Introduction: Raspberry Pi Alamode CNC Controller
This is my first attempt at an instructable. I hope it helps someone else.
Switches and Lights and fans, oh my...
Please read through the comments for more details.
I bought a CNC machine some time ago and I was never happy with it. It used a traditional parallel port controller and of course no modern computers have those. So it was always a point of frustration. I used an old Pentium based computer and ran LinuxCNC on it for a while but was still not happy with that. So I started looking for another solution. I decided that I would try to put together an Arduino based controller and try to use USB to communicate with it.
After studying that for a while I came to realize the Arduino was just not going to be able to do all that needed to be done on its own. The Arduino UNO just does not have enough memory or processing capacity to process a design file by itself. So I modified my solution and started working on using a Raspberry Pi as my host computer.
I created a Visio drawing of what I intended to do: It didn't turn out that way and the drawing continued to evolve as I learned more. It kept on changing until I finally got my project completed.
I have now built an Arduino based CNC Controller system that uses a Raspberry Pi as its host computer. The Raspberry Pi processes an "nc" file that contains a design that is described in GCode commands that can be understood by the Arduino. I have used a few tools on my Windows 8.1 Pro laptop to design a few simple things (like tutorials in makercam here: http://www.makercam.com/). This is a great introduction to designing things for CAD/CAM and it is really easy to use.
After creating a design that I wanted to use I wirelessly connected to the Raspberry Pi using WinSCP to transfer design files to the Raspberry Pi. You can get WinSCP here: http://www.soft-now.com/listing/123823/WinSCP?did=11055&pid=1&ppd=search,44532390848,winscp20download,e,,c,0,,,&gclid=CJuIkNHds74CFagWMgodpxMAJw. Its great, you can just drag a file from one window to the other to move files between systems. You will have to know the IP address of your Raspberry Pi to connect to it. If you have gone through the initial setup of the Raspberry Pi and setup a network connection you can get the IP address by using the ifconfig command on the Raspberry PI. A really helpful tool for getting your IP address and seeing that your Pi is online is a tool called the Advanced IP Scanner here: http://www.advanced-ip-scanner.com/. Another great tool is Wireshark: http://www.wireshark.org/
I then used Remote Desktop Connection (Remote Desktop connection is part of Windows and should be on your Windows machine. It can be run by entering mstsc in the Run Open: box) to connect to my Raspberry Pi. Otherwise you could use VNC or TightVNC: http://www.tightvnc.com/. TightVNC is what you need to put on your Raspberry Pi to allow you to use Remote Desktop Connection from another machine. I can now run the Grbl Controller on the Raspberry Pi which in turn connects to an Alamode (an Arduino like board that plugs directly into the GPIO connector on the Raspberry Pi and provides automatic voltage level translation. So that the Arduino can communicate with the Raspberry Pi directly. The Alamode also provides Arduino headers to allow for Arduino shields to be plugged directly into it. So I ended up with a stack of three boards that are tightly integrated due to being plugged directly into each other. The Alamode (Arduino) processes the GCode commands from the Raspberry Pi into signals that are sent to the CNC Controller shield to run the stepper motors and passes the various function signals on to the CNC Controller shield too. They can then be accessed from the external world. All is well so far... But now I have to connect these things to the external world.
Step 1: 100% Grbl Compatible CNC Controller
First, I purchased the 100% Grbl compatible CNC Controller shield from: http://blog.protoneer.co.nz/arduino-cnc-shield. I already had an Arduino and intended to use that with the CNC Controller shield and run something on my laptop to control everything. Then I found out that the Arduino would not be able to process an entire design file all by itself. This is due to it not having enough memory to handle more than one GCode command at a time. In fact not all GCode commands are currently completely implemented in the Arduino Grbl software. However, the Arduino does directly interface with the CNC Controller shield and can pass commands to the stepper drivers on the CNC Controller shield without any additional circuitry.
The sets of three yellow jumpers that you see in the pictures set the micro stepping for the stepper motors. The one single yellow jumper selects how the limit switches work. Mine are set up so that when the switch closes a ground is detected (the default). The alternative is to sense a hi when Vcc is selected. That is to say that the limit switch logic can be set to sense a hi or lo, your choice. The two yellow jumpers on the left side of the picture are for selecting which axis the A-axis mirrors (two motors on one axis).
