Introduction: Raspberry Pi As Completely Wireless Router
This instructable is to create a wireless router from a raspberry pi and a wireless adapter, None of this work is original just pieced together after several fails I hope this helps. My sources are:
https://howtoraspberrypi.com/create-a-wi-fi-hotspo...
https://github.com/billz/raspap-webgui
https://github.com/billz/raspap-webgui/issues/141 contributor Caxton1
For this project I used a raspberry pi zero w but any raspberry pi may be used and a edimax wifi adapter.
https://www.amazon.com/gp/product/B003MTTJOY/
If the raspberry pi does not have an onboard wifi two adapters should be able to accommodate they must have access point capabilities. I am using a fresh version of jessie with pixel. I am unsure about other versions.
I will be using the adapter as my connection to the external wifi and the onboard wifi as my access point or point other devices can connect to. internet-->wlan1-->wlan0-->device
Step 1: Prepairing the Additional Wifi Adapter
With the raspberry pi on and connected insert the wifi adapter into the raspberry usb
Verify in the pixel desktop that both wireless connections are present and one is connected to a external wifi router
Update the pi with:
sudo apt-get update && sudo apt-get upgrade -y
Then move the wifi credentials to another location with
sudo cp /etc/wpa_supplicant/wpa_supplicant.conf /etc/wpa_supplicant/wpa_supplicant.conf.sav
sudo cp /dev/null /etc/wpa_supplicant/wpa_supplicant.conf
Step 2: Install the Workhorse and Web Gui
Now install the web gui that will do most of the work
sudo wget -q https://git.io/voEUQ -O /tmp/raspap && bash /tmp/raspap
Wait for the next prompt
Type "y" to continue
Type "y" to install
Type "y" to reboot
Your raspberry will not have internet access for the next step
Step 3: Re-enable Internet Access and Correct Configuration File
To re-enable internet access we need put the wifi credentials file back in place with
sudo cp /etc/wpa_supplicant/wpa_supplicant.conf.sav /etc/wpa_supplicant/wpa_supplicant.conf
Then reboot again
sudo reboot
Once rebooted in the pixel desktop verify that one connection is associated with your wifi ssid and the other is with an ssid "raspi-webgui"
Open a terminal, edit the /etc/network/interfaces with sudo nano /etc/network/interfaces file in my case I will delete "wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf" from the wlan0 section and in the wlan1 section change the line "iface wlan1 inet manual" to "iface wlan1 inet dhcp"
My file looks like this
# interfaces(5) file used by ifup(8) and ifdown(8)
# Please note that this file is written to be used with dhcpcd # For static IP, consult /etc/dhcpcd.conf and 'man dhcpcd.conf'
# Include files from /etc/network/interfaces.d: source-directory /etc/network/interfaces.d
auto lo iface lo inet loopback
iface eth0 inet manual
#wlan0 as access point
allow-hotplug wlan0
iface wlan0 inet manual
#wlan1 connects with external wifi
allow-hotplug wlan1
Once closed restart the raspberry
sudo reboot
Step 4: Getting a the Wifis to Talk to Each Other
After the reboot the internet will be accessible now the wlan1 and wlan0 have to be told to talk to each other, In the terminal:
sudo apt-get install iptables-persistent -y
select yes to save current IPV4 rules
select yes to save current IPV6 rules
sudo nano /etc/hostapd/hostapd.conf
Comment out the driver #driver=nl80211
sudo nano /etc/default/hostapd
Find the line #DAEMON_CONF="" and change it to DAEMON_CONF="/etc/hostapd/hostapd.conf"
sudo nano /etc/init.d/hostapd
Find the line DAEMON_CONF= and change it to DAEMON_CONF=/etc/hostapd/hostapd.conf
sudo nano /etc/sysctl.conf
uncomment the line #net.ipv4.ip_forward=1 so that it becomes net.ipv4.ip_forward=1
sudo sh -c "echo 1 > /proc/sys/net/ipv4/ip_forward"
sudo iptables -t nat -A POSTROUTING -o wlan1 -j MASQUERADE
sudo iptables -A FORWARD -i wlan1 -o wlan0 -m state --state RELATED,ESTABLISHED -j ACCEPT
sudo iptables -A FORWARD -i wlan0 -o wlan1 -j ACCEPT
sudo sh -c "iptables-save > /etc/iptables/rules.v4"
sudo reboot
Step 5: Connect to and Configure Your Wi-Fi Hotspot
When your raspberry pi restarts, and you should see a “raspi-webgui” network in the list of accessible networks.
