Introduction: Raised Garden Beds (and More!) From Reclaimed Wood
The fence in my back yard was already half collapsed when I bought my house last year. I figured I'd take care of it eventually, but this winter when a wind storm came through it went from one section already on the ground with two more halfway there to four sections (around thirty feet) down.
There were lots of old rusty nails sticking out all over the place in a spot right next to my daughter's playground, so I decided I'd better do something about that. Without a truck readily available, I decided I'd just remove all the nails from the lumber and make a pile of it somewhere until I had an opportunity to take it down to the wood recycling place.
As I was pounding nails out of boards, I realized that a lot of the pickets, posts and stringers, while not in great shape at the top or bottom, were in relatively good condition for most of their lengths. After disassembling a couple of sections of fence I had a pretty good pile of cedar that, while not any good for building furniture or houses out of or anything like that, were still solid enough that the idea of just sending them away to be chipped and mulched kind of grated on me.
My mind began to churn, what could I build out of all that still perfectly serviceable wood? I later on decided I'd rebuild that entire fence and pulled down even more boards, until the pile got really big. I settled on structures for my garden, and this instructable was born!
Step 1: Get Some Old Wood
Old beat up lumber is actually very easy to find. As I mentioned, I got most of mine from the old fence in my back yard, but I sourced some 2x6's from a couple of other places. My dad had several redwood 2x6's from an old barn (I think) that he offered to bring me. Also, a coworker had torn down part of his house to make way for new construction, so I spent a profitable morning with a sledge hammer pounding fir 2x6's out of what used to be his roof. I thought if I needed more lumber I might use pallets or even put up an ad on craigslist offering to remove someone's old fence in exchange for the boards, but those sources weren't needed this time. I've still got plenty of wood in the pile next to my shed!
In addition to the wood you'll need:
Woodworking tools (tablesaw, circular saw, drill, etc)
Hammer (and an anvil if you have one)
Tape measure
Pliers
Square
Level
Pry bar
Eye and ear protection
You'll most likely need some wood glue and maybe some more nails, but you'll get a lot of those from the next step.
Step 2: Prepare the Wood
This is the part where you turn old crappy fence boards or rafters into usable lumber. You'll also be salvaging a lot of perfectly good (if a bit rusty) nails.
Make sure you wear eye and ear protection for this! Impact sounds from repeatedly hammering wood are particularly bad for your ears, and every time you try to pry a rusty nail out of a board you run the risk of breaking the head off and getting an eye full of steel. Seriously, a good friend of mine had exactly that happen and it messed up his vision something awful!
First, turn the wood over and tap the nails from the pointy end out as far as you can. If you're doing this to old fence boards, a lot of the nails will just fall right out a this point. I kept a speaker magnet lying in the area where this was most likely to happen so as to avoid the possibility of stepping on nails. I have done this before and don't recommend you make the same mistake. Flip over the board and use the pry bar or the claw end of your hammer to remove the nails the rest of the way. I also kept a bucket handy to throw these nails in, to be sorted and straightened out later, as many will probably still be usable.
Once you've got a good stack of boards, pull out your circular saw or bring them to your table saw. Safety first! I hate to keep harping on this sort of thing, but I have an uncle with two and a half fingers. He lost the rest in a table saw many years ago. If you go that route, use push sticks or a fence where possible. Don't worry about getting a square cut at this point, as you're not finishing the lumber yet, just cutting off any parts that are too rotten or split to be used. After I was done I was left with a big pile of bad lumber and a bunch of boards that were relatively solid. I ended up giving the bad stuff to a friend with a wood stove, as they made great kindling.
Now you've got a whole lot of lumber that will be great for outdoor construction! The next steps will show the various things I built out of my old fence and the other wood I acquired.
Step 3: Raised Garden Beds
I've been told that in the overly wet western Oregon climate, raised garden beds are great for keeping your soil drained. I've certainly had gardens in the past that got way too wet and had plants struggle to keep up with all that water. This year, I'll see if raised beds make a difference.