I used polarized headers to connect to the stepper drivers so that I would not be able to plug in my stepper motors backwards - that's pretty important.
The 100% Grbl compatible CNC Controller shield does not actually include any stepper motor drivers. It is only a means of integrating the stepper motor drivers into an Arduino shield conveniently and it works great for that purpose. The CNC Controller shield is designed to use the Pololu type step driver modules like the A4988 stepper motor driver carrier that is shown here: http://www.pololu.com/product/1182
I purchased some from China that were about $4.00 each and appear to be exactly the same (we shall see when I actually try to use them). They came with some heat sinks too but I decided to use the ones you see (from Adafruit) instead of the ones that were included instead. You actually only need to populate the X, Y and Z stepper driver carriers on the CNC Controller board (because the Grbl software on the Arduino only knows about three axes). Unless you intend to use the A-Axis too (for a second motor on one of the primary axes). The CNC Controller allows you to mirror the control signals from X, Y or Z to the A axis by using jumpers. I am not using the fourth axis. I just included the fourth stepper driver carrier so that I would have a spare in case one of the others stops working. Then again who knows what might be in the future?
Step 2: Raspberry Pi
It became clear that I needed some way to process a complete design file and break it into individual GCode commands that the Arduino could then pass on to the CNC Controller shield. Many articles are available on the internet about running the Grbl Controller software which provides this specific function on a Raspberry Pi. I had a Raspberry Pi that I had played with a bit, some time ago, but it was an older version. I am sure it would have worked but I decided to get a new one and dedicate the new one to being the host in my new CNC Controller system. For more information about running the Grbl Controller software on a Raspberry Pi look here: http://zapmaker.org/raspberry-pi/running-grbl-controller-on-raspberry-pi/
Due to reading a lot of those articles that I mentioned I became concerned that the Raspberry Pi would overheat when inside of an enclosure so I put heat sinks on it. Then I had to trim down the heat sink on the processor as it was too tall.
I also came to realize that the Arduino and the Raspberry Pi are slightly, electrically incompatible. The Arduino operates with 5V logic and the Raspberry Pi operates with 3.3 V logic. So a voltage level translator of some sort is required as an interface between the two environments. I looked around for a solution and found a few. I didn't really like anything that I was finding and it took a while to get to what I wanted but I eventually found the Raspberry Pi Alamode board.
Step 3: Raspberry Pi Alamode
The Alamode board plugs directly into the GPIO connector on the Raspberry Pi and provides the level shifting function that is needed for the Arudino to communicate with it. It also provides Arduino compatible headers so that any standard Arduino shield can be plugged into it too. Including the CNC Controller shield. So it now appeared that I could have a stack of three boards that communicate with each other properly and elegantly - with no additional circuitry required.
Some quick features of the Alamode - that I am interested in: The Alamode has a real time clock that is directly available to the Raspberry Pi (with a coin cell battery backup). The Alamode can be powered from the Raspberry Pi or it can be powered directly through its own micro USB connector. There is a tiny jumper that allows you to select how you want to power it. The jumper header fell off of my board (probably my own fault). I looked at it and decided I just didn't need it as I intended on powering it through its own micro USB port anyway. The big deal is that the Alamode includes the signal level shifting that is required for an Arduino to communicate with a Raspberry Pi.
Once the Alamode is connected to the Raspberry PI you can then load the Grbl software onto the Alamode. The Grbl code is loaded into the Alamode with the Arduino IDE. You need to load the Arduino IDE onto the Raspberry Pi to load the Grbl code into the Alamode. The Getting Started instructions at the Alamode site are very good and complete: http://wyolum.com/projects/alamode. Refer to the User Guide for instructions on how to set up the real time clock.
Let me just say that it works exactly as they say it does. It is a bit of a task to get everything together to actually use it but once it is set up (mostly on the Raspberry Pi) it works great.
