Introduction: Raised Planter Bed From Pallets
I recently saw a picture of a raised planter bed and though it was a really neat idea. I though this would be the solution for keeping rabbits out of my garden, only problem was they wanted $250 for it.
After looking at the picture for a few minutes I was able to construct it in my head, only problem was getting the wood for it would be costly. I was thinking about it while I was at work and saw a co-worker toss a pallet into a dumpster, it occurred to me that I had just found a source of free wood for this project.
It took me about 6 hours in total to build the raised planter bed and I was able to make it for about 10% of what it retailed for.
Step 1: Materials and Notes
- 3 to 4 Pallets - depends on the size of the pallets, you'll also want them similar in size.
- Hammer
- Vice Grips
- Pry bar/Crowbar
- Drill
- Staple Gun - 3/8 inch staples
- Skill saw, jig saw, or preferably a miter saw (something that will make 90º cuts and 45º cuts)
- Screws; I used 3 different lengths of wood screws: 1 inch, 1 1/4 inch, and 1 3/4 inch
- Landscaping Fabric
- Additional treated wood from a lumber store, unless you have planks that are the total length of the bed.
The Pallet wood you will need to use will need to be heat treated. All pallets will have some marking or stamp on them indicating how they have been treated. You will need to get some that have a HT (Heat Treated) stamped on them to make this safe for uses with a garden. Steer clear of pallets with MB stamped on them, they have been treated with Methyl Bromide and can be dangerous if used for this project, since plants will be in contact with the wood and any chemicals in it.
Step 2: Prepping the Wood/Pallets
You will need to break down the pallets to use them. It is a lot easier to disassemble pallets that use nails instead of staples. You will also want to look for pallets that are newer versus older, the wood is less likely to crack when a screw is drilled into it.
The first two pallets I had were assembled with nails, I was able to break them down in about 10 minutes .The second pallet, the crate one, was assembled using staples. That one took a bit more time to break down but had newer and more wood to it.
After all the pallets are broken down you need to remove all of the nails and staples from the boards to get them in a safe usable condition.
Step 3: Building the Legs
- First I lined up 8 of the best looking 2 x 4's and cut them to length of 3 feet. I used a roofers square tool to get a 90º angle on all of the boards, and cut them to length.
- Once all the boards have been cut will need to combine two of the boards to make two sets of 4 x 4's. These will be our center legs.
- Once you have the 4 x 4's created will use a thin board to make part of the sides.
- One side will consist of a 2 x 4, a thin board, a 4 x 4, another thin board, and a final 2 x 4. The fifth image shows what it should look like once completed.
- Now just repeat step 4 for the other side.
Step 4: Angled Sides and Supports
- For the angles you are going to take a 2 x 4 and cut it in half, I was able to get each half 21 inches in length. Put a 45° angle on both ends with either a jigsaw or miter saw. I only have a jigsaw so I had to cut the 45° angle manually, which made for rough cut but it worked.
- You're going to need to do this step two more times to come up with all the angled sides you will need for the raised planter bed.
- For the legs, I used a 2 x 4 and cut it partially down the middle to create the supports for the raised planter bed, you can see the results in picture 4.
- Now you're going to want drill a hole for the support legs and 2 x 4's to bolt everything together.
- Once all the support beams are in place, lay down the center board and screw it in place.
- Now that the center beam is down start working your way up of the sidewalls with additional boards leaving a little bit of space between each board.
Step 5: End Caps
For the in caps it is a good idea to use the scrap pieces that were not good enough to be used for the angled sidewalls.
The easiest way to make the in caps is to place the board directly against the and of the angled walls and use the roofers square to market a 45° angle and make a cut on that line. Just repeat the process until you get to the top of the angled walls.
Step 6: The Liner
For the liner I used a heavy duty cloth liner that was a 1/16th of in inch thick. I measured out the total length and the total width with the sides, added 2 inches for an inch fold on each side.
I ended up cutting a rectangle that measured 72 inches in length and 56 inches across.
Once I had it positioned in the bed I started stapling it in place with a staple gun.
For the end caps I cut out a triangle shaped piece and repeated the process.