I built a whole bunch of these raised beds in a variety of sizes. For the largest ones I double stacked 2x6's, the ones I got from my dad and the ones I got from my coworker's old roof. On the smaller beds I used fence pickets stacked three high and two boards thick.
The design is really simple, I just cut the pickets and 2x6's to the lengths I wanted and took either a fence post or a stringer and cut a piece to put in the corner and cobbled it all together. Take a look at the pictures below, I'll make sure to include photo notes. For the smaller beds I used nails reclaimed from the boards, but on the larger beds I wanted to be able to replace boards if they rot out, so I used wood screws coated with some sort of anti corrosion substance.
Step 4: Hanging Planter Boxes
I already had one of these lying around the house, and really liked the idea of putting my strawberries in it, to keep the damn snails off them. With the extra wood, I decided to build a couple more. As the well known formula runs, strawberries are good, so more strawberries would be better!
These are very simple planter boxes, just two end pieces and three main boards between them, with hooks at either end to hang chains from. You don't have to get as fancy as me, but I wanted these new ones to match the old one. I wood glued these together, but forgot to follow that up with some screws or nails for added strength, and ended up with one of them falling apart in a strong rain.
Step 5: Garden Markers
With some of the smaller ends of the pickets I decided to make little garden signs. If I thought the board was too small to be used for much of anything else, I ripped it in half on the table saw. After I had everything planted, I took down a bunch of left over house paint, gave them a coat of something almost white, and started painting. I think the result was pretty good, all told!
Step 6: Ugly Grape Arbor
My brother gave me an old grape vine he didn't want anymore, so I parked it in the corner of my yard. I realized that it probably needed to get off the ground though, so with some more of the old lumber I cobbled together a kind of rickety, but good enough for now grape arbor.
Again, this is a very simple build, and since I didn't want to make it permanent I didn't even bury the posts. It's just four legs held together at the top with 2x4's, with a couple of cross beams made from pickets for a bit of added sturdiness. The grape seems to like it so far, so I don't mind it being kind of ugly!
Step 7: . . . Any More?
No, that's all for now, but I've still got a big fat pile of old lumber by the shed . . .
So thanks for reading! Please take the time to leave a comment and a rating, and make sure to vote for me in the garden contest! I love hearing what people think of my instructables, so don't be shy.
If you can think of something else I could build from all those fence pickets, let me know! If I decide to build what you've suggested, I'll give you a patch. Also, if you post pictures of your own creations from reclaimed lumber in the comments below, I'll send you a patch for that!
Step 8: One Small Update (7/30/10)
I just thought I'd post a couple of pictures of my garden, now that things are in full swing. What do you think?
Runner Up in the
Garden Contest
49 Comments
10 years ago on Introduction
Looks great! Can I add that installing raised garden boxes like this would be perfect opportunity to install gopher/mole screens? That is, if your area has the problem (I wonder what areas don't). You wouldn't need to dig down to install it. Gopher/mole screen should be metal or vinyl-coated metal with openings no bigger than 1/2". I'm commenting because this is exactly what I'm planning to do, too!
Thanks veryken, and thanks for mentioning the gopher screen. It's not a problem here, but I'm sure lots of people do have to worry about them!
1 year ago on Step 8
Hi! I see all these comments are many years back. I’m not seeing any from this year. But I was wondering how was your garden? This will be my first year doing one. Like I’m completely unprepared. But that’s okay, it’s been a long year. But I think I’m going to try two of your raised garden. I really like the floating ones. The strawberries ones! That is my fav. Now why is a net over them? Yep! Almost forgot to fill you in on the key thing here. So my landlord is my daughter’s grandpa on her dads side. He owns farm land and I’m sitting right in the middle! Yeppers I’m living the dream. I’m off the road and I have free range to do what ever I want. He even thru the shed in next to it. Which is now my she shed. It was his great uncles. He was a farmer and bootlegger/moonshiner many years ago. He worked on tractors, 30 years of used tractor parts (the part that was broke) went into my shed and just recently them parts finally got to see sun light before being hauled away. I still have a lot of old but good stuff hanging on the walls that he has iInstructed me to keep. I’m a sucker for old stuff! But I recently (yesterday lol) order a metal detector and I can’t wait to go on a Treasure hunt with my daughter and niece. Maybe I’ll found an old distillery 😉😉😳🤷♀️🤫🤫 Or some gold dust. My imagination is running wild again. But who knows. It
But I’ll post pictures when I get them done. I’m going to try and slap something together pretty quick. I’m running behind on this gardening thing. I’m going to keep it real real simple for me this year. I’m still playing catch-up on everything and of course adding new projects to the list does not help at all.