Step 4: Stack 'em Up
So now I have a stack of three boards. With the Raspberry Pi on the bottom, the Alamode in the middle and the CNC Controller shield on the top. All plugged together. One problem for me was that the Alamode does not provide any mounting holes. It does provide a rubber pad that goes on the top of the RJ-45 Ethernet connector on the Raspberry Pi and is the right height (must be very carefully positioned on the RJ-45 connector) but there is no solid connection point other than the GPIO connector. The CNC Controller shield is like most other Arduino shields and is very well held in place due to the friction of the header extenders that are on the Arduino. My original Raspberry Pi did not have mounting holes in it either. That is part of the reason why I decided to get a new one and use it instead. Later on, I purchased an assortment of nylon standoffs and attached a couple of them to the Raspberry Pi - with a couple of washers to get the height right. Then I very carefully put a drop of super glue on the top of each of the nylon standoffs and put the Alamode onto the Raspberry Pi. I then left it alone for a while. I was later able to take the screws out of the bottom of the Raspberry Pi and take the Alamode off with the standoffs attached to the Alamode - it worked! I also attached a standoff between the Alamode and the CNC Controller shield as there was a hole in a place that made that possible on both boards. So now I have all three boards securely connected together.
Step 5: An Enclosure
Early on I decided to use some sort of enclosure to protect my finished project. So I bought one and then came to realize it was not large enough and had to measure everything and buy another one. The one I used is is nice box but turned out to be a challenge anyway. This box is made by Bud and I got through Amazon here: http://www.amazon.com/dp/B005T7ARB6/ref=pe_385040_30332190_TE_M3T1_ST1_dp_1. It is a BUD Industries PN-1339-DG High-Impact ABS NEMA 4x Indoor Box, 6-19/64" Length x 6-19/64" Width x 3-17/32" Height, Dark Gray Finish enclosure.
There are some nice brass threaded mounting holes in the corners inside of the box and the box comes with screws to secure the top to the bottom with the brass threaded holes in the outside corners. The box also has a gasket to make it waterproof if you need that. In my case it just makes for a very nicely sealed box.
I came to believe that I needed to have some sort of carrier to mount my "stack" to inside of the box. So I bought a sheet of acetal from Zoro Tools: http://www.zoro.com/g/Acetal%20Sheet%20Stock/00153128/. Acetal is supposed to be somewhat ESD safe but I have not studied that out entirely either. After I got the sheet of acetal I cut a piece that would fit inside of the enclosure with my Dremel tool. It isn't pretty and this is one of the things I plan to replace when I finally get my milling machine working again. I ended up having to cut cutouts on both sides of my initial carrier to provide better access for the wires and cables that connect the "stack" to the external world.
I also felt that it was important to make sure that there is adequate ventilation in the box. So I mounted two 40mm, 12 VDC, exhaust fans on the top and two inlet vents with filters on the bottom.
In the pictures you can see that there are a couple of extra holes in the carrier - Oops.
I made a 1:1 scale drawings of the openings to be put into the box in Visio and then printed those out on my printer. Then I cut out the printed drawings and taped them to the box and used them as templates. It wasn't perfect, of course, but was pretty good. I started each modification to the box by using an Exacto knife to carefully mark through the templates and then used a Sharpie to make sure I got it right. Then I used my Dremel to cut out the various openings in the box. Not too difficult to do but you have to be patient and let the Dremel do the work or you will end up with a lot of melted plastic on your hands and the nib that you are using in the Dremel will try to dig into the material occasionally. My only advice is be patient, take you time, don't press to hard, cut in the right direction and it will all work out acceptably - no one is perfect. The hardest openings to cut were the ones for the switches and the connectors. Each of the connectors and switches have flat spots on opposite sides. All of my switches and connectors are 16mm. The flat spots keep the switches or connectors from turning in the chassis. That is great if you are using chassis punches but I do not know of any of those that are designed to work on plastic. So I had to very carefully cut the holes by hand with my Dremel. I cut them and test fitted each connector one at a time and as soon as I was able to get the switch or connector in the hole I stopped. They are pretty good but a nice CNC machine would have done a better job than I did - maybe next time I will have a working CNC machine and I can try that.
