Introduction: Raspberry Pi 2 Homekit - From Zero to Hey, Siri (Updated)
UPDATE:
Added the "ready to use" image file link to the youtube video description.
Download, write to SD, and ready to use.
UPDATE 2:
Rpi ZERO version:
Hi,
In this instructable, i will show you, how to install Homekit Bridge to your RPi 2, and control your home accessories.
There is a youtube video too, with step by step tutorial.
For me, Homekit on the RPi2 not worked well with other OS (Raspian), only with a Jessie image.
Tutorial video:
STEP 1 >>
Step 1: Step 1: Install Jessie
Tools needed:
- Jessie OS (version 2015-08-30)
http://sysprogs.com/files/SD/2015-08-30-jessie-ras...
- WinFlashTool (for write image to SD)
http://winflashtool.sysprogs.com/
Download the image and the WFTool from the links, put the image file into the WFTool, and install the OS to the SD
(First step in the video)
Step 2: Step 2: Installs, Installs Everywhere...
1:
Boot the RPi2 with Jessie.
Open a terminal program on your PC/MAC (im using putty)
Connect to your RPi2 with the putty (RPi2 ip found in your router DHCP client list)
Username: pi
Password: raspberry
In the youtube video find this step at 1:17.
2:
next, the ragular update and upgrade:
sudo apt-get update && sudo apt-get upgrade -y
In the youtube video find this step at 1:35.
3:
Add yourself superuser privileges (less "sudo" type)
sudo su
In the youtube video find this step at 2:13
4:
Install python-dev and python-pip
apt-get install python-dev python-pip
In the youtube video find this step at 2:21
5:
Install libavahi and libdnssd
apt-get install libavahi-compat-libdnssd-dev
In the youtube video find this step at 2:27
6:
Download and install the latest node
wget http://node-arm.herokuapp.com/node_latest_armhf.d...
dpkg -i node_latest_armhf.deb
In the youtube video find this step at 2:37
7:
Check node and npm version and installation
node -v
npm -v
8:
Clone Homekit Bridge from github, and go into the HAP-NodeJS folder
git clone https://github.com/KhaosT/HAP-NodeJS.git
cd HAP-NodeJS
In the youtube video find this step at 3:04
9:
There is a lot of missing modules, so install all of them in one command.
npm install -g node-gyp
npm install node-persist && npm install srp && npm install mdns && npm install ed25519 && npm install curve25519 && npm install debug && npm install python-shell
In the youtube video find this step at 3:37
10:
Rebuild
npm rebuild
Step 3: Step 3: Add New Light Accessory
1:
Go into accessories folder, and make a new light accessory:
cd accessories
nano myLight_accessory.js
In the youtube video find this step at 5:13
2:
Copy in this empty .js file everything from the linked homekit.txt file, from the
//Light accessory line
Homekit.txt link:
https://drive.google.com/file/d/0B6GR9Hj5Ut61bDZle...
Rename the accessory, change a little the "username" (looks MAC address, watch out the HEX rules)
Save the file and exit
In the youtube video find this step at 5:46
Step 4: Step 4: Make the Python Files to Control GPIO Pins
1:
in the HAP-NodeJS folder, make a new python folder, go into.
cd ..
mkdir python
cd python
In the youtube video find this step at 7:07
2:
Make the GPIO "on" and "off" python file
nano light1.py
Copy this into:
import RPi.GPIO as GPIO
GPIO.setwarnings(False)
GPIO.setmode(GPIO.BOARD)
GPIO.setup(16, GPIO.OUT)
GPIO.output(16, 1)
Save, and close the file
nano light0.py
Copy this into:
GPIO.output(16, 0)
In the youtube video find this step at 7:19
3:
Connect a led GND into one of the RPi2 GND pin. Im used the outer line 3. pin, and connect the led "+" pin tho the RPi2 GPIO.16 pin. Thats the 8. pin in the outer line.
Test the python codes:
python light1.py (led turn on)
python light0.py (led tudn off)
If everything ok, go back to HAP-NodeJS folder.
cd ..
npm rebuild
In the youtube video find this step at 8:14
4:
Start the Homekit Bridge.
node Core.js
Step 5: Stap 5: Config Ios Device
1:
In the video, im using Apple HMCatalog app, but find better homekit app, like EVE elgato.
Add a new home, some room, and one of the rooms, add your new light accessory.
The PIN: 03145154
Add anyway.
In the youtube video find this step at 9:28
2:
Test it, enjoy it!
Thank you.