Once the network is visible, all you have to do is connect to it, the default password is ChangeMe.
You can change this password, network name, and many other things by connecting to the admin interface of your raspberry hotspot via your web browser, by default the address should be 10.3.141.1.
login:admin
password:secret
I hope this helps
Raspberry Pi Contest 2017
11 Comments
3 years ago
Hi, thank you for your tutorial.
I have Raspberry Pi4, I followed everything, but I have the problem that I can't access RaspAP on 10.3.141.1.
On my Raspberry the wlan1 connects to the network and I have internet access, but the raspi-webgui hotspot does not have internet access.
I wanted to know some advice, my network looks like in image1
Question 3 years ago on Step 5
I think I am close to making this work. My issue is that I need the wlan1 interface to be the AP and wlan0 to be the WAN side. This is due to a high gain antenna I have on the wlan1 device for a building-to-building deployment. I have tried to change the interfaces around, but I must be missing some of the files. All I seem to do is break it. Does anyone have experience with switching these around? What files will need to be changed to get it working?
Question 4 years ago on Step 3
Hi, trying for a couple of days now to get this working but there seem to be major differences in Raspbian-Stretch that are not reflected in any howto I found so far.
When I just copy the wpa_supplicant back it causes wlan0 to connect to the internet, wich seems to me actually quite logic
iwconfig says:
wlan0 IEEE 802.11 ESSID:"TeliaGatewayxx-xx-xx-xx-xx-xx"
Mode:Managed Frequency:2.412 GHz Access Point: xx:xx:xx:xx:xx:xx
the "rasp-gui" hotspot is from now on not available anymore while wlan1 (actually wlx00c0ca82xxxx on my pi with predictable interfeces turned on) remains unassociated.
Has anyone been able to archive this setup with stretch?
Answer 4 years ago
Hi there, I'm having the same problem as you were. Can you explain how to resolve this issue??
4 years ago
Ok, solved:
first:
Second:
Now the problem is:
STEP 1: OK
STEP 2: Country no selected wlan1
STEP 3: internet wlan1, no internet wlan0 (no ip, can´t access to: 10.3.141.1.)
STEP 4: no wireless interface found (icon show red cross) internet wlan1, no internet, no ip, show "raspi-webgui" but can´t access to 10.3.141.1 in wlan0)
Raspberry Pi 3 b+
Raspbian Noobs
Dongle wifi: Edimax EW-7811UN
Regards
Reply 4 years ago
Lets start with number 2 is the country code set in the /etc/wpa_supplicant/wpa_supplicant.conf file example my file contains a line country=GB
Reply 4 years ago
OK, solved step2, but on the step3, in my /etc/network/interfaces only show this:
nothing more....
Regards!!
Reply 4 years ago
can anybody help me, please?
Reply 4 years ago
Unplug the ext wifi, reboot, than plug it in again. If you dont use predictable interfeace names wlan0 and wlan1 seem to quite randomly swap at boot when both are connected on startup.
4 years ago on Step 4
Hi,
when copy:
sudo iptables -t nat -A POSTROUTING -o wlan1 -j MASQUERADE sudo iptables -A FORWARD -i wlan1 -o wlan0 -m state --state RELATED,ESTABLISHED -j ACCEPT
show:
Bad argument `sudo'
Try `iptables -h' or 'iptables --help' for more information.
Reply 4 years ago
Ok sorry for the editing the site clumped these together into one line this should be two lines