Step 6: The Hard Part
So here is the hard part. Most CNC machines (milling machines, laser cutters, engravers, water jets, etc.) use stepper motors to position the axes. The CNC Controller board provides X, Y and Z axes as well as an A-Axis that can be used to supplement one of the other axes if needed with an additional motor or a fourth axis could be implemented (but Grbl only knows about three axes right now). My implementation is only going to use three axes at this time. However, I decided that I needed to bring the A-Axis out because I might someday want to use it. Further, the CNC Controller board provides for the control functions to enable the spindle as well as two other functions. By default they are spindle cooling and spindle direction (alternately these functions can be used to control a laser, a vacuum hold down or a blower / fume extractor and a heating mat for a 3D printer). I did not know what I might want to control later on so I decided to bring those signals out of the box too. I ended up with five connectors on one side of my box that can be used to connect to the machine that I want to control. I have labelled everything and everything is also color coded.
I want to mention that I used expandable sleeving to bundle wires together where ever possible and to reduce the number of unbundled wires in the build. It helps in a lot of ways and protects the wires a bit but most importantly it makes it really clear what each of the bundles is for. It also makes the entire project a lot better looking. Here is one place that you can get expandable sleeving: https://www.parts-express.com/Search.aspx?keyword=expandable%20sleeving&sitesearch=true. NTE provides wire and heat shrink tubing assortments that are really useful in building electronics.
NTE / Elenco hookup wire assortment: http://www.amazon.com/Elenco-Electronics-WK-106-Storage-25-Feet/dp/B008L3QJAS/ref=sr_1_1?ie=UTF8&qid=1400363023&sr=8-1&keywords=elenco+wire
Heat shrink tubing assortment: http://www.amazon.com/NTE-Heat-Shrink-Assorted-Colors/dp/B000FIDTYG
Other useful things are like these:
Crimping Tool to put pins onto the ends of wires to be plugged into the various places: http://www.pololu.com/product/1928. This is a really nice tool and works better than a lot of other crimpers that are a lot more expensive. Of course, you need to have pins and housings to complete a connection. You can see that I used many pins and housings in building my CNC Controller.
Step 7: The External World
The next thing that had to be done was to connect the inside of the box to the external world. Switches to control the system and plugs to get the signals to the stepper motors and the spindle and finally a connection to a power supply.
The switches are all connected to one header that plugs into the CNC Controller shield and another one that plugs into the power distribution board for the LEDs that are in the switches. So the switches have a connection both below the carrier and above the carrier.
The switches are E-Stop or Arduino Reset (Red), Abort Reset (Yellow), Pause / Feed Hold (Blue) and Cycle Start / Resume (Green). The Reset, Abort and Hold switches are push-push switches. That is they stay pushed in until you push them again. That gives a positive indication of whether or not a button was pushed. The Resume button is a momentary push button and only stays in as long as you hold it in. Each button illuminates so that you can clearly see if it is pushed in or not. As you can see in the pictures I used colored expandable sleeving and shrink tubing of the same color as the button for each function to make it easier for me to keep everything straight.
The connectors on the other side of the box are color coded too. They are X-Axis (Green), Y-Axis (Blue), Z-Axis (Red), A-Axis (Purple) and Spindle (Yellow). These colors match up with the cables on my milling machine. The X, Y and Z axes contain the wires for the stepper motors and for the limit switches. The A-Axis is only stepper motor wires and will not be used on my milling machine. The Spindle connector has the Spindle Enable, Spindle Direction and Cooling Enable wires in it. Again you can see that I tried to use the same color expandable sleeving and heat shrink tubing as much as possible.
I connected the two 12 VDC exhaust fans to a header that eventually connects to the power distribution board.
Finally, I used a PowerWerks PowerPole snap-in chassis mount that provides 5 VDC through a red connector and red cable, 12 VDC through a yellow connector and yellow cable and a ground for each side through black connectors. The chassis mount holds the PowerPole connector housings in place inside of the snap-in chassis mount with a pin and these connectors are very well made. More information about the PowerWerks PowerPole connectors can be found here: http://www.powerwerx.com/powerpole-accessories/pow...
Externally I am using an ATX power supply that has been slightly modified to provide power for my milling machine (it came with my machine). I built a cable with the PowerWerks PowerPole connections on it that match up to my CNC Controller box PowerPole snap-in chassis mount. Later on I added an emergency power off switch to my power supply. You can see the emergency switch here: http://www.sourcingmap.com/red-mushroom-cap-1no-1nc-dpst-emergency-stop-push-button-switch-ac-660v-10a-p-256918.html
Hooking up the switches and the connectors was the most time consuming part of the build.
