Introduction: Raspberry PI OS Root File Manager
Linux is very strict on file and directory permissions. I is also tricky for somebody who does not now all the command line commands to copy files, directories, move them around and edit files. If you do anything like the mentioned, in a directory other than /home, you will frequently get the error, permission denied.
Raspberry PI OS and many other Linux have a nifty File Manager (Like Windows explorer). You will find this on your main menu. This File Manager is however not started as the root user (super user). If you start it as super user, your permission denied problems should be over. Files you launch from it should be completely owned, editable, movable etc
Go to the main menu>Preferences>Main Menu Editor
Open Accessories and select New Item. Complete the form
- Name=ROOT File Manager
- Command=sudo pcmanfm
- Comment=sudo pcmanfm, Run File Manager as Root
You can also give it a nice picture, like the one I attached
Click OK. You now run pcmanfm (File Manager) as root user