Step 7: Finishing Touches
I added some rubber feet to the bottoms of the legs so the wood would not be in direct contact with the ground. I had some old rubber mat that was give to me and it works perfect for the rubber pads. Just cut it to size and and screw the pads in place.
Step 8: Final Notes and Future Plans
Over all I a happy with the sturdiness of the raised bed. My wife and I were able to move it into place easily.
When I fill the bed I am going to put river rock at the bottom to assist with drainage, place another layer of liner over the rocks and fill with garden soil.
I am currently working a smaller version that will be constructed from 2 pallets.
I am also working on a way to add netting to keep bugs out, a sun screen to keep certain plants from burning up in the summer heat, and possibly a greenhouse type of cover to keep humidity in in the spring months. I hope to have a instructable posted on it in about a month or so. Until then happy gardening.
Instructables Green Design Contest
Gardening Contest
2 People Made This Project!
- mrnova made it!
- showard2021 made it!
29 Comments
Question 2 days ago
Does anyone have just a list of the sizes everything needs cut to? It looks like a great design and easy to do. I'm just wondering the size of the cross/support boards that make the width. We got 3 ft legs and 21" diagonal with 45° cuts on each end. But what about those cross boards that get kinda notched out?
10 months ago on Step 8
What are the dimensions?
1 year ago
Thanks for posting! 8 years on, your gift keeps on giving!
I researched for a friend who is buying a ready made ones made of cedar for $279 on Amazon. I tried to talk her into buying only one and then using it as a template to make more for a fraction of the cost. I'm going to try to build one myself just to see if I can do it. :)
2 years ago on Introduction
FYI: These are NOT 2 x 4s, they are 1 x 2s
Just a thought on adding the netting to the top. Add a piece of PVC pipe at points along the top. You will have the hole of the pvc pipe. Then build a separate netting on a frame of PVC with a smaller size tube that will insert into the pvc you have .
2 years ago
Great instructable thanks. I suggest disassembling pallets from the underside as nails tend to be driven in from the upper side; leastways I tend to recover more pieces without splits happening this way.
4 years ago
Obviously the 'V' -shape is to cut down on the amount of soil needed to fill it, while allowing root crops like beets and turnips to grow in the deeper center and top growing crops like onions and lettuce in the shallower soil on the sides.
4 years ago
Great idea and design, thanks for posting. When built out of pallets how long does the box last. Wondering if it worth the investment to take the same design out of pallets. This is for a box at a church for a community garden done as an eagle scout project.
6 years ago
Making one for my 87-year-old mother for Mother's Day so she doesn't have to bend over to garden
6 years ago
thanks for the idea will give it a try
7 years ago on Introduction
wow! What a great idea. I am not able to be on my knees be cuz of severe knee surgery. This is a great way for me to still garden. Pallets are at my neighbors for the taking.. Thanks... Great job....
Fantastic build, I have two, really had fun with this. Attached a glass door to one of them and using it as a green house type set up for my herbs.
7 years ago
I do love this idea. very good use of reclaimed wood. however what is the point of the triangular design? is it for drainage?
8 years ago
Can't wait to see the smaller version. My yard has minimal space and I have been looking at designs that are high enough to keep my dogs out. I love this design. Keep us posted.
8 years ago on Introduction
Very nicely done. I made a square raised garden bed out of reclaimed pallet wood but I think your design is a lot prettier and more soil-efficient. I need to get some more pallet wood and I'll have to try to replicate your design. Thanks for sharing and happy gardening!
9 years ago on Introduction
If you use flashing to line the inside instead of landscape cloth you can use the chemically treated wood. If you want to reuse the water put in a french drain at the bottom lined with landscape cloth and a catch basin. I like the triangular design of this box because of the easy access it affords to wheel chairs.
9 years ago
Great idea! I am currently working on the three pallet planter. Looking forward to seeing the two pallet design.
This is awesome!!! a lovely design! :D
9 years ago
Awesome! Great instruct able- and I really look forward to the modifications. I wonder how effective it would be as a greenhouse. ? I love the idea.....thanks!
I have also come up with a different design using only 2 pallets and needs 1/4 of the amount of filler and 1/3 amount of the dirt. Only downside is it will not work well for vegetables that grow underground such as carrots and potatoes. I will have an updated version posted in a few days.