Step 8: Power Distribution
The next issue was how to get power to my "stack". I decided to build a power distribution board. I also had an issue with the switches that I used. As you can see they have LEDs inside of them. The LEDs are completely separate from the switches. On top of that the switches just provide a path to ground for the CNC Controller / Alamode. So, to get the LEDs to light up when the switch is depressed I had to use an inverter (SN7404 Hex Inverter). The LED power function is most of the circuitry on the prototype board. Power is on the edges with 5 VDC on one edge and 12 VDC on the other edge. The four resistors are current limiting resistors to limit the current going through the LEDs. The 12 pin header is where the switches plug into the board. The headers provide power for everything in the box. 5 VDC for the Raspberry Pi and the Alamode. 12 VDC for the fans and the 12 VDC circuitry on the CNC Controller shield and for the 12 VDC path through the relays. The black connector on the prototype board is used to provide the grounds for the signals being controlled by the relay stack. Notice that I tied all of the grounds together on the power distribution board.
I used a temporary breadboard to figure out how to get the LEDs to work the way I wanted them to work. Then I moved the circuit to an Adafruit Perma-Proto Half-sized Breadboard PCB. It went pretty quickly and easily.
There are pull up resistors in the Alamode (Arduino) that pull up the voltage to near Vcc on the Alamode for each of the functions. A function change of state is sensed when the voltage is pulled lo or to ground. The CNC Controller shield provides the function pins and matching ground pins. Shorting the function to ground changes the state of the function and is sensed by the Arduino code. I wired up the switches to do just that. Press the switch and the function is connected to its respective ground pin. However, I also ran a wire from each of the switches to one of the four Inverters that I used (two of the inverters in the HEX Inverter chip are not used). So that when the switch is open a high or Vcc is on the input to the inverter which results in a low is on the output and the LED is off. Pressing the switch puts a low or ground on the input to the inverter and hence the output of the inverter transitions to a hi and the LED turns on.
Step 9: Putting It All Together
I looked into connecting a video display to the enclosure but did not have enough USB ports. So I bought a 3-port USB hub. It came in a black plastic housing but that was way too big to fit into my box. So I took it out of its housing and then used a zip tie to anchor it to my carrier. Now I have four usable USB ports. One has a wireless network adapter in it. I also used one with a miniature keyboard but I am not using it now as I am using the Remote Desktop Connection instead. I also looked at adding an LCD display to the box but found that I just do not have enough room in the box. Another of the USB ports would have been used to connect a touch screen to the system.
Next I attached the stack to the top side of the carrier and the power distribution board to the bottom side with nylon standoffs.
The last pieces to go onto the carrier were the relays. There are three relays. One for the spindle, One for spindle direction and the last one for spindle cooling. They got put into a stack and mounted on the carrier with nylon standoffs too.
Step 10: Wiring the Carrier
After getting all of the pieces mounted on the carrier they needed to be connected electrically. I built a small wiring harness to connect the relays to the power distribution board and to the CNC Controller board. Each relay connects to its control pin on the CNC Controller board (the white expandable sleeving bundle). Then each relay gets connected to the power distribution board for 12 VDC power. On the other side of the relays I made a couple of cables that provide the ground for the signals being controlled by the relays and a very small cable to connect the relays to the spindle connector. It is sleeved with yellow on this side as it connects directly to the Spindle connector on the side of the box. I used inline connections to allow me to more easily disconnect the cables and get the carrier into and out of the box.
The relays are controlled directly from the Alamode via the CNC Controller shield. Of course, you could use these three relays to control the functions mentioned but they could also be used to control the functions of the print head and heat pad on a 3D printer or a LASER in a laser engraver along with a fume extractor or whatever. I plan on being able to move this control system between all of those environments in the future - unless I decide to dedicate this one and build more of them for my future machines. It would also be really easy to use the 5 VDC relays to switch 12 VDC and then use that to control a solid state relay or whatever is wanted.
I built another small wiring harness to connect 12 VDC from the power distribution board to the CNC Controller shield. This 12 VDC is used to power the stepper motors.
