Introduction: Raspberry Chocolate "Blood" Sauce
Perfect for cupcakes, cookies, and all your spooky dessert needs.
Ingredients
- red food coloring (I prefer gel colors, but you could probably use the liquid kind although it will take more to get the same intensity of color)
- corn syrup
- cocoa powder or chocolate syrup
- seedless raspberry jelly or jam (or strawberry would work)
Step 1: Make a Cocoa Paste
(if you are using chocolate syrup, you can skip this step and use the syrup as is)
Put a tiny amount of cocoa powder and water in a bowl and mix until you get a thick paste. Basically, you want all the clumps of cocoa dissolved so they don't create lumps in the blood (although that could look pretty gross...).
Step 2: Mix the "blood"
In a small bowl, mix together the jelly (if using), corn syrup, and little bit of food coloring. You should get a bright red but somewhat thin syrup. Add the cocoa paste a little bit at a time until the syrup darkens and looks like blood.
Step 3: Make It Bleed
That's it!
I used mine to decorate cupcakes, but you can use it for whatever Halloween treat you're making.
