochet 8sc onto the body
- Reverse, dec, 6sc
- Reverse, dec, 5sc
- Reverse, dec, 4sc
- Reverse, dec, 3sc
- Reverse, dec, 2sc
- Reverse, dec, sc
- Cut and weave ends
- On the stitch next to the finished flap, weave into the body once again (shown in the picture) and repeat these steps until 6 flaps have been made
Step 3: Mimikyu Bottom
- Mg circle 6 (6)
- inc x 6 (12)
Next, repeat the step 2 to create 6 flaps around the bottom
Then, sew the bottom and body together, aligning the flaps. Before fully closing, stuff to desired firmness. I chose to stuff less firm in the neck so that he can tilt his head.
Finally, cut and weave the ends.
Step 4: The 'Face' and the Face
To make Mimikyu's actual eyes, sew two vertical lines, about three rows tall, 8 stitches apart, in around the middle of the body.
For the costume's face, chain one strand of 20, and one of 15 in burgundy. Take some scraps of red yarn and chain two strands of 15. I then took a strand of burgundy yarn to stand in place as the mouth before I sewed it in. I then pinned all of the pieces into place, before using a needle and thread to sew down the eyes and cheeks. I pinned the cheeks and eyes in a spiral to mimic the scribbled face of the actual Pokémon. Finally, I used the darning needle to sew the mouth. After this step, you can set the body aside as you work on the pieces to be added to the piece.
Step 5: Tail
Create two of the following:
- Ch 4 (4)
- Ch 1, 4sc (4)
- Ch 1, 4sc (4)
- Ch 1, 4sc (4)
- Ch 1, 4sc (4)
- Ch 1, 4sc (4)
- Ch 4, then reverse and sc 5, skipping the chain closet to the hook (5)
- Ch 1, 5sc (5)
- Ch 1, 5sc (5)
- Ch 1, 5sc (5)
- Ch 1, 5sc (5)
- Ch 1, 5sc (5)
- Ch 6, reverse, sc 8, skipping the chain closest to the hook (8)
- Ch 1, 8sc (8)
- Ch 1, 8sc (8)
- Ch 1, inc, 6sc, inc (10)
- Ch 1, 10sc (10)
- Ch 1, inc, 6sc, inc (12)
- Ch 1, 12sc (12)
Cut off and weave ends
Create one of the following:
- Ch 3, 2sc (2)
- Ch 1, 2inc (4)
- Ch 1, inc, 2sc, inc (6)
- Ch 1, 6sc (6)
- Ch 1, 6sc (6)
- Ch 1, 6sc (6)
- Ch 1, 6sc (6)
- Ch 1, 6sc (6)
- Ch 1, 6sc (6)
- Ch 1, dec, 2sc, dec (4)
- Ch 1, 2dec (2)
- Ch 1, 2sc
Cut off an weave ends
Start by sewing the oval to both tops of the sides of the tail. Then, sew down each side, stuffing as you go.
After the tail is fully sewn and stuffed, pin to the flap at two O'clock. (In a top-down view of plush, the flap that would point to two on a clock. For further clarification, the final image in this set should be helpful). Finally, sew onto the flap.
Step 6: Ears
Make one of the following:
- Mg circle 15 (15)
- 15sc (15)
- 15sc (15)
- 15sc (15)
- 15sc (15)
- 15sc (15)
- 15sc (15)
- 15sc (15)
- 15sc (15)
- 15sc (15)
- Change to burgundy
- 3inc, 3sc, 3dec, 3sc (15)
- 2inc, 2sc, 4dec, 3sc (13)
- 13sc (13)
- 3dec, 2sc, 2inc, 3sc (12)
- 2dec, 3sc, 2inc, 3sc (12)
- (sc, dec) x 4 (8)
- 4dec (4)
Cut and weave ends
- Mg circle 15 (15)
- 15sc (15)
- 15sc (15)
- 15sc (15)
- 15sc (15)
- 15sc (15)
- 15sc (15)
- 15sc (15)
- 15sc (15)
- 15sc (15)
- (sc, dec) x 4 (8)
- 4dec (4)
Cut and weave ends
(I decided to make two slightly different ears to make him look slightly more scraggly. If you would prefer to make the same set of ears, then just make two of either pattern.)
Next, pin them onto the head in the orientation you like.
Sew them on
Cut and weave ends