Step 11: Installing the Carrier
Now it was time to install the carrier with all of its boards and cables into the enclosure. The hardest part is connecting the power to the power distribution board. First I plugged in the connector to the LEDs that are in the switches. Next comes the fans and finally the power. Everything is color coded because I am notorious for incorrectly connecting things. The cables that are attached to the switches and the connectors have to be gently pushed and pulled to get the carrier in the box but once there is sits comfortably.
Step 12: Connecting to the External World
After getting the carrier board connected and in place and then screwed down at its corners the remaining steps are to connect the switches to the CNC Controller shield. Followed by connecting the axes cables to the CNC Controller shield. Finally the last connections are the relays and the ground for the spindle connection. It is tight but there is enough room for everything to fit nicely into the box.
Step 13: Testing
After getting everything hooked up I powered up the box and started testing everything. The switches worked and I was able to control the system as I thought it should work.
Next I went to my laptop and used the Remote Desktop Connection to log into my Raspberry Pi.
I had already installed the Arduino IDE on the Raspberry Pi and done a lot to prepare to run the system. It was a learning experience and I did not know what else I might need to do to make everything work. So I got the software working before I ever put anything in the box. The biggest difference between my getting the software working and the current state is that I now have the switches too and can control the system by pressing those buttons and it all works.
I ran the Grbl Control program on my Raspberry Pi and connected to the Grbl program that is running on the Alamode. I opened a file that I had created (a modified coaster tutorial) and ran the program. It ran all the way through and stopped as I expected it to.
I checked to make sure that nothing got hot. Now I have to get out my milling machine and get it back together and try to make something.
Thanks for reading my instructable.
Let me know what might have done differently. Maybe I will make another one.
4 People Made This Project!
- cdtaylor51 made it!
- mark.buttle1 made it!
224 Comments
2 years ago
Pretty ambitious project! But why didn't you simply use the Protoneer CNC hat for the Raspberry Pi and leave the Arduino out of it?
Reply 2 years ago
Well if you look at the date of my instructible you will notice that it was done some time before the hat you mentioned came out. The hat that I used in my instructible was also made by the Protoneer guys but was a much earlier version that did not have voltage level changers built in. That is why I used the A la mode board. Buy the way the newer Protoneer hat has an Arduino MCU built in (the MCU that is mentioned is an ATMEGA328, the same MCU that is on the Arduino UNO). I still have a couple of their boards and will probably use them on future projects.
The Arduino is used because the RPi is not very good at real time tasks (controlling the stepper motors for example). But is very good and inexpensive for what it does. It takes a gcode file and feeds it to the Arduino one instruction at a time. The Arduino can't do all that by itself. So you need both of them. In this sort of configuration.
Thanks for looking at my instructible!
Question 4 years ago
how much coding do you know? I am trying to make a hardcore 5+3 axis cnc with a few extras. so far I am trialling the nano aspect and raspberry pi. how many extra axes can you use with your setup?
I see 4 polulu's is it 4 axis or are you using the extra for something else?
Answer 3 years ago
Most 8 bit processors just don't have the performance to drive 5 axis simultaneously. However I did create a solution for hobbyists looking into 5 axis cnc. Have a look at https://awesome.tech my website.
Answer 4 years ago
My system is a 3-axis setup. The fourth driver is not used in my system at this time. My setup can used the fourth driver to run a second stepper on one of the three channels. That is normally used if there is a lot of weight on one particular axis or you just want more power on that axis. I have not looked at more complex configurations excepting my 3D printer. It would be awesome to see an instructible on a 5+3 system.
Question 4 years ago on Introduction
What size stepper motors are you driving with this?
Answer 4 years ago
I had not seen your question until today. my little CNC uses NEMA 17 size stepper motors. I would suggest that you look at the Polulu site and read their very informative posts about their stepper drivers. You need to know the maximum rated current that the motor can take and the maximum current that the drivers can supply.0
4 years ago
Thanks to your posting I can now make a cnc machine once i have bought all the parts some of which are on eBay in Australia but still very cheap
Reply 4 years ago
Sounds good to me. i can tell you that this thing actually does work. It will bit a little bit cheaper if you use the new CNC hat with a newer Raspberry Pi (a 40 pin version). Then you will not need the Alamode board because a pre-programmed Arduino Nano is included on the new CNC hat. Everything else is pretty much the same. Good luck and post a pic when you have done. Feel free to ask questions if you need too. There is a lot of information in these comments too.
