Introduction: Random LED Millis
The goal of this project is to create 4 LED that turn on randomly based on a random number generator and use an interval based on Millis. To create this project, you will need a push button, 4 led lights and the wires to hook them up.
Step 1: Step 1
The first step is pretty simple. Connect 4 LEDs and and a push button to your Arduino. In our code, we will use the pushing of the button to start the LEDs.
An LED will light up after a two second interval as determined but Millis.
A random number generator will decided which led to turn on.
Code:
unsigned long wait = 2000;
unsigned long previousTime = 0; int buttonPin = 2; int buttonState = 0; int previousButton = 0; int pin1 = 13; int pin2 = 12; int pin3 = 11; int pin4 = 10; long randomNumber; boolean led1State = false; boolean led2State = false; boolean led3State = false; boolean led4State = false;
void setup()
pinMode(buttonPin, INPUT);
pinMode(pin1, OUTPUT);
pinMode(pin2, OUTPUT);
pinMode(pin3, OUTPUT);
pinMode(pin4, OUTPUT);
}void loop()
//read the button's state (on or off)
buttonState = digitalRead(buttonPin);
if(buttonState != previousButton)
if(buttonState == HIGH)//Button is pressed
unsigned long time = millis;
randomNumber = random(0,3); if(time - previousTime >= wait)
switch(randomNumber)
case 0:
digitalWrite(pin1, HIGH);
digitalWrite(pin2, LOW);
digitalWrite(pin3, LOW);
digitalWrite(pin4, LOW);
previousTime = time;
break; case 1:
digitalWrite(pin1, LOW);
digitalWrite(pin2, HIGH);
break; case 2:
digitalWrite(pin3, HIGH);
break; case 3:
digitalWrite(pin4, HIGH);
break;
