Rainbow Wood Magnetic Knife Strip
Intro: Rainbow Wood Magnetic Knife Strip
This is a magnetic knife strip that is made from cut-offs of fine hardwoods that I had lying around the shop. Glue them all together and you get something I'm calling rainbow wood. It also has a line of rare earth magnets embedded in it so it's got surprisingly strong knife-holding power.
My issue with conventional knife holders is that they're often covered in metal, which means that there's the potential for the blade edge to get a nicked or damaged. That's just simply not a possibility with this wooden one. Furthermore, the ones that are made of wood are often cheaply made with weak magnets that don't sufficiently hold large 8" or 9" chefs knives. This knife holder does double duty as being both uniquely decorative, and is a step up from what's commercially available.
STEP 1: Make Stock Material and Cut Off a Strip
This knife hanging strip was made from a piece of scrap, scrap wood material. First, make a bunch of scrap wood material as described in this instructable here. Then, cutting across the board and using a sled so that the wood doesn't bind, cut a strip of scrap material off of the end. For a very long knife strip, or if your scrap wood blank is particularly short, cut two and glue them together.
Other tools this Instructable will require are basic wood working tools like:
Other materials this Instructable will require are
Quantities of these materials depends on the scale of the project.
- miter saw
- table saw
- router and router table
- palm sander
- various clamps
- Elmer's® Carpenter's® Wood Glue
- rare earth magnets (.5"x.5"x.125")
- two part epoxy
- scrap wood
- food safe wood finish
- keyhole hangers
STEP 2: Miter Saw Edges to Prepare for Gluing
I made a large knife rack that uses two strips glued together. Before gluing the two strips end to end to make one long one, I chopped the edge to be glued on the miter saw to make sure it was absolutely square.
STEP 3: Glue Two Strips Together (if Necessary)
Glue the ends of the two strips together and clamp them well using another strip of wood to act as a caul opposite the clamp.
STEP 4: Sand Off the Glue
Using 80 and 120 grit sanding discs, sand the strip and remove any glue marks. There's no need to go much higher in grit since the finishing sanding can be done just before applying the finish.
STEP 5: Cut a Groove
Cut a groove or rabbit in the strip using a router and a 1/2" straight bit. I used a router table to do this and set the fence so that the bit would rund down the middle of the strip. The feather boards help to make sure that thin strip of wood is held securely in place as it is run through.
Make multiple passes, cutting deeper with the router on each one. Remove material until you come within a comfortable distance of the top of the strip. The goal is to leave as little material as possible in place, as this will be the barrier between your magnets and your knives. Less material = more holding power. I came to within a 1/8th or so of the top of the strip and my magnets have plenty of holding power on the knives.
STEP 6: Cut a Spline That Fits
With the grove cut, it's time to cut a spline that will fill that space once the magnets have been inserted. With a few test magnets in place for thickness, measure the length, width and depth of your channel. Then, using some scrap material and a table saw, cut a spline that fits those dimensions. I cut the length on the spline on the chop saw. The spline should fit in place smoothly and easily. It should not be a tight, pressure fit, as it's held in place with epoxy in a later step.
STEP 7: Cap With More Scrap Material
Grab two more short pieces of scrap material that are cut to sizer and cap the ends of the strip. Use a caul along the back of the strip to make sure that the (3) pieces you are now gluing together are well aligned and true.
Sand off of any glue marks after the clamps have been removed and the glue has set.
You can avoid this step by cutting your grove with a router and plunge base, and not routing out material all the way to the end of your strip. Gluing on end caps wasn't too big of a chore for me, so I just quickly zipped it through the router table in step 5.
STEP 8: Round Over the Edges
Using a round over bit, a router, and a router table, pick the nicest side of the wood strip and round over the edges on that side. The round over bit I used has a bearing that controls the cut, however I used the fence set to the same depth as the bearing for added stability. Since the bit was removing such a small material, I did this in one pass, without the use of feather boards since the wood is easy to control my hand.
One thing I do recommend is to use a sacrificial piece of wood as a followthrough to reduce tear out when you get to the end of a pass.
STEP 9: Sand the Strip With Random Orbital Sander
Now it's time to do the finishing sanding. Using 120, 180 and then 220 grit sanding discs, sand the entire strip and remove any marks from the clamping, gluing and routing.
STEP 10: Insert Magnets
The hardest part of making this knife strip was working with the rare earth magnets. They have a surprising affinity to stick to one another and will *snap* together unexpectedly. That being said, they do attract to one another end to end, so they can be carefully laid out.
Lay the magnets out into strips making sure to keep all the poles going in the same direction. You can tell this easily because if the poles are misaligned, the magnet will repel the one adjacent to it. If it attracts, you know the poles are good to go.
The magnets I'm using are 1/2" W x 1/2" L x 1/8" thick rare earth magnets.
I wanted to make registration points for certain large knives that I own and make sure that there would be no chance of knocking one knife into another when placing them on the strip. To do this I made sections, or small clusters of magnets that were seperated by short sections 1/8" acrylic material. The acrylic spacers allow me to control the groups of magnets. See 3rd photo and photo notes below for more detail.
Lay out the strip of magnets and then gently transfer them into the bottom of the groove. Insert spacers (optional) as you see fit to create knife groupings or clusters.
STEP 11: Epoxy Magnets in Place
Using a quick set 2-part epoxy, glue the magnets into place inside the knife strip.
STEP 12: Glue Spline in Place
Using more of the same epoxy, glue the spline into position on top of the magnets. This will hold all the magnets in position forever.