Reply 4 years ago
Hi
Thanks for contacting me but might be taking a slightly different route as been given plans to build a cnc for free by someone on you tube who had offered them to someone else which was before i found your posting.
Turns out they use a old windows xp computer.
Depending on what route i go ill still your your posting as a guide but wont use grey box to house everything might use a old pc case as loads about dirt cheap or even a old satellite tv box
Did get as far as having 3 stepper motors , audrio version of Ras pi and i think drivers for motors which were small motors.
Looks like got to start all over again thanks to house fire which did me more good then bad.
As for pictures keep meaning to get new phone but that hasnt happened yet.
Reply 4 years ago
Thanks again for your comments and good luck with your project.
4 years ago
Great job!
Reply 4 years ago
Thanks
4 years ago
I'm Italian. I apoligize about my poor english
Please, do you have further data and some video in which you show the system working with stepper motors. About the data, i talking about precision and repeatability of the tool in flange.
I want and i need to build my own CNC machine, and so far your seems to be the best solution. But i want to be sure i don't waste money to buy what you suggested in you post and have just workin stepper motor, without precision
I hope what i wrote is clear for you
Reply 4 years ago
Lately I have been working on my 3D printer and I do not currently have a video of my CNC machine working because it has not worked for some time. We have moved three times in the past three years. I am now working on getting my CNC machine working again. Part of the reason that I started building my CNC controller was that I was not happy about the precision and repeatability of my little machine. I bought new lead screws and anti-backlash nuts and started modifying my machine. It turned out that doing the modifications to my machine was more difficult than I had anticipated and took a long time. I am now making good progress finishing those modifications. I have printed some new mounting components on my 3D printer that are allowing me to get things done now that I had a lot of trouble doing previously. Hopefully, I will finish things up in the next week or so. Then I could make a video of my machine working but it is not working right now and is in many pieces.
You concern with precision and repeatability is the most important aspect of a machine tool, in my opinion. I can tell you this. Leadscrews are more precise than belts, in general, as belts will occasionally slip and result in missed steps. However, my CNC machine had cheap threaded rods. So I did not have that problem. I instead I had a problem with precision and repeatability because the threads were not precision cut. Thus, I replaced the threaded rods with precision lead screws. Also, the anti-backlash mechanisms were not that good and they were replaced with the leadscrews and matching anti-backlash nuts. Further, my original stepper motors were connected to the threaded rods with plastic tubing that didn't work very well and I replaced the tubing with aluminum couplers.
The precision and repeatability is not a big factor of the software, it is very accurate. Precision and repeatability is more determined by physical factors of the machine itself. Precision of the leadscrews and anti-backlash nuts, stepping or micro-stepping of the stepper motors, torque and holding capacity of the stepper motors, smoothness of the slide bearings, stability of the machine, orthogonality of the axes, vibration, runout or how much the spindle's bit moves from perfectly straight, etc.
Take a look at the new CNC board from Protoneer. It will make the project a bit cheaper and easier to do (you would not need the Alamode board). If you are interested in the precision and repeatability of the software take a look at the GRBL site on Github. Lastly, read through the comments here. you will find a lot of great information about CNC machines.
4 years ago
this is absolutely fantastic cdtaylor51! thank you very much! I am building my second cnc machine (I am doing all traditionally though - linuxcnc, stepper motors, etc.) and I know what it takes to design and build your own. you've done great job!
Reply 4 years ago
Thanks for taking a look. Good luck on building your machine.
4 years ago
you left a description and purchase link for almost everything but the 8 pin connectors, both male & female, used to connect steppers to the box. please let us know what they are called and where we can buy them. Thanks much!
Reply 4 years ago
Try this and there is another parts list in the comments, way back.
http://m.ebay.com/itm/110983775612?_mwBanner=1
This link worked a few minutes ago.
Reply 4 years ago
Worked perfectly. Thanks much.
