Introduction: Raspberry Pi B+ Case, Quick and Cheap
Welcome to my first instructable.
How to make a Case for that new Raspberry Pi B+ for ~ $2
Step 1: Supplies and Tools
Supplies:
Ace hardware Mini Utility Box- http://www.acehardware.com/product/index.jsp?produ...
Tools:
Needle Nose Pliars
Jewelry files
Metal Sawzall blade with handle
Exacto type knife
Dremel Tool with cutoff wheels (#420)
Step 2: Dry Fit.
Since the box that is suggested has partitions cast inside that will need to be removed the first steps will be to lay to Raspberry Pi b+ (RPb+) in the box. Making sure that the board does not overlap the sides of the box (ok for ports to overlap sides).
Step 3: Mark Your Cuts.
Once the Board is placed and held in the box mark the edges of the board so you will know where to cut.
Step 4: Start Your Cuts.
Cut the Partitions vertically where you marked. I used the Sawzall for this step.
Step 5: Dremel Horizontally
Now, Take the dremel tool and Cut the bottom so that the box can be deep enough to hold the RPb+. The Plastic will melt so try not to stay in the same area too long unless you want a pool of plastic in and around the cut.
Step 6: Clean Dremel
As I said, the Plastic will melt. Since the dremel is spining in hot plastic you will end up with poly strings wrapped around your shaft. Just Cut them loose.
Step 7: Cut and Gross
The plastic melted and did not leave a clean edge.
Step 8: Clean Up the Melty Mess
Go Over you cuts and clean the up as much of the plastic mess as possible.
Step 9: Dry Fit Again
Dry Fit the RPb+ again. Mark where the holes will go.
Step 10: Cut the Port Holes
I used a hot exacto for this step. I did not get any pictures of it because was playing with fire. Just heat the exacto blade over a open flame. You can jam it in the plastic once it is hot and it will melt/cut it like butter.
Step 11: Clean Up the Port Holes
I went thru and files the edges of the port holes. The Hot knife method of cutting plastic does not make for straight clean cuts.
Step 12: Dry Fit, Mark Cut Again
Dry fit the board again. This time marking the USB and network port. Cut using the Hot knife or the dremel tool.
Step 13: It Fits.
Woo hoo. After lots more dry fitting and cutting it fits. Just keep testing till you get it to fit.
Step 14: Cut So Fits.
I forgot to cut space for the SD card. So now I am doing that.
Step 15: Done.
Done Picture. I did not attach the RPb+ to the inside of the box in anyway. I just am using it for protection while I decide what to do with this one. If you would like to attache it I was thinking hot glue or nuts and bolts.
Thanks and have fun!