Apply clamps and let the epoxy set. I used masking tape to protect my clamp heads so that they wouldn't become epoxied in place from any squeeze out that might occur.
Once the epoxy has set, remove the clamps and sand off any glue marks.
STEP 13: Apply Food Safe Finish
Apply a food safe finish, such as mineral oil or butcher block oil. I'm using a gel varnish here that's FDA approved called "Good Stuff" which I quite like since it's easy to work with, doesn't drip, and results in a nice satin finish.
Let your finish dry and repeat for a second coat if necessary.
STEP 14: Drill Cut Outs for Flush Mount Hanging Bracket
I didn't want to interrupt the face of my knife rack with mounting hardware, so I opted for keyhole hangers, also called keyhole brackets, which slide and lock into place on any screw head. These hangers need to be mounted flush to the back of the knife strip so used the drill press with a forstner bit to remove the bulk of the material, and then did a cleaning up of the recess with a hand chisel. I used two of them mounted at either ends of the wooden strip.
Apply blue painters tape to any at-risk surface to avoid scratching the strip in these final few processes.
Drill three holes with a forstner bit that matches the exact outer radius of your keyhole hanger, making the center hole a touch deeper to allow for the screw head.
STEP 15: Use Chisel to Finish Cut Outs for Hanging Bracket
Clean up the small chunks of wood between the circles with a hand chisel. Test fit the keyhole hanger in place.
STEP 16: Mount Bracket
Mount the bracket using a Vix Bit, or self-centering pre-driller which will ensure that the holes for your hardware are exactly in the correct position and some short wood screws. Make sure not to drill too deep.
If you haven't used a Vix Bit before, you should give them a shot - they are perfectly designed for this application and are quite pleasing to use. They self-center!
STEP 17: Set Anchors in Wall and Hang in Kitchen
The keyhole hangers simply need two screw heads to lock on to. I've got drywall in my kitchen wall so I used some plastic plugs and 1.5" screws to secure the strip in place. Use a level to make sure that the knife strip is level and hang away.
The keyhole hangers push the strip away from the wall ever so slightly and when placing or removing a knife from the strip, the strip did a little shimmy. I used the soft side of an adhesive velcro strip as a thickness pad to take up the room between the strip and the wool - worked like a charm.
If you make your own magnetic knife rack post it in the comments below - I'd love to see what you come up with - so post photos please! Thanks for reading and leave comments with questions if you've got them.
40 Comments
IrmaA7 6 years ago
Thesyvertsons 8 years ago
If not noted yet, you can get various kinds of hardwood from pallets. I've gotten cherry, oak, walnut, pine and several others I wasn't able to identify for free from disassembling and sanding pallet pieces parts. FYI! :)
RobertW162 8 years ago
zerzig 7 years ago
Not all pallets are treated with chemicals, FYI. Heat treated pallets are safe and are marked "HT". All Canadian pallets are heat treated.
SeanD137 7 years ago
Hi there,
Love this idea and will be making one out of oak, but I don't know enough about magnets. I'm afraid I will by the wrong kind or magnets that are too weak.
Are these what you used? They say 6 lb Pull strength? http://www.rare-earth-magnets.com/magcraft-nsn0911
ata1anta 8 years ago
Absolutely stunning! This came up looking for a spice rack project (guess I'll be writing my first instructable). However my only power tools are a drill and a dremel so when I have wood projects, I take advantage of the very nice people at HD to cut my pieces to size. ;)
So, do you have an etsy page???
jsaul2 8 years ago
wizawuza 9 years ago
Going to try my hand at this project when I move into my new place (another couple of months).
Have you put any thought into two rows of magnets, to help prevent the knives from rotating? Or is that not a concern with the strength of these? Right now I have a store-bought block (http://benchcrafted.com/Magblok.html), great quality, but the knives can rotate if I'm not careful.. plus I like the lack of visible holes on your design.
shazni 10 years ago
https://www.instructables.com/id/Reclaimed-Wood-Magnetic-Knife-Rack-1/
it said D55
jonficke 9 years ago
N35 is just a classification of magnet strength family. The best way to think of it is that the number after the N sets the upper bound on how strong the magnets in that classification could be. Example with made up numbers: An N35 magnet might have a pull strength from .1 to 10 lbs. An N 37 magnet might have a pull strength from .25 to 15 lbs.
If your magnet is directly in contact with your knife, then you need a pull strength at least as strong as the weight of the knife but not so strong you struggle to pull the knife off the rack. I hide the magnets behind hardwood on mine, so I use very strong magnets as the pull strength is weakened by going through the wood. http://warriorwoodwork.blogspot.com/2013/11/zebraw...
I use magnets with almost a 40 lb pull strength.
txgrinch 9 years ago
This is a brilliant design and will be perfect for my holiday gifts this year. Unfortunately, I have to make a bunch (30) and am wondering whether I need the 40 lb pull strength. Can I go with something less to keep the cost down?
How long do you usually make the board? I was thinking 12 to 15 inches.
Lufkum 10 years ago
Just to cut a step I would not cut the groove till the end so I don't need to cap it
Nice project!
marstery 10 years ago
clazman 11 years ago
I love your attention to detail, such as the velcro strips to act as "springs" to preload the mounting. Very nice! Af\ter my own heart!!
supersoftdrink 11 years ago
Your "rainbows" could probably stand a little inclusion of argentine osage orange and some pink ivory, though.
wilheln 11 years ago
noahw 11 years ago
nmvb 11 years ago
sarawelder 11 years ago
flamesami 11 years ago