Thank you for sharing ! I really thought it was great. You dummy it down just right when called to.
Okay thank you for you time and for letting me rambling
Renee
6 years ago
Очень красиво, захотелось свой огород)))
7 years ago on Step 7
Thanks so much for the tutorial! Looks great! Just wondering about your soil. Did you double-dig the bed area first? I have very compact soil. Wondering if I make the bed tall enough if I still need to do this step. Thanks!
8 years ago on Step 7
Great job of repurposing those fence posts. Here's another idea for you (if you have any 2x4's hanging around). Build a black soldier fly compost bin to help amend the soil in those beds.
http://gardenpool.org/beneficial-insects/black-soldier-fly-composter-automatic-chicken-feeder
I'm going to be building a few with students to help feed our chickens at school.
8 years ago on Introduction
Excellent and clear instructions and photos. I've managed to garner quite a big pile of good (not chemical-soaked) shipping pallets and am embarking on several projects ... the regular raised garden beds for square foot gardening, elevated garden table/beds for my nearly-90-year-old mother, a fence around my raised garden beds to keep out the desert critters including deer, and then I have enough 2x4's of decent length to do all the studs and rafters for another 10 x 20 storage shed. I just have to get the OSB for the flooring, and plywood and shingles for the roof. I've got enough leftover pallet wood to side the whole shed as well. And over the next few weeks, I hope to get more pallet wood to do the framework of a small (8 x 10) greenhouse. My brother gave me plastic sheeting already for that (that's only fair ... he's currently using 90% of my current 10 x 20 storage shed!). There are lots of things you can make with your leftover wood ... benches, Adirondack chairs, a picnic table, etc. I'll try to take pix that are as clear as yours, and write down the instructions for my other projects and post them as I get projects done. They may take a while as this desert gets hot during the summer and I can only work outside when it is cool in the early mornings and late evenings. But, hey, I'm a girl after all! Daddy taught me well.
Thanks, I'm looking forward to seeing the pictures!
9 years ago
Wow! Your garden is doing great!
9 years ago on Introduction
hang some gutters on the fence and direct the water to the beds and make an auto water system..
What a great recycle project. Love the variety of projects especially using the left over as plant markers. You did a good job with your pictures with each step so people like me who have very little experience with building could follow. Thank you for the follow up pictures and may I say what a beautiful garden you have. I am sure your family is very appreciative of your work.
Well thanks very much Deb, those are kind words! It's been three years now and they're still holding up, and the family certainly loves all the fresh veggies each summer!
9 years ago on Step 3
Awesome recycling project!! You used up almost everything!
Here's a tip if you ever do your square boxes again: since you chose to double the siding, a stronger joint would be to build with a single layer first- and overlap at the corners like you did with the 2x6's. Then put on the second layer, and overlap the corners the opposite way. See below:
_________| | |
_________|__| |
____________|__|
For the scrap and rotted wood leftover, look into huegalculture! -it will make nice black loam.
Reply 9 years ago on Step 3
Arrrgg! the formatting messed up my drawing!
________| | |
________|__| |
__________|__|
I think I get what you're saying. It makes a lot of sense, thanks for the advice!
9 years ago on Step 6
Note that grapevines love to wrap themselves around trees and bushes.
I think your garden looks wonderful. I hope to start a garden this year and this is the kind of instructable we needed. Oh, and cute cat too!
Thanks! I'd love to see some pictures of how your garden turns out!
I think it looks awesome. I like how you used reclaimed wood and your garden is thriving.
10 years ago on Step 7
Lots of good tips and inspiration. Thanks!
