Introduction: Raspberry Chocolate Mousse Mini Pies
When I saw the Pi Day Speed Challenge, I knew I had to make some kind of pie! I haven't made any kind of pie in so long, and I thought this would be a fun challenge! After much thinking, I decided to make mini chocolate cookie pie crusts filled with a fluffy raspberry chocolate mousse! I am very pleased to present this dessert as my Pi Day entry! They are rich, creamy and decadent!
Step 1: Supplies for the Crust
Small food processor
mini pie maker
rolling pin
plastic wrap
small bowl
5-inch pie crust cutter (came with the mini pie maker)
fork
small rubber scraper
Step 2: Ingredients for the Cookie Crust
1 cup all-purpose flour
1/4 cup unsweetened cocoa powder
1/2 cup confectioners' sugar
pinch salt
1/2 cup cold butter
1 large egg
Step 3: Mix the Dry Ingredients
Add the flour, cocoa powder, confectioners' sugar and salt to the bowl of the food processor. Pulse until combined.
Step 4: Add Butter
Cut and add the butter. Pulse 7 times.
Step 5: The Egg
In a small bowl scramble the egg.
Step 6: Add the Egg
Pour in the egg and let process until the dough holds together.
Step 7: Roll the Dough
Remove the dough from the bowl. Place on a piece of plastic wrap. Cover with another piece of plastic wrap. Roll with the rolling pin, making a 1/8-inch thickness. Wrap tightly. Refrigerate for 1 hour.
Step 8: Supplies for the Mousse
small sieve
quart saucepan with cover
stand mixer
Step 9: Ingredients for the Mousse
1 (6-ounce) package fresh raspberries
1 cup heavy cream, divided
2 egg yolks
1/4 cup granulated sugar
1/2 teaspoon vanilla extract
3/4 cup semi sweet chocolate chips
Step 10: Blend Raspberries and Cream
Set 5 raspberries aside. Place remaining raspberries into the food processor. Pour in 1/4 cup cream. Puree until the raspberries are broken down.
Step 11: Sieve the Mixture
Place a fine mesh sieve over a small saucepan. Pour some puree into sieve. Stir and press the puree through sieve into saucepan using the spatula. Discard the remaining pulp. Repeat until all of the mixture has been sieved.
Step 12: Cook the Puree
Heat the puree mixture over medium heat until just beginning to steam. Set aside.
Step 13: Whisk the Yolks and Sugar
Place the egg yolks into the bowl of a stand mixer. Using the whisk attachment, whisk for 3 minutes until yolks are thickened. Add the sugar gradually while continuing to whisk.
Step 14: Add Half of the Puree
Stream half of warm puree mixture into egg mixture while continuing to whisk.
Step 15: Cook and Stir
Pour egg mixture into the sauce pan with the remaining puree mixture. Cook and stir for 7 minutes over medium-low heat until thickened.
Step 16: Add Vanilla and Chocolate Chips
Stir in vanilla extract. Remove from heat. Add one-third of the chocolate. Stir until melted and smooth. Add half of remaining chocolate. Stir until melted and smooth. Add remaining chocolate. Stir again until melted and smooth. Cover the pan. Place in refrigerator for 1 hour, stirring after 30 minutes have passed.
Step 17: Cut the Pie Circles
While the chocolate chills, prepare the crusts. Using the cutter, cut circles of crust. Re-roll the scraps. I made 5 chocolate mini crusts.
Step 18: Bake the Crusts
Spray the wells of the pie maker with cooking spray. Press in and shape the dough to form the crusts. Cover and bake until fully cooked, about 7 minutes. Remove the crusts and allow to cool. Repeat with remaining crusts until all 5 are baked. Note: if you don't have a pie maker, you can make the crusts in a muffin pan. Bake at 350 degrees for about 10 minutes. Check for doneness.
Step 19: Whisk the Cream
Using the stand mixer, whisk the remaining 3/4 cup heavy cream to stiff peaks.
Step 20: Add the Whipped Cream
Stir 1/3 of the whipped cream into the chocolate mixture until smooth. Fold remaining whipped cream gently into the chocolate mixture until blended.
Step 21: Finishing the Mini Pies
Generously spoon mousse into the chocolate crusts. You can serve as is or add garnishes. Here I have added small squirts of aerosol whipped cream, the 5 reserved fresh raspberries and chocolate shavings! So creamy and rich, your family or guests will be quite impressed and happy on Pi Day!!!!!
